Orangie Neutral Newbie January 15, 2004 Share January 15, 2004 Alamak... throw liao huh? Give me lah... Very likely its due to the terminal block at the battery. Is the alternator grounded? This for me got the most effect Did mine for $80 grounding kit. Got no effect till I change the terminal block. Engine got better response(just enough to feel the diff). From then, grounding is DIY liao Haven't tried taking out the grounding to try Maybe same also ↡ Advertisement Link to post Share on other sites More sharing options...
Hitman Neutral Newbie January 15, 2004 Share January 15, 2004 Yeah yeah ... throw liao. Haven't tried taking out the grounding to try Maybe should .... one fine day take out and feel the diff. Like me .... very free nothing to do .... morning run with E68 and then take out and go afternoon run without E68 ... can feel lots of difference Link to post Share on other sites More sharing options...
Konspire Neutral Newbie January 15, 2004 Author Share January 15, 2004 wat is e68? Link to post Share on other sites More sharing options...
Epsilon 2nd Gear January 15, 2004 Share January 15, 2004 a type of air compressor.....like airmax Link to post Share on other sites More sharing options...
Hitman Neutral Newbie January 15, 2004 Share January 15, 2004 Answer is as listed .... airjet thingy into your manifold Link to post Share on other sites More sharing options...
Konspire Neutral Newbie January 15, 2004 Author Share January 15, 2004 aahh..for the air intake, rite? but doesn't that drain your power? Link to post Share on other sites More sharing options...
Hitman Neutral Newbie January 15, 2004 Share January 15, 2004 No .... gives you more power This is my take. Our ECU is programmed for a rich mixture of air and fuel ratio. Wat E68 does is that is bypasses the air intake sensor and goes straight into the combustion manifold. As such you get more air and a leaner mix in the chamber, whilst tricking the ECU. I could be wrong but I think thats the way its done. FC also better but I cant tell cause after installation I WOT most of the time Link to post Share on other sites More sharing options...
Konspire Neutral Newbie January 15, 2004 Author Share January 15, 2004 it's not like the CAI logic izzit? how much did u do it for? Link to post Share on other sites More sharing options...
Hitman Neutral Newbie January 15, 2004 Share January 15, 2004 No CAI still depends on the air sensor as it goes through the basic intake setup. Thus your ECU reads more air and compensates with more fuel, but you are still burning rich. This one overrides thats I installed at S$188 (McWell) but I saw in JB also got (Holiday Plaza) .... I didnt ask how much but I think its cheaper there Link to post Share on other sites More sharing options...
Konspire Neutral Newbie January 15, 2004 Author Share January 15, 2004 is the unit big? major installation? pass inspection or not? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 15, 2004 Share January 15, 2004 hmm up to now still haven seen a negative comment from pple who do gounding for their rides Me .... I thought my ride was better after grounding , but just to satisfy my tastebuds, I took out all the grounding wires on a quiet weekend 6 months later ... and guess what , the car feels the same .... with and without grounding. Conclusion : The wires ended up in the trash bin. But it aint done by any fellow members here. It was done by some supposed aftermarket shop. I think it's psychological. I can't serioudly say I got any improvement from grounding. Link to post Share on other sites More sharing options...
Hitman Neutral Newbie January 15, 2004 Share January 15, 2004 Can can see it here http://www.micro-compressor.com I think u better take out for inspection as a leaner mix may result in higher CO2 levels I think Link to post Share on other sites More sharing options...
Hitman Neutral Newbie January 15, 2004 Share January 15, 2004 Ya lor .... thats why my ended up in the trash bin Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 15, 2004 Share January 15, 2004 Mine's still inside. If I ever take them out, they'll likely go to the trash too! Link to post Share on other sites More sharing options...
Hitman Neutral Newbie January 15, 2004 Share January 15, 2004 You an turn it into a clothes hanger dryer for your home mah Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 15, 2004 Share January 15, 2004 Too short for a clothes dryer wire lah..... Link to post Share on other sites More sharing options...
Firefox Neutral Newbie January 15, 2004 Share January 15, 2004 no pwr increase or fuel saved. oni thing is load better balanced, so brighter head light n audio sounds better. that all 4 me Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 15, 2004 Share January 15, 2004 I guess it works for some and not for some! ↡ Advertisement Link to post Share on other sites More sharing options...
Grounding VS Voltage stabalizing
Hyflux Preference Shares
Jardin 80% plunge
Jardin 80% plunge
HKS grounding kit
HKS grounding kit
Cab passenger shares 15% liability for her injuries
Singapore shares hit 3-year low
Fed taper starts. $85B to $75B
Noob questions on shares rights - OCBC
