Zrun
Intake manifold Gasket mod
I've heard about a type of mod that is just a piece of non thermal sensitive gasket that you put between your engine block and intake manifold, thus decreasing the intake manifold temperature.
Anyone heard? Seems like a cheap mod, a piece of plate only. But a non conductor thing that can withstand high temperature of the block might be expensive..
Share this post
Go to www.hondata.com .... they've one for Honda RSX (Integra)
Read it there :-)
Edited by Andrewkb
Share this post
Are you talking bout the spoon sports venturi plate?
Venturi Plate : Racing engines are machined with extreme precision and feature filled-in intake ports. This is done to make use of the venturi effect a fundamental of fluid mechanics. Specifically, by smoothing a portion of the intake port and making it narrower, it is possible to increase the speed of the air-fuel mixture. By simply inserting this component between the cylinder head and the intake manifold, it is possible to obtain the optimum port shape for the above-mentioned venturi effect. When the speed of the air-fuel mixture is increased in this way, the efficiency of combustion inside the engine is improved and power increases accordingly.
Share this post
Yeah.. Somethig like that.. I only knew that it will decrease the temperature of your intake manifold altogether, but not sure about the air flow property thing..
Looks like cheap mod, but it cost $200USD for this piece of metal..
Share this post
Hmm... I only know that this item i posted cost 280,000 yen. Its for B16A and B16B engines only.
Share this post
US$200 for the gasket is not cheap.....and with the labour cost in, it is definitely not a cheap mod...sweatdrop.gifsweatdrop.gif
Share this post
Hi
Ppl
I am
Looking to replace my car manifold gasket
My car model is Toyota sienta 2008
Any idea where I can get it replaced and want to know the costing too
Share this post
