Zvicki Neutral Newbie December 14, 2014 Share December 14, 2014 Hi all, i am looking for your opinion. In recent regular maintenance, my engineer suggested me to change the front absorber and engine mounting which cost about 1.5K inlcuding labor. I can feel the problem while driving and it is getting a little worse in the past 6 months. Howver, I am not sure whether I shall chang them now since the car is due in 3 years and I probably will change another car. what would you do if in my situation? thanks. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Optramagnum 6th Gear December 14, 2014 Share December 14, 2014 Hello, Firstly I dun think absorber and mounting cost that much. If it really does, you divide $1500 by 3 years. Only $500 a year / $40 a month to have a more comfortable ride. Feel what your heart says. This method had served me well whenever I'm considering for any major repair, like you are now. 1 Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 14, 2014 Share December 14, 2014 do get a few quotations from other workshops although i am aware the spare parts of Honda are not cheap. if you are planning to stick with the current car for the next three years, i would think it is definitely more worthwhile to replace the parts now. 2 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged December 15, 2014 Share December 15, 2014 even u sell it b4 3yrs, at least u r doing next owner a favor, esp if u r selling by urself. but's that's me. 1 Link to post Share on other sites More sharing options...
Zvicki Neutral Newbie December 15, 2014 Author Share December 15, 2014 thank you guys for you advice. any reliable workshop to recommend? I am staying at CCK area.. 1 Link to post Share on other sites More sharing options...
Blueray Hypersonic December 15, 2014 Share December 15, 2014 changed engine mount (whole set) for my FD Civic last year at Autosaver Toh Guan, think around $800+ with AA discount. but have to give them time to order the parts. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 16, 2014 Share December 16, 2014 thank you guys for you advice. any reliable workshop to recommend? I am staying at CCK area.. you may want to consider AutoSaver or J's Garage. they are located at Toh Guan. give them a call to get a quotation first. if you want to save some money, buy the replacement parts from a Honda stockist yourself and pay a workshop to do the replacement. Civic FD is using Showa OEM shock absorbers. not sure about Stream. remember to go for wheel alignment if you are replacing the shock absorbers. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 16, 2014 Share December 16, 2014 changed engine mount (whole set) for my FD Civic last year at Autosaver Toh Guan, think around $800+ with AA discount. but have to give them time to order the parts. for Civic FD, how many pieces of mount are there in one full set? 3 or 4? Link to post Share on other sites More sharing options...
Zvicki Neutral Newbie December 16, 2014 Author Share December 16, 2014 thanks. changed engine mount (whole set) for my FD Civic last year at Autosaver Toh Guan, think around $800+ with AA discount. but have to give them time to order the parts. you may want to consider AutoSaver or J's Garage. they are located at Toh Guan. give them a call to get a quotation first. if you want to save some money, buy the replacement parts from a Honda stockist yourself and pay a workshop to do the replacement. Civic FD is using Showa OEM shock absorbers. not sure about Stream. remember to go for wheel alignment if you are replacing the shock absorbers. IC, thank you very much. Link to post Share on other sites More sharing options...
Blueray Hypersonic December 16, 2014 Share December 16, 2014 for Civic FD, how many pieces of mount are there in one full set? 3 or 4? er, not sure actually ... Link to post Share on other sites More sharing options...
Ichibawa 5th Gear December 17, 2014 Share December 17, 2014 buy your parts separately from stockist then go and ask quotes from workshops. You should be able to get everything done below 1K. 2 Link to post Share on other sites More sharing options...
Ricktyp Neutral Newbie December 19, 2014 Share December 19, 2014 Hi all, i am looking for your opinion. In recent regular maintenance, my engineer suggested me to change the front absorber and engine mounting which cost about 1.5K inlcuding labor. I can feel the problem while driving and it is getting a little worse in the past 6 months. Howver, I am not sure whether I shall chang them now since the car is due in 3 years and I probably will change another car. what would you do if in my situation? thanks. Mine was the RN3 stream. I managed to get the shock adsorber and the engine mounting changed about the same time period as you and all in all, costs me about 1.3K as well (I got the parts from Honda stockists) and go to a reliable workshop for changing. This was slightly more than 3 years back. If it needs to change, you have to. No choice. 2 Link to post Share on other sites More sharing options...
Zvicki Neutral Newbie December 22, 2014 Author Share December 22, 2014 Mine was the RN3 stream. I managed to get the shock adsorber and the engine mounting changed about the same time period as you and all in all, costs me about 1.3K as well (I got the parts from Honda stockists) and go to a reliable workshop for changing. This was slightly more than 3 years back. If it needs to change, you have to. No choice. thanks for advice Link to post Share on other sites More sharing options...
Kezg1 5th Gear December 23, 2014 Share December 23, 2014 thanks for advice ... at auto saver, they will also tell you to change the rubber buffer when you change your absorber...it will cost u too.. 1 Link to post Share on other sites More sharing options...
West7679 Neutral Newbie December 23, 2014 Share December 23, 2014 thank you guys for you advice. any reliable workshop to recommend? I am staying at CCK area.. Bro, can go to ACE motorsport. I recently went there to repair engine mounting. Cost of repair plus labor is $720. Opening hours 12pm to 12midnight. Look for Mr Lim. He will advise you on the repair. Address is No. 1 Soon Lee Street. #01-34, Pioneer Centre, Singapore 627605. Call 63343064. 2 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged December 23, 2014 Share December 23, 2014 ... at auto saver, they will also tell you to change the rubber buffer when you change your absorber...it will cost u too.. Shock mount u mean? Link to post Share on other sites More sharing options...
Kezg1 5th Gear December 23, 2014 Share December 23, 2014 Shock mount u mean? ..shock absorber..auto-saver advertised as promo but exclude gst and rubber buffer.. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged December 23, 2014 Share December 23, 2014 ..shock absorber..auto-saver advertised as promo but exclude gst and rubber buffer.. I chg 3 parts top to bottom order - shock / strut mount, rubber stopper n shock. I don't think shock mount n stopper easily cui, but just chg them out since they cost 2 n 5 x lesser than shocks. ↡ Advertisement Link to post Share on other sites More sharing options...
Car repair and maintenance
2025 Mitsuoka M55
2025 Mitsuoka M55
Ho Hup Seng......Some good info for our Brudders
