Gorjiam 1st Gear November 1, 2012 Share November 1, 2012 Continue from here. http://www.mycarforum.com/index.php?showto...640&st=1680 ↡ Advertisement Link to post Share on other sites More sharing options...
Thingy 1st Gear November 1, 2012 Share November 1, 2012 yawns Link to post Share on other sites More sharing options...
Bathory Clutched November 1, 2012 Share November 1, 2012 Thanks Desmojon for the selespeed manual. Link to post Share on other sites More sharing options...
Firestorm9 1st Gear November 1, 2012 Share November 1, 2012 2007 159 on sgcarmart.. any history of this pls? http://www.sgcarmart.com/used_cars/info.ph...698&DL=1000 thnx! Link to post Share on other sites More sharing options...
Theredstar 2nd Gear November 1, 2012 Share November 1, 2012 Bro Saabre, u mentioned that this oil u using cool from 100-80 quickly is this cooling u speak of achieve in the last 1-2k stretch of easy driving home? i only see my olio meter go up never down leh Link to post Share on other sites More sharing options...
Theredstar 2nd Gear November 1, 2012 Share November 1, 2012 Can any bros here tell me what does this mean? "deactivating the ASR, if any, using the relevant dashboard button and pressing the accelerator pedal quickly flat out, will obtain a Link to post Share on other sites More sharing options...
Iridiumx Clutched November 1, 2012 Share November 1, 2012 Can any bros here tell me what does this mean? "deactivating the ASR, if any, using the relevant dashboard button and pressing the accelerator pedal quickly flat out, will obtain a "brilliant" start" means more spectacular.. i.e. burn some tire.. make some smoke.. Link to post Share on other sites More sharing options...
Bathory Clutched November 1, 2012 Share November 1, 2012 Can any bros here tell me what does this mean? "deactivating the ASR, if any, using the relevant dashboard button and pressing the accelerator pedal quickly flat out, will obtain a Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear November 1, 2012 Share November 1, 2012 Bro Saabre, u mentioned that this oil u using cool from 100-80 quickly is this cooling u speak of achieve in the last 1-2k stretch of easy driving home? i only see my olio meter go up never down leh Millers. 50WT Theredstar, just to be absolutely clear, I don't know exactly if it is 1 or 2 km away, I do know that I take the last stretch home, rather easy. I don't always push the car so very hard that its at 100 all the time, nor is it exactly 80 when I reach home. its a variance, and a general guideline, not absolute figures. And it does get up to temp and come down quicker than most other oils I've used. for a 50wt, I personally feel it is faster than before, gauging by usual check points when i look at the meter. certain junctions, certain turning points, and i glance at the oil temp, its already up, or already down. so i hope you don't take it as absolute. my present car is not a 159, so the cooling system and other things are not the same as yours. it would react differently. If yours is 2nd hand, best to get it checked out, serviced, oil changed... etc and then monitor from there, compared with the old fluids in the system. Link to post Share on other sites More sharing options...
Desmojon 1st Gear November 1, 2012 Share November 1, 2012 ASR is the anti-slip reduction. It basically cuts the power to the front wheels to stop them slipping. If off it, will get a great wheel spin..... Ya right. I had a wheel spin with ASR on while doing a U turn. Maybe something to do with the electronic LSD program taking priority and cancels out the ASR function. Electronics also decided I should move off in 2nd gear one day. ASR? Not sure. Link to post Share on other sites More sharing options...
Iridiumx Clutched November 1, 2012 Share November 1, 2012 Ya right. I had a wheel spin with ASR on while doing a U turn. Maybe something to do with the electronic LSD program taking priority and cancels out the ASR function. Electronics also decided I should move off in 2nd gear one day. ASR? Not sure. ASR allows some wheel slip. not 0 wheel slip. Link to post Share on other sites More sharing options...
Lmeng69 1st Gear November 1, 2012 Share November 1, 2012 Was in rare situation just now... total of 3 AR lining up at the junction of Toh Guan Rd, waiting to turn right into Toh Guan East Rd. Front is me, behind me a maroon 159 SJS plate, behind it is a red 156 wagon (lagi rare sight). Link to post Share on other sites More sharing options...
Gorjiam 1st Gear November 1, 2012 Author Share November 1, 2012 my present car is not a 159, so the cooling system and other things are not the same as yours. it would react differently. Does your car come with an oil cooler stock? Just curious as my ex 3.2 Busso does... Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear November 1, 2012 Share November 1, 2012 Does your car come with an oil cooler stock? Just curious as my ex 3.2 Busso does... Yup..... by January 2013, it should be stock-er :) Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic November 1, 2012 Share November 1, 2012 checking in 1 Link to post Share on other sites More sharing options...
Desmojon 1st Gear November 1, 2012 Share November 1, 2012 ASR allows some wheel slip. not 0 wheel slip. I see.....That is why it is Anti-slip Reduction. It is to reduce the anti-slip function. Viva AR! Link to post Share on other sites More sharing options...
Iridiumx Clutched November 1, 2012 Share November 1, 2012 I see.....That is why it is Anti-slip Reduction. It is to reduce the anti-slip function. Viva AR! the correct term for ASR is actually Antislip Regulation Link to post Share on other sites More sharing options...
Theredstar 2nd Gear November 1, 2012 Share November 1, 2012 means more spectacular.. i.e. burn some tire.. make some smoke.. why manual will put such thing one? lol ↡ Advertisement Link to post Share on other sites More sharing options...
Sgcarmart's Community Telegram group is now live!
Soft drinks also wanna tax?
Jialat... Eat biscuit also can mati...
Autonomous Vehicles in Singapore
Thoughts on a car-lite Singapore as a car owner?
Nissan QashQai 2014 Part 2
