Suhaimiebrahim 1st Gear August 1, 2017 Share August 1, 2017 Hi bro, Driving at above 50k/hr, low note humming sound can be heard from the engine. This happen recently. Car is Camry about 10 yrs. Any one ever experience this issue. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
BenTong Turbocharged August 2, 2017 Share August 2, 2017 go workshop.. or if not go car showroom 6 Link to post Share on other sites More sharing options...
Xtrah 3rd Gear August 2, 2017 Share August 2, 2017 Hi bro, Driving at above 50k/hr, low note humming sound can be heard from the engine. This happen recently. Car is Camry about 10 yrs. Any one ever experience this issue. Thanks. Are you sure the noise is from the engine? If you are not moving, it does not have the noise? Then its not the engine problem. Try to switch of the air-con and hear the difference. The other possibility is the drive shaft problem or the wheel bearing problem. If turning left or right gives different level of noises, then it more likely wheel bearing problem. Link to post Share on other sites More sharing options...
Rayoflight 5th Gear August 2, 2017 Share August 2, 2017 Check Tyres, or Wheel Bearings. 3 Link to post Share on other sites More sharing options...
Suhaimiebrahim 1st Gear August 2, 2017 Author Share August 2, 2017 Are you sure the noise is from the engine? If you are not moving, it does not have the noise? Then its not the engine problem. Try to switch of the air-con and hear the difference. The other possibility is the drive shaft problem or the wheel bearing problem. If turning left or right gives different level of noises, then it more likely wheel bearing problem. Link to post Share on other sites More sharing options...
Suhaimiebrahim 1st Gear August 2, 2017 Author Share August 2, 2017 Hi bro, Sound not audible with engine running with car in stationary condition. Turning right or left seems no effect only when cruising above 50 kph. Link to post Share on other sites More sharing options...
Xtrah 3rd Gear August 2, 2017 Share August 2, 2017 Hi bro, Sound not audible with engine running with car in stationary condition. Turning right or left seems no effect only when cruising above 50 kph. When you turn left / right above 50km/h (those expressway bend), does the noise get louder? I suspect its more likely the wheel bearing since its a wear and tear part. You just need to pin point it is the left or right front wheel bearing. Do note the noise will get louder when your mileage increase. You fuel consumption will be affected due to wheel bearing causes drag. 1 Link to post Share on other sites More sharing options...
UncleAtas Turbocharged August 2, 2017 Share August 2, 2017 Is the humming loud? Else, just turn up the music volume. Link to post Share on other sites More sharing options...
Mits_jc 5th Gear August 4, 2017 Share August 4, 2017 (edited) sounds like a wheel bearing issue go to one of the workshop here that gives u FOC diagnostic the last time they jacked up my car (suspected coming from the rear), spin the wheel ask me to hold onto the suspension shocks while the wheel was free-spinning the side of the affected wheel bearing, can feel vibration from the shocks while the wheel was spinning changed the wheel bearing on the affected side, problem solved. Hi bro, Driving at above 50k/hr, low note humming sound can be heard from the engine. This happen recently. Car is Camry about 10 yrs. Any one ever experience this issue. Thanks. Edited August 4, 2017 by Mits_jc 2 Link to post Share on other sites More sharing options...
Suhaimiebrahim 1st Gear August 4, 2017 Author Share August 4, 2017 Thanks Mits_jc, If indeed the wheel bearing is the problem, what is the replacement cost? Thinking to visit the work shop soon. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged August 4, 2017 Share August 4, 2017 Thanks Mits_jc, If indeed the wheel bearing is the problem, what is the replacement cost? Thinking to visit the work shop soon. Normally 2 to 300 region. If you are keeping the car for long, I suggest to change all four. Also, I need to do alignment after replacement. Technically it is not needed but somehow, the technicians managed to knock it out of alignment. Link to post Share on other sites More sharing options...
Mits_jc 5th Gear August 4, 2017 Share August 4, 2017 wheel bearing most likely the workshop will carrot u ask u pay $300, which u can pay to save the trouble, cos they will cover the parts and labor otherwise to save money, u can do some homework, go buy the affected part from stockist outside. OEM should be around $70, original prob $90-100 (for my case) Labour wise can get a workshop to help u replace, straight forward job shouldn't take more than 1h.I got mine done in msia for RM50 (labour) Thanks Mits_jc, If indeed the wheel bearing is the problem, what is the replacement cost? Thinking to visit the work shop soon. Link to post Share on other sites More sharing options...
Suhaimiebrahim 1st Gear September 4, 2017 Author Share September 4, 2017 Hi guys, Thank s for all your advise. It's the rear wheel bearing that having trouble. Replacement done and all is back to normal. 2 Link to post Share on other sites More sharing options...
Wavvyykaa October 24, 2017 Share October 24, 2017 Hi Need help There is this roaring sound from engine compartment when car move off from stationary sounded very rough. Normally about 2000rpm onwards. When ok highway which rpm is normally below 2000 there is not significant sound. This roaring sound will sometimes disappear and it will be smooth like baby but most of time it is around. Abit like modified exhaust sound but my car is stock. When in neutral and accelerate there is no sound thus engine should be fine and exhaust not leaking. Honda vezel 2015, 60k mileage Link to post Share on other sites More sharing options...
GravityBlue 4th Gear June 28, 2019 Share June 28, 2019 Hi Need help There is this roaring sound from engine compartment when car move off from stationary sounded very rough. Normally about 2000rpm onwards. When ok highway which rpm is normally below 2000 there is not significant sound. This roaring sound will sometimes disappear and it will be smooth like baby but most of time it is around. Abit like modified exhaust sound but my car is stock. When in neutral and accelerate there is no sound thus engine should be fine and exhaust not leaking. Honda vezel 2015, 60k mileage Let me guess , aircon compressor bearing noise. Link to post Share on other sites More sharing options...
Inlinefour Twincharged June 28, 2019 Share June 28, 2019 Let me guess , aircon compressor bearing noise. my aircon also got bird noise like that Link to post Share on other sites More sharing options...
13177 Supersonic June 28, 2019 Share June 28, 2019 my aircon also got bird noise like that There is a bird inside your aircon? Link to post Share on other sites More sharing options...
Inlinefour Twincharged June 28, 2019 Share June 28, 2019 There is a bird inside your aircon? ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
[Official] 2024 Lexus LBX
All BMW owner thread
Toyota Corolla Cross
