Prodigysaint Clutched August 21, 2008 Share August 21, 2008 i've tried using water to clean but it spreads to a larger area. in case u guys are lost bout what i said.. it's the carbons (driving with window wound down) deposited along the interior of the car's cabin roof side near the window... i dunno what i'm talking.. but hope someone understand.. ↡ Advertisement Link to post Share on other sites More sharing options...
Silhoutte Clutched August 21, 2008 Share August 21, 2008 I heard that there is this thing called steam cleaning for car interiors. Maybe you can do a search in sgcarmart? Link to post Share on other sites More sharing options...
Mr_b20 6th Gear August 21, 2008 Share August 21, 2008 use VANISH POWER O2 ! Link to post Share on other sites More sharing options...
Maddriver 4th Gear August 21, 2008 Share August 21, 2008 I know what you referring to...especially if biege interior..is more obvious..I used plain water to clean tat all... Link to post Share on other sites More sharing options...
Linlaupeh Neutral Newbie August 21, 2008 Share August 21, 2008 Fwah If I use plain water sure rub until LeePee tua suay liap Link to post Share on other sites More sharing options...
Maddriver 4th Gear August 21, 2008 Share August 21, 2008 I ok lei...use water can see patches when is wet but once dry is ok liao.. Link to post Share on other sites More sharing options...
Adawang 1st Gear August 21, 2008 Share August 21, 2008 u need to use some detergent as well naturally the black spot will spread , wipe it a few times with some detergent and = as good as new Link to post Share on other sites More sharing options...
Prodigysaint Clutched August 21, 2008 Author Share August 21, 2008 tot steaming is for mainly the leather seat or something?? mmm.. anyway thanks bro.. will check out the price.. Link to post Share on other sites More sharing options...
Prodigysaint Clutched August 21, 2008 Author Share August 21, 2008 does this really work?? dun later everything also vanish.. including the colour of the material.. haha Link to post Share on other sites More sharing options...
Prodigysaint Clutched August 21, 2008 Author Share August 21, 2008 (edited) so there are no products for this item yet i supposed.. since u only use water and some detergent.. get the BROTHERs to create some products for this.. hahhaa anything for the rubber lining?? cleaning the lining of the rubber between the door and window??? Edited August 21, 2008 by Prodigysaint Link to post Share on other sites More sharing options...
Prodigysaint Clutched August 21, 2008 Author Share August 21, 2008 sounds logical.. thanks bro.. Link to post Share on other sites More sharing options...
Corgan Neutral Newbie August 21, 2008 Share August 21, 2008 autoglym got interior cleaner. white bottle with green colour wordings. it works quite ok. Try autobacs Link to post Share on other sites More sharing options...
Xiao_bai77 Neutral Newbie August 21, 2008 Share August 21, 2008 Is there any way to remove a cig burnt mark for the car interior celing instaed of changing the whole entire interior? The interior celing is grey clothing.. Link to post Share on other sites More sharing options...
Corgan Neutral Newbie August 21, 2008 Share August 21, 2008 i think for cig burnt mark, the material itself should be slightly burnt off right? I am not sure whether the cleaner will be of use. Sorry. Link to post Share on other sites More sharing options...
Maddriver 4th Gear August 21, 2008 Share August 21, 2008 Th fabric cleaner are on the way..for rubber lining..I have #253 for rubber lining.. Link to post Share on other sites More sharing options...
Silhoutte Clutched August 22, 2008 Share August 22, 2008 Well I think they do interior cleaning on the fabric seats, which means they should be able to clean your interior roof I guess... Link to post Share on other sites More sharing options...
Mr_b20 6th Gear August 22, 2008 Share August 22, 2008 slight cigg burnt mark use wd40 ! ↡ Advertisement Link to post Share on other sites More sharing options...
ItzJuzCarbon can customise any of your steering wheels, car parts, interior trims, side panels and accessories with Carbon Fiber!
Did a interior detailing, but
2016 Mercedes E-class (W213)
Is coffee without coffee beans still coffee?
GSS 2021 join forces with Lazada
From India to S.Africa in an off-peak Hyundai Matrix
Black flakes from washing machine
Blast from the past!!! WWF stars!!
