dragonballdidi 2nd Gear March 20, 2019 Share March 20, 2019 https://www.youtube.com/watch?v=y12f7NxFgkw The Ferrari 488 GTB says so long this year to make room for its successor, the F8 Tributo. In a pair of new videos, fans of the Prancing Horse can be acclimated with some of the changes made to the supercar before it hits the streets. Up first, performance. The engine is still a traditional V-8 ridden by a pair of turbochargers. The F8 Tributo has the highest-output Ferrari V-8 ever with 710 horsepower on tap. It will take just 2.9 seconds to go from 0-62 mph and the top speed sits at 211 mph. Even better, the F8 Tributo is lighter compared to the 488 by some 88 pounds. The weight savings come from the engine itself, a Lexan rear windshield, and a carbon-fiber rear spoiler. Ferrari also highlighted the "Ferrari Dynamic Enhancer+" system that adjusts brake pressure at each caliper to control the F8 Tributo's svelte body better. The system should help drivers more easily unlock the car's performance. There's also a smaller-diameter steering wheel inside for a sportier feeling. Moving onto aerodynamics, the Tributo separates further from the 488. Foremost, the front air duct comes from the company's Formula One learnings and helps to cut through air and keep the car slippery. At the rear, the wider spoiler creates greater vertical load. Rear flux deflectors reduce drag. Taking a look underneath the car reveals a nearly flat underbody that works with the front diffuser to channel more cool air into the brakes. The rear diffuser also houses active aero elements to help boost performance when needed around a corner, or in a straight line. Back up front, new radiators from the 488 Challenge improve cooling while further reducing drag and a new air intake design helps ensure cooler air is fed to the engine to complement the car's power increase to 710 hp. Overall, the F8 Tributo is 10 percent more aerodynamic than the 488 GTB. Not to mention, it looks quite good too. Check it out in the videos above. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Itay Auto-Otaku
Itay Auto-Otaku
2023 Ferrari Purosangue SUV
Ferrari Portofino, and gone is the California
Ferrari Roma 3.9L twin-turbo V8
Steven Lim wanna buy used Ferrari or used car with $78K in his bank
Which richman's garage is this?!
Ferrari Is Recalling Nearly Every Car It's Sold Since 2005
Paddle shifters - fixed to wheel or column?
