AndyHo 1st Gear February 6, 2019 Share February 6, 2019 anyone installed DTE pedalbox? any feedback? just want to remove the lag between acceleration. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear February 6, 2019 Share February 6, 2019 (edited) anyone installed DTE pedalbox? any feedback? just want to remove the lag between acceleration. basically this device is installed at your acceleration sensor there to widen the signal. So that the padal when depress have better response as compared to stock. seen good reviews about it. but didnt install it. alternate brands eg: pivot i think also have similar ones like the DTE. Edited February 6, 2019 by StreamRSZ Link to post Share on other sites More sharing options...
UncleAtas Turbocharged February 6, 2019 Share February 6, 2019 (edited) Ok lah. Helps abit. Im still looking for that instance response. Nothing beats a litre bike. Edited February 6, 2019 by UncleAtas Link to post Share on other sites More sharing options...
Lmws214 Turbocharged February 6, 2019 Share February 6, 2019 any website link to read about this gadget? anyone installed DTE pedalbox? any feedback? just want to remove the lag between acceleration. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear February 6, 2019 Share February 6, 2019 any website link to read about this gadget? can do a google la. Link to post Share on other sites More sharing options...
Lmws214 Turbocharged February 6, 2019 Share February 6, 2019 local installer? can do a google la. Link to post Share on other sites More sharing options...
AndyHo 1st Gear February 6, 2019 Author Share February 6, 2019 local installer?Yes vtec auto at ubi. Still considering... quite sure it affects fc after installed. Anyone installed can share the fc consumption? Link to post Share on other sites More sharing options...
AndyHo 1st Gear February 6, 2019 Author Share February 6, 2019 any website link to read about this gadget?Nothing new lah... alot of e throttle controllers in the market. I think most popular one is sprint booster.all performing the same thing.. Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 6, 2019 Share February 6, 2019 Before install= 1000bhp After install= 1000bhp So why install. 2 Link to post Share on other sites More sharing options...
Eyke Supercharged February 6, 2019 Share February 6, 2019 want instant response, get electric car 1 Link to post Share on other sites More sharing options...
Lmws214 Turbocharged February 6, 2019 Share February 6, 2019 thanks for sharing. Before install= 1000bhpAfter install= 1000bhpSo why install. Link to post Share on other sites More sharing options...
Ishiwgao 3rd Gear February 7, 2019 Share February 7, 2019 Yes vtec auto at ubi. Still considering... quite sure it affects fc after installed. Anyone installed can share the fc consumption? The gadget itself doesn't affect fc. All it does is to tell the engine to put more throttle (e.g. 70%) when your pedal is slightly depressed (e.g. 20%) instead of a linear setting. I'm sure you know this So in the end, the fc is just dependent on the acceleration of the car. In your stock car, you depress 70%, you get shiok acceleration and not-so-good fc. With this DTE pedal box, you depress 20%, you get 70% shiok acceleration, you will still get the same not-so-good fc. Only difference is you don't need to press so much, so you feel that the response is better. No such thing as more acceleration but same fc. 3 Link to post Share on other sites More sharing options...
AndyHo 1st Gear February 7, 2019 Author Share February 7, 2019 The gadget itself doesn't affect fc. All it does is to tell the engine to put more throttle (e.g. 70%) when your pedal is slightly depressed (e.g. 20%) instead of a linear setting. I'm sure you know this So in the end, the fc is just dependent on the acceleration of the car. In your stock car, you depress 70%, you get shiok acceleration and not-so-good fc. With this DTE pedal box, you depress 20%, you get 70% shiok acceleration, you will still get the same not-so-good fc. Only difference is you don't need to press so much, so you feel that the response is better. No such thing as more acceleration but same fc. Which means every time i step on acc, throttle open 70% .. same as heavy footstep... i still think will impact fc. Before install= 1000bhp After install= 1000bhp So why install. Install to get rid of the lag. E.g. for normal car, if you slow down to 40-50km at highway and once traffic clear, it will take a while before you reach 90km again even if you foot down to the floor. E throttle will remove this lag in between. Yes it doesnt increase power or make your car goes faster. Link to post Share on other sites More sharing options...
Eyke Supercharged February 7, 2019 Share February 7, 2019 (edited) Install to get rid of the lag. E.g. for normal car, if you slow down to 40-50km at highway and once traffic clear, it will take a while before you reach 90km again even if you foot down to the floor. E throttle will remove this lag in between. Yes it doesnt increase power or make your car goes faster. in this case, e-throttle won't do jackshit; how can e-throttle do better/more than flooring it? try downshift to get revs up into engine's power band faster instead. Edited February 7, 2019 by Eyke Link to post Share on other sites More sharing options...
Columbian78 6th Gear February 7, 2019 Share February 7, 2019 Helps to compensate for foot lag. Works as claimed. I installed something similar from racechip. Found that my foot speed was not the issue. I sold it away. 1 Link to post Share on other sites More sharing options...
Soya Supersonic February 7, 2019 Share February 7, 2019 Used both DTE & Sprint Booster b4. They work alright. Throttle response is slightly sharper and little less lag makes the daily urban stop-go drives a little more tolerable. Not expensive and my warranties were not affected. Think of it as an amp for the stereo. Some can also say can use fingers to turn up volume, no need amp. Some oso say step pedal harder same effect. But when i last checked, my fren mr.google say electronic signals move faster than leg muscles wor.... Link to post Share on other sites More sharing options...
Ishiwgao 3rd Gear February 7, 2019 Share February 7, 2019 Which means every time i step on acc, throttle open 70% .. same as heavy footstep... i still think will impact fc. Install to get rid of the lag. E.g. for normal car, if you slow down to 40-50km at highway and once traffic clear, it will take a while before you reach 90km again even if you foot down to the floor. E throttle will remove this lag in between. Yes it doesnt increase power or make your car goes faster. I think you are misunderstanding what this DTE throttle box will do. It will not remove the lag when you accelerate from 50km/h to 90km/h. that is your car's engine performance, and DTE throttle will not affect acceleration rate. It will remove the lag from when you step on the throttle to when your car starts to accelerate strongly. but the acceleration after you step on throttle is the same with or without DTE throttle box. Yes, everytime you step on acc, throttle open more, same as heavy footstep, so increase fc. that is exactly what the DTE throttle is doing. Link to post Share on other sites More sharing options...
AndyHo 1st Gear February 7, 2019 Author Share February 7, 2019 Bro, u installed before? Confirm doesnt remove lag from e.g 50km to 90km? If this is the cae no point install. Any other bro installed similar throttle controller, can confirm on this? I think you are misunderstanding what this DTE throttle box will do. It will not remove the lag when you accelerate from 50km/h to 90km/h. that is your car's engine performance, and DTE throttle will not affect acceleration rate. It will remove the lag from when you step on the throttle to when your car starts to accelerate strongly. but the acceleration after you step on throttle is the same with or without DTE throttle box. Yes, everytime you step on acc, throttle open more, same as heavy footstep, so increase fc. that is exactly what the DTE throttle is doing. ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Toyota Corolla Cross
Toyota Land Cruiser Mini
