gasman 2nd Gear July 16, 2015 Share July 16, 2015 As above for discussion. Example - NX200 wheelbase is 2660mm, whilst Forrester 2.0 is 2640mm. But I "felt" the NX200 a bit tight as compared with the latter. Food for thought. ↡ Advertisement Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic July 16, 2015 Share July 16, 2015 Wheelbase is good for comfort But it doesnt mean much about space for rear passenger. 1 Link to post Share on other sites More sharing options...
Lucille 3rd Gear July 16, 2015 Share July 16, 2015 External dimension can be as big/width as it comes. If the interior design is crappy, then it will still be small/uncomfortable. 1 Link to post Share on other sites More sharing options...
Akula Turbocharged July 16, 2015 Share July 16, 2015 Other factors like the presence of the transmission tunnel along with the thickness of the seat cushion and length of the seat squab do play a part. The amount of boot space and the engine layout - either traversely or longitudinally affects as well. 2 Link to post Share on other sites More sharing options...
Tohto Hypersonic July 16, 2015 Share July 16, 2015 (edited) Other factors like the presence of the transmission tunnel along with the thickness of the seat cushion and length of the seat squab do play a part. The amount of boot space and the engine layout - either traversely or longitudinally affects as well. Front or rear wheel drive also affect a lot. A rear wheel drive will always have a much smaller rear space due to the transmission tunnel as you mention even the wheel base is same. Edited July 16, 2015 by Tohto 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 16, 2015 Share July 16, 2015 i would say Yes, wheelbase has a significant effect on rear passenger rear space. look at sunny and you know what i mean. Link to post Share on other sites More sharing options...
Kklim Supercharged July 16, 2015 Share July 16, 2015 The type of suspension used in the rear also affects the space in the back. Link to post Share on other sites More sharing options...
Tenghock 2nd Gear July 16, 2015 Share July 16, 2015 Longer wheelbase gives you more legroom. But taller cars would give you more headroom, so the feeling of spaciousness. Forester is some 105 mm taller. Link to post Share on other sites More sharing options...
flashbang Turbocharged July 16, 2015 Share July 16, 2015 Best is to go down in person to experience it yourself. No need to rely on the measurements, you're not buying a car online :) 1 Link to post Share on other sites More sharing options...
BobbyTan_74287 4th Gear July 16, 2015 Share July 16, 2015 Normally I buy car always based on the wheelbase and I will physically go and sit inside myself to make sure. Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged July 16, 2015 Share July 16, 2015 It all depends on how the cabin is designed. If the dashboard is very shallow, then expect the cabin to be spacious overall. Case in point: Nissan Latio and Sylphy. Shallow dashboards and they manage to use the space for rear leg room. 1 Link to post Share on other sites More sharing options...
Benarsenal Turbocharged July 16, 2015 Share July 16, 2015 It's just one of the factors for consideration. Other things include seat design, overall cabin design, whether got anything intrusive like transmission tunnel, suspension etc etc. Lots of stuff to consider also. Best is to just go and try for yourself and see whether comfortable or not. 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 16, 2015 Share July 16, 2015 It all depends on how the cabin is designed. If the dashboard is very shallow, then expect the cabin to be spacious overall. Case in point: Nissan Latio and Sylphy. Shallow dashboards and they manage to use the space for rear leg room. fully agree there. these two models may not have the most impressive wheelbase figures, but the rear leg space is impressive to say the least. the taller roof play a part too. 2 Link to post Share on other sites More sharing options...
Pinobii Hypersonic July 16, 2015 Share July 16, 2015 This is an interesting thread I haven't thought about wheelbase before during car purchase What i did was to sit myself in every seat and feel the leg space and comfort before deciding if that car matches up to what i think is needed 1 Link to post Share on other sites More sharing options...
Ivan_06 5th Gear July 17, 2015 Share July 17, 2015 (edited) External dimension can be as big/width as it comes. If the interior design is crappy, then it will still be small/uncomfortable. Just look at Mazda 3, wheelbase is long at 2700mm but rear legroom is worst than vios. Edited July 17, 2015 by Ivan_06 Link to post Share on other sites More sharing options...
Ishiwgao 3rd Gear July 17, 2015 Share July 17, 2015 As above for discussion. Example - NX200 wheelbase is 2660mm, whilst Forrester 2.0 is 2640mm. But I "felt" the NX200 a bit tight as compared with the latter. Food for thought. 20mm of difference in wheelbase is not going to make much of a difference in feeling tight. I believe it's more of the interior design that is giving that difference. Link to post Share on other sites More sharing options...
Zippaboy 4th Gear July 17, 2015 Share July 17, 2015 I was surprised by nissan slphy rear legroom space..spacious! I was ever more surprised by a Hummer...boy it is so tight inside. Link to post Share on other sites More sharing options...
Wt_know Supersonic July 17, 2015 Share July 17, 2015 (edited) toyota design always has the "best" legroom and space ... just take a look at camry vs accord/teana/etc and definitely much spacious than a6/e-class/5-series due to rear wheel drive 1pix is altis 2pix is camry just look at the reg legroom and space ... wow ! Just look at Mazda 3, wheelbase is long at 2700mm but rear legroom is worst than vios. Edited July 17, 2015 by Wt_know ↡ Advertisement 2 Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
2015 Forester 2.0
2015 Forester 2.0
Lexus Finally Figured Out The Three-Row SUV
The all new Lexus UX
2024 2nd Generation Lexus LM
Lexus Owners (To share driving experience and advise)
2023 Lexus RZ 450e
2023 Lexus RZ 450e
