Verve 1st Gear August 3, 2007 Share August 3, 2007 Hi, am considering the above model, does anyone know the fc of this car (present fc after so many years in service, not when new) heard toyotas are generally reliable, how about this make does anyone own this car or know of people who do. many thanks in advance. btw, i posted this cos i didnt find this car in the fuel consumption database picture http://www.sgcarmart.com/main/info-2XtZxB8W-1138.html ↡ Advertisement Link to post Share on other sites More sharing options...
Octopus 3rd Gear August 3, 2007 Share August 3, 2007 I believe Pisces69 own the model you mentioned, perhaps he will advise when he see this thread? Me driving a 91 Corolla, average 12km/l. FC rather consistent, not much significance difference whether drive fast or slow. Link to post Share on other sites More sharing options...
Verve 1st Gear August 3, 2007 Author Share August 3, 2007 ok thanks, then fc for the 1.6 at corona should be less, i am guessing cos it must be heavier, how's the maintenance like for your corona, costly to upkeep? Link to post Share on other sites More sharing options...
BoneStock 5th Gear August 3, 2007 Share August 3, 2007 both using same 4AFE engine. yes, you are right...Corona should consume more petrol because of the heavier body Link to post Share on other sites More sharing options...
Octopus 3rd Gear August 3, 2007 Share August 3, 2007 Mine is the corolla... So far around 3 ~ 4 years, the wear and tear parts got replaced. For the past year no problem, just routine oil change maintenance. Did broke down once due to distrubutor problem, replaced with a 2nd-hand parts and still working fine. Link to post Share on other sites More sharing options...
Genie47 1st Gear August 3, 2007 Share August 3, 2007 This is a BBC. There is no difference between the G7 Corolla and this when it comes to FC. Link to post Share on other sites More sharing options...
Friendstar Supercharged August 3, 2007 Share August 3, 2007 hey i used to own the car when the car was 10 years old, it still gave me 14km/litre. now i donno. the car should be 18years old now. there was once i saw it on the road. basically, rest assure that this is a VERY GOOD CAR Link to post Share on other sites More sharing options...
Friendstar Supercharged August 3, 2007 Share August 3, 2007 oh sorry, mine was the corona cd Link to post Share on other sites More sharing options...
Albeniz Turbocharged August 3, 2007 Share August 3, 2007 Hi, heard toyotas are generally reliable, how about this make does anyone own this car or know of people who do. many thanks in advance. btw, i posted this cos i didnt find this car in the fuel consumption database picture http://www.sgcarmart.com/main/info-2XtZxB8W-1138.html Old cars, no matter how reliable the brand can be, definitely needs parts replacement due to wear/tear and age. Be prepared to set aside some money, otherwise you might be in for a rude shock. Link to post Share on other sites More sharing options...
Albeniz Turbocharged August 3, 2007 Share August 3, 2007 My presea is 16 years old. About the same age as the corona you are looking at. The car was excellent up to the 15th year mark without much repair. Finally when it turned 16, age has finally caught up and I spent $4-5k replacing the worn and torn parts to make sure it could survive till 2011. I could have chosen the cheaper option of selling the car away. The corona seller might have the same issue, instead of replacing all the almost-gone parts, he decide to sell the car away, and unwittingly, the next buyer takes over the ownership. Link to post Share on other sites More sharing options...
Verve 1st Gear August 3, 2007 Author Share August 3, 2007 so anyway to buy one where the seller actually changed the replacement parts, from your experience what are the parts to look out for. i am prepared to spend 1-2k to get the car up to mark after buying. Link to post Share on other sites More sharing options...
Albeniz Turbocharged August 3, 2007 Share August 3, 2007 (edited) Likely wear and tear parts:- Engine might need an overhaul, or a complete change. This can be expensive. Oil leaks, distributor problems. Brake pads. Radiator. Alternator. belts, squeeky sound. Strut bars, lower arms. Auto gear box. suspension. shock absorbers. Dealer usually use a cheap coat of paint which might not last more than 2 years under the sun. Some of the problems might only surface after you have driven the car home for 1 month. Edited August 3, 2007 by Albeniz Link to post Share on other sites More sharing options...
Albeniz Turbocharged August 3, 2007 Share August 3, 2007 (edited) This is a BBC. There is no difference between the G7 Corolla and this when it comes to FC. I was under the impression that the big boot Corona is heavier than the G7. I would expect the FC of corona to be slightly worse. Edited August 3, 2007 by Albeniz Link to post Share on other sites More sharing options...
Verve 1st Gear August 3, 2007 Author Share August 3, 2007 so how much did you spend for the wear and tear parts, hope its less than some bros here who spent 5k i am prepared to spend 1-2k to replace some parts when i get the car and maybe another 1-2 k progressively as ownership of the car goes along. but hopefully not above 5k. don't know if my expectations are realistic though. Link to post Share on other sites More sharing options...
Albeniz Turbocharged August 3, 2007 Share August 3, 2007 I think your budget plan is quite reasonable. Link to post Share on other sites More sharing options...
Octopus 3rd Gear August 4, 2007 Share August 4, 2007 [reply] so how much did you spend for the wear and tear parts, hope its less than some bros here who spent 5k i am prepared to spend 1-2k to replace some parts when i get the car and maybe another 1-2 k progressively as ownership of the car goes along. but hopefully not above 5k. don't know if my expectations are realistic though. I think since I own the car until now, total repair is definately less than $5k. The most expensive job was a top-overhaul + clutch replacement which cost about $750. Your budget should be more than enough, provided that the car is in a reasonable condition when you got it. Link to post Share on other sites More sharing options...
Imax84 Neutral Newbie June 2, 2010 Share June 2, 2010 Sorry anyone knows where to get the front fog light place beside the signal lamp for AT190? Link to post Share on other sites More sharing options...
Happily1986 5th Gear June 4, 2010 Share June 4, 2010 TS why not just get the AE101 instead? Lighter car body, same engine. Maybe interior volume smaller alittle but definitely better FC than Corona assuming you compare both 1600cc ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Toyota Corolla Cross
