Guyver 1st Gear February 2, 2003 Share February 2, 2003 Hi Jagash, 1. Yes, priority on my list. Also my worry. Dun wanna spend money again. 2. Steering free play should be okay. The car is new! 3. Electric power steering. 4. Pressure and balancing okay. No high speed vibes, no jittery teeth. 5. Alignment should be okay I suppose... Thanks! Looks like money gonna be gone liow... I don't know exactly.. but do check whether is all your tyres ok... see whether got any punctured one.. which u didn't notice.... i experienced similar thing.. and it's bec. of punctured tyres... just my 2 cents.. hope it helps... ↡ Advertisement Link to post Share on other sites More sharing options...
Silver_z 1st Gear August 18, 2003 Share August 18, 2003 Use to have such prob in my previous ride. Shock has a leak. Test by pressing car down to test for stiffness on all four corners. It should be the same. A spoilt shock will result in a soft suspension(softer than other 3 corner). Link to post Share on other sites More sharing options...
Mmythos Neutral Newbie October 23, 2003 Share October 23, 2003 why not i bring ur metallic babe out for a ride with u to know better? hahaha.... Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 15, 2004 Share January 15, 2004 All the syptoms seems to point to only 1 thing time to change car Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 17, 2004 Share January 17, 2004 Looks like a wheel camber problem but not possible for a new car unless one of the front wheel hits a road porthole or side curb. If it is a camber problem, within the next few weeks you should be able to detect some abnormal wear patterns on the tyre(s). Alternatively, you can go for a side slip test ( tyre scuffing test ).If the result shows the car is pulling either towards the right or left side , it indicates your front wheels may have a camber or camber & toe problem. Link to post Share on other sites More sharing options...
Jagash Neutral Newbie January 17, 2004 Share January 17, 2004 Our friend had the probem with his car 1 year ago (2003) I think the problem should have already been resolved by now! Cheers! Link to post Share on other sites More sharing options...
Ivtecody Neutral Newbie January 24, 2006 Share January 24, 2006 So can I know what is the actual problem as I am facing a similar problem here. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged January 24, 2006 Share January 24, 2006 Most likely suspension wear and tear judging from the way you drive.......Agree. I second that. Link to post Share on other sites More sharing options...
Sqkam Neutral Newbie April 2, 2006 Share April 2, 2006 I am having the same problem with my ride too. Can share how the problem was resolved? Link to post Share on other sites More sharing options...
Ae101 Neutral Newbie January 18, 2007 Share January 18, 2007 ai yoh very simple...change away your absorber .... Link to post Share on other sites More sharing options...
Mooscenic 1st Gear January 18, 2007 Share January 18, 2007 Sounds like a lemon to me... What's wrong with going back to BM to get it checked and yo feedback, since you're harping so much on having to fork up money to replace the parts? In any case, if the car is new and it's within the warranty period, you as the customer has every right to get it checked and things replaced FOC. No point being scared just because you "think" about this and that... Unless of cause you have some hidden issues (Maybe you'd modified the car) and does not/cannot/dare not let BM know about. Ultimately, you should decide whether to exercise your right to use the warranty or just pay money and let it go to waste. The choice is yours. Moooooooooooooooo Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 18, 2007 Share January 18, 2007 If your tyres r properly inflated, then it seems your shocks r worn or just got a leak. Check them first & try to change then asap. Get the OEM by KYB. Look for the made in Japan shocks as they r more lasting. Link to post Share on other sites More sharing options...
Clubace Clutched January 18, 2007 Share January 18, 2007 Hello pple! This is a 3yr old thread. The owner had changed his car. Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 18, 2007 Share January 18, 2007 Hahaha. So someone dig it out & didn't notice the original posting date. Anyway some other kakis also having same problem. Maybe they wil find the replies helpful. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Old WW2 Relic disposals
