Longg8 Clutched May 31, 2006 Share May 31, 2006 my right headlamp bulb is blown.... the socket its H4...but it cant be sloted into the headlamp.. mine is 05 liteace...i think the bulb, i nid to change the filament inside...cos its like a joint together thing (the pin of the original bulb is welded on to the lamp assembly)..den i supposed i have to remove the whole headlamp assembly to change 1 headlamp bulb? its very hard to visualise by reading those...i know..anyone driving a liteace? if yes..anyone know where to change those bulb at a cheap price? can use can liao... ↡ Advertisement Link to post Share on other sites More sharing options...
Megalord Neutral Newbie May 31, 2006 Share May 31, 2006 (edited) It has been more than a few years since i last look at the liteace, but i do know that for toyota dyna, they change the whole headlamp assembly when the bulb is blown. The headlamp is sealed for that pickup, but the replacement is cheap anyway. Hope this info is of help. Edited May 31, 2006 by Megalord Link to post Share on other sites More sharing options...
Longg8 Clutched May 31, 2006 Author Share May 31, 2006 i see....haiz...wat a lousy design........cheap? whole headlite assy is cheap? hmmm..dunno..tmr go down ask... thanks aniway Link to post Share on other sites More sharing options...
Megalord Neutral Newbie May 31, 2006 Share May 31, 2006 I may be wrong for the liteace, as i simply can't visualise how it looks like since i have stopped getting toyota diesels a few years back. The dyna back then uses 4 headlamp, and from the other megalord that service them, he mentioned its only secured by a few screws, and the replacement assembly he got is something like 10+ SGD for a new one. But i believe it may be far fetched to link the dyna to the liteace. Diff models afterall. Link to post Share on other sites More sharing options...
Longg8 Clutched May 31, 2006 Author Share May 31, 2006 i think its about the same...haiz..muz go scout ard 1st..heng liteace quite common..most places should haf..cant believe it...changing 1 bulb so ma fan... changing a bulb for my bike is like 5 min work onli ....-_-'' Link to post Share on other sites More sharing options...
Mobile1 1st Gear May 31, 2006 Share May 31, 2006 The headlight for LA is a consealed type. What you got to do is to change the whole headlight assembly to that which allows you to change the bulbs. I got mine at LianSong in Horne Rd. I hope this helps. The assembly will cost you $70 a pair. The bulb will probably cost another ~$20 depending on the bulb you take. Link to post Share on other sites More sharing options...
York Clutched May 31, 2006 Share May 31, 2006 (edited) my right headlamp bulb is blown.... the socket its H4...but it cant be sloted into the headlamp.. mine is 05 liteace...i think the bulb, i nid to change the filament inside...cos its like a joint together thing (the pin of the original bulb is welded on to the lamp assembly)..den i supposed i have to remove the whole headlamp assembly to change 1 headlamp bulb? its very hard to visualise by reading those...i know..anyone driving a liteace? if yes..anyone know where to change those bulb at a cheap price? can use can liao... I oso ride a L.A 2005..got to replace the whole headlight...unless u wanna mod it...by cutting..(not worth)....after all chiong nippon ones...less than 20 bux nia... perhaps, u can dropby @ tis vannin community to get more info http://www.dreamzvannin.net/phpBB2/index.php Edited May 31, 2006 by York Link to post Share on other sites More sharing options...
Fire76 Neutral Newbie May 31, 2006 Share May 31, 2006 Wa pau morning Uncle york, so early... ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Toyota Corolla Cross
Toyota Land Cruiser Mini
