Ben50 Neutral Newbie June 5, 2006 Share June 5, 2006 I'm driving a Pinic. Presently, at 78500km. For the last 2 weeks, when I stopped at traffic junctions, the engine vibrated at idle on drive mode. What is the problems? ↡ Advertisement Link to post Share on other sites More sharing options...
Coupe07 Neutral Newbie June 5, 2006 Share June 5, 2006 should be time to change ur engine mount...... Link to post Share on other sites More sharing options...
Carmaniac Neutral Newbie June 5, 2006 Share June 5, 2006 are you sure it is your engine that is vibrating? My father currently drives a lancer glxi and his car's dashboards vibrates whenever he stops his car. Some times the brakes sort of vibrates when he steps on the brake. But luckily he is about to change car liao Link to post Share on other sites More sharing options...
Carmaniac Neutral Newbie June 5, 2006 Share June 5, 2006 you can bring your car back to BM to have a checkup too Link to post Share on other sites More sharing options...
Zoom99 Neutral Newbie June 5, 2006 Share June 5, 2006 Possible defective 1)Mounting 2)ECU defect If yr car is less than 3 yr,it is better to send for check at BM. Link to post Share on other sites More sharing options...
Ben50 Neutral Newbie June 5, 2006 Author Share June 5, 2006 Yes....Good idea to let BM check my car. It's about time to service my car....80K liao. Link to post Share on other sites More sharing options...
Ben50 Neutral Newbie June 5, 2006 Author Share June 5, 2006 Bro, what is ECU? Link to post Share on other sites More sharing options...
Jasonllh Neutral Newbie June 5, 2006 Share June 5, 2006 got to make sure if it is really the engine vibrating cos for my case i found out it was my faulty aircon compresssor causing the vibes. turn on and off your aircon to determine. otherwise, it could sometimes be a lengthy affair trying to determine the cause. Link to post Share on other sites More sharing options...
Coupe07 Neutral Newbie June 5, 2006 Share June 5, 2006 are you sure it is your engine that is vibrating? My father currently drives a lancer glxi and his car's dashboards vibrates whenever he stops his car. Some times the brakes sort of vibrates when he steps on the brake. But luckily he is about to change car liao this is also most likely engine mount... Link to post Share on other sites More sharing options...
Sky8807 1st Gear June 5, 2006 Share June 5, 2006 I'm driving a Pinic. Presently, at 78500km. For the last 2 weeks, when I stopped at traffic junctions, the engine vibrated at idle on drive mode. What is the problems? How is the condition of your battery and the capacity. Though it may be remote but a possibility Link to post Share on other sites More sharing options...
Ben50 Neutral Newbie June 5, 2006 Author Share June 5, 2006 The battery is Ok. Just replaced less than 6 months ago. Link to post Share on other sites More sharing options...
Zoom99 Neutral Newbie June 5, 2006 Share June 5, 2006 The electronic control board that controls the fuel injection, idling mode and etc. For this portion, defintely BM is the expert. FYI: My friend encounter the same issue until BM replace the ECU. Link to post Share on other sites More sharing options...
Sky8807 1st Gear June 5, 2006 Share June 5, 2006 If battery is okay. but it's better to check at any battery shop for condition, its free, only a loading test and to see the charge of the battery. Then maybe its the petrol u pump lately. Try filling up a higher grade next round to see if it improve or disappear. Don't think anything serious. Link to post Share on other sites More sharing options...
Wolverlander Neutral Newbie June 5, 2006 Share June 5, 2006 I do agree ...engine mount once deteriorate due to weather will cause that to happen .... Link to post Share on other sites More sharing options...
Coupe07 Neutral Newbie June 5, 2006 Share June 5, 2006 go to ur favourite workshop, ask them to use a jack and jack up til it touches ur engine. Then u sit in ur car and feel. If it doesnt move or shake, then confirm its ur engine mount. Link to post Share on other sites More sharing options...
Ben50 Neutral Newbie June 7, 2006 Author Share June 7, 2006 I'm driving a Pinic. Presently, at 78500km. For the last 2 weeks, when I stopped at traffic junctions, the engine vibrated at idle on drive mode. What is the problem? Hi Bros, BM have found the following problems: Belt tensioner faulty....to be replaced....under warranty. ISC valve faulty....to be replaced....under warranty. Thottle body assembly dirty....recommend overhaul. My Pinic is now in good running condition. Thank you for all your inputs. Link to post Share on other sites More sharing options...
Gary84 1st Gear June 8, 2006 Share June 8, 2006 bro, since mileage still less than 100,000km then better go BM and haf the rpob rectify...unless u tell me ur car more than 3y.o liao...then bo bian lor.. Link to post Share on other sites More sharing options...
Gary84 1st Gear June 8, 2006 Share June 8, 2006 u are lucky...belt tensioner if i remembered correctly is quite exp...anyway good to hear tat ur car is fine liao...enjoy and cheers! ↡ Advertisement Link to post Share on other sites More sharing options...
Cars We Don't Get to Drive in Singapore
Driving in Europe
Driving in Europe
Malaysia: Drive up to Malacca
Eye surgery - cannot drive
Recirculation mode not working
