Yeobt Supercharged December 14, 2016 Share December 14, 2016 guys, recently my car's check engine light turns On again. it happened few months ago and i got a mechanic who specialises honda car in ubi area to fix it for $280 in 5 mins. i guess i want to try and get it fix somewhere else to see if i could get it done one and for all without having to be a carrot. well, i'm driving an EK. when the engine light turns ON, sometimes it lost power on gear one. sometimes it works as fine. and sometimes, it goes back to normal after i restart engine. this problem has been a few days. today, it just doesn't turn Off after i tried to restart. all the good honda mec i know are located in the WEST, i wish not to travel that far to fix this. TIA ↡ Advertisement Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 14, 2016 Share December 14, 2016 guys, recently my car's check engine light turns On again. it happened few months ago and i got a mechanic who specialises honda car in ubi area to fix it for $280 in 5 mins. i guess i want to try and get it fix somewhere else to see if i could get it done one and for all without having to be a carrot. well, i'm driving an EK. when the engine light turns ON, sometimes it lost power on gear one. sometimes it works as fine. and sometimes, it goes back to normal after i restart engine. this problem has been a few days. today, it just doesn't turn Off after i tried to restart. all the good honda mec i know are located in the WEST, i wish not to travel that far to fix this. TIA since you spent $280 for a 5 min job a few months ago,you should go back and tell the mechanic the recurrence of the problem and ask if he could do the same fix FOC . It is important to understand what fix did he do previously. If he will to charge you another $280, then you have an option to look for other mechanics. Link to post Share on other sites More sharing options...
Shibadog Turbocharged December 14, 2016 Share December 14, 2016 what's the error code? Link to post Share on other sites More sharing options...
Watwheels Supersonic December 14, 2016 Share December 14, 2016 Like that also call good? I think your mechanic just plug in the obd device and clear the check engine light. He did not resolve the real issue at all. That's why the CEL will always come back. Wah, really? $280? You really kumgong. $280 can buy yourself a good obd device to read fault code, you know....ownself check ownself? Somemore you can say the mechanic is good. I salute you. You need to find out what exactly is the error code to resolve the issue in your car. Turning off and on ignition doesn't make the CEL go away. Don't be silly. If I'm not wrong possible issues are one of your air sensors or catalytic converter got issue. If not will be spark plugs or the seals around the spark plug need to replace. Other possible stuff might be the fuel pump. The error code will have the specific notification to determine the main cause. Stop going back to that workshop of yours. Link to post Share on other sites More sharing options...
Yeobt Supercharged December 14, 2016 Author Share December 14, 2016 Like that also call good? I think your mechanic just plug in the obd device and clear the check engine light. He did not resolve the real issue at all. That's why the CEL will always come back. Wah, really? $280? You really kumgong. $280 can buy yourself a good obd device to read fault code, you know....ownself check ownself? Somemore you can say the mechanic is good. I salute you. You need to find out what exactly is the error code to resolve the issue in your car. Turning off and on ignition doesn't make the CEL go away. Don't be silly. If I'm not wrong possible issues are one of your air sensors or catalytic converter got issue. If not will be spark plugs or the seals around the spark plug need to replace. Other possible stuff might be the fuel pump. The error code will have the specific notification to determine the main cause. Stop going back to that workshop of yours. any good mech that can check and fix this? what's the error code? i only saw him going under where the pedals are. he look so secretive and quickly fix it before i can go near to see. sigh...didn't feel like going back... Link to post Share on other sites More sharing options...
Watwheels Supersonic December 14, 2016 Share December 14, 2016 any good mech that can check and fix this? i only saw him going under where the pedals are. he look so secretive and quickly fix it before i can go near to see. sigh...didn't feel like going back... I only know of Ubi area. Block 3007 should be Ubi road 1. I forgot the shop's name. You turn left into Ubi road 1 after the famous car sticker shop. You will be able to see a couple of car workshops that do old honda cars. Gotto ask around. I long time no go there. Link to post Share on other sites More sharing options...
Shibadog Turbocharged December 14, 2016 Share December 14, 2016 any good mech that can check and fix this? i only saw him going under where the pedals are. he look so secretive and quickly fix it before i can go near to see. sigh...didn't feel like going back... like that ah..... maybe go back bang table (if sure its the same issue) but don't pay any more. But I think better to go to a better workshop that is willing to explain the issue to u. Link to post Share on other sites More sharing options...
Watwheels Supersonic December 14, 2016 Share December 14, 2016 You just need to locate the obd plug-in. Use a obd scan tool to get the error code. Google together with your car's make and year you will be able to find out the fault. Your old car obd I dunno what it looks like. Got "A,B ,C D". Modern cars are simple. Looks like this. OBD device or scan tool. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic December 14, 2016 Share December 14, 2016 guys, recently my car's check engine light turns On again. it happened few months ago and i got a mechanic who specialises honda car in ubi area to fix it for $280 in 5 mins. i guess i want to try and get it fix somewhere else to see if i could get it done one and for all without having to be a carrot. well, i'm driving an EK. when the engine light turns ON, sometimes it lost power on gear one. sometimes it works as fine. and sometimes, it goes back to normal after i restart engine. this problem has been a few days. today, it just doesn't turn Off after i tried to restart. all the good honda mec i know are located in the WEST, i wish not to travel that far to fix this. TIA Let me make a guess. EG/EK those era cars I think they like to tinker with the exhaust. Modified original, remove cat converter, There are two o2 sensors. One upstream near the exhaust and the other downstream, after the cat converter. Since the cat converter can be missing, the two o2 sensor reads the same, and this triggers CEL. The upstream o2 sensor is more important as It controls fueling and power. The trick to disable CEL due to missing cat converter is to change the signal. Some mech put spacer on the lower o2 sensor, some add capacitors/resistors to the signal. Sometimes it work, sometimes it doesn't. So your CEL will come on and go off. If your engine has other problem due to misfiring, it will also affect power output. And also light up CEL. The first thing to do is to check the code of the CEL, then you can work from there. 1 Link to post Share on other sites More sharing options...
Kurty Supercharged December 15, 2016 Share December 15, 2016 is it your air flow sensor (MAF) dying? $280 for 5 mins job, that's a rip off.. go jb and repair. anyway, nice car. love the series Link to post Share on other sites More sharing options...
Yeobt Supercharged December 15, 2016 Author Share December 15, 2016 Journey to the west to meet another Honda specialist now. Link to post Share on other sites More sharing options...
Freeder Hypersonic December 15, 2016 Share December 15, 2016 Most probably is the O2 sensor up lorry..Honda cars always prone to this problem..Or ur catalytic converter Kanna too much carbon?need to take out n de carbonized using some special acid wash..how I know? Coz I Kanna before 6 Link to post Share on other sites More sharing options...
Karoon Turbocharged December 15, 2016 Share December 15, 2016 my car also now has a permanent engine light on sign. Its 9 years old. Trusted mechanic ran diagnostic and can only suggest spurious electronic signal. No effect on performance, in fact drove to KL last weekend. Proposed permanent solution: Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear December 16, 2016 Share December 16, 2016 (edited) Poor thing to be con like that. I think they only clear your DTC lor ..... Drive 2 standard cycles and see if it clear by itself lor. Standard Cycle - Cold Start -> 65km/h for 10mins -> Stop -> Off. or you should buy this : https://www.aliexpress.com/item/VIECAR-Super-MINI-Bluetooth-ELM327-V2-1-OBD2-ELM-327-OBDII-for-Android-Torque-Car-Code/32765288301.html?spm=2114.01010208.3.3.FBGH2Z&ws_ab_test=searchweb0_0,searchweb201602_4_10065_10068_10084_10083_10080_10082_10081_10060_10061_10062_10056_10055_10054_10059_10099_10078_10079_427_10073_10103_10102_10096_10052_10050_10051,searchweb201603_9&btsid=4bead1d2-e638-44fc-925b-31c00f05ef30 US2.80 only. Use android phone to load this app called Torque. Read DTC Both Pending and Confirmed Code. Clear DTC. guys, recently my car's check engine light turns On again. it happened few months ago and i got a mechanic who specialises honda car in ubi area to fix it for $280 in 5 mins. i guess i want to try and get it fix somewhere else to see if i could get it done one and for all without having to be a carrot. well, i'm driving an EK. when the engine light turns ON, sometimes it lost power on gear one. sometimes it works as fine. and sometimes, it goes back to normal after i restart engine. this problem has been a few days. today, it just doesn't turn Off after i tried to restart. all the good honda mec i know are located in the WEST, i wish not to travel that far to fix this. TIA Edited December 16, 2016 by Apple-Tree Link to post Share on other sites More sharing options...
Yeobt Supercharged December 16, 2016 Author Share December 16, 2016 thank you all for the valuable advice. went to a reputable ws in the west yesterday, got it check, he touch touch and the check light gone. FREE. Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 16, 2016 Share December 16, 2016 thank you all for the valuable advice. went to a reputable ws in the west yesterday, got it check, he touch touch and the check light gone. FREE. Even if it is free, you should ask the mechanic what was the error. At times the mechanic may just clear the error to see if a problem would recur. Basing on your case , the error may come back again. Link to post Share on other sites More sharing options...
Yeobt Supercharged December 17, 2016 Author Share December 17, 2016 Even if it is free, you should ask the mechanic what was the error. At times the mechanic may just clear the error to see if a problem would recur. Basing on your case , the error may come back again. he said its the intake sensor and exhaust temp sensor that need attention. will replace them if the check light turns on again. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 17, 2016 Share December 17, 2016 he said its the intake sensor and exhaust temp sensor that need attention. will replace them if the check light turns on again. if the CEL is lit again, you might want to look for the good Honda doctor at SKM Auto in the east. ↡ Advertisement Link to post Share on other sites More sharing options...
KIA K3 Owners check-in!
2025 Mitsuoka M55
2025 Mitsuoka M55
