Kiatmobile 1st Gear August 16, 2006 Share August 16, 2006 I have not use the glass polish b4, but friends told me it can easily remove all common contaminants. So just wanted to get 1 to try it out I'm worried abou the screeching of wiper after applying this solutions... Do you think it will happen? As my screen has lots and lots of rain marks... ↡ Advertisement Link to post Share on other sites More sharing options...
Sirbrian Neutral Newbie August 16, 2006 Share August 16, 2006 Kiat, It should not leave any screeching possibilities by your wipers after using the Autoglym Glass Polish. In fact it should improve the efficiency of your wiper. Then again it all depends on the condition and also the brand of your wiper too. Bottom line, I always use the glass cleaner / polisher after my detailing session on my car to give the windows a clean, wet, and "invisible" look. And to put the finishing touch I will coat the windscreen with RainX. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 16, 2006 Share August 16, 2006 Bro, the Autoglym Glass Polish isn't a solution It's similar to the liquid wax whereby it will dry itself on the windscreen It will not cause your wiper to judder but instead improve the efficiency of it I'm using both the Autoglym Windscreen Wash & Glass Polish for many years and they are indeed useful in terms of countering wiper juddering issue Link to post Share on other sites More sharing options...
Toalson 1st Gear August 16, 2006 Share August 16, 2006 Only if u got very bad stains that the normal windscreen cleaners couldnt clean then should u use the AG polish. N if use polish, can use a little on the rubber wiper as recommended. I had been using AG polish but it had been for quite a while tat I last use it. I find that normal cleaner is good enuff for the job n my latest rubber didnt give me much problems of "dancing" wipers. Link to post Share on other sites More sharing options...
Kanr 1st Gear August 16, 2006 Share August 16, 2006 Good stuffs,bro!!! Link to post Share on other sites More sharing options...
Biccat Neutral Newbie August 16, 2006 Share August 16, 2006 Rain_X with prolong use will not only cause your wiper to judder but give it a hazy look as well. Link to post Share on other sites More sharing options...
Owen_fan 2nd Gear August 16, 2006 Author Share August 16, 2006 Hi thanks for the info, will drop by the shell station this coming saturday Link to post Share on other sites More sharing options...
Beanoyip Turbocharged August 16, 2006 Share August 16, 2006 Does this AG glass polish cause juttering on the windscreen wipers? Link to post Share on other sites More sharing options...
Sirbrian Neutral Newbie August 16, 2006 Share August 16, 2006 Rain X when applied to the windows and windscreen is meant to Haze up. Then you really need to buff it off really well for the molecules to be bonded to the glass. After which there will not be any haze. I have been using these pair for 2 years liao...no problem at all, only run into problem when I apply RainX at night and can't see the haze without reflecting lights on the windows. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 16, 2006 Share August 16, 2006 Bro, it will not Infact, it helps to solve juddering issue but depends on how jialat is your windscreen being contaminated Link to post Share on other sites More sharing options...
Biccat Neutral Newbie August 16, 2006 Share August 16, 2006 You may be right. There are many cases of ppl in many forums giving up on this stuff due to problems with glare, hazing, wiper juddering etc. They may have not been doing it correctly but this thing is supposed to be user friendly for the average Joe. Link to post Share on other sites More sharing options...
Southpark2000 Neutral Newbie August 16, 2006 Share August 16, 2006 [reply] but this thing is supposed to be user friendly for the average Joe. - so u mean they abv average lah? Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 16, 2006 Share August 16, 2006 Can tell what the Glass Polish does? Does it remove fine scratches & lines on the outside of the windscreen? How is it supposed to b applied? It makes the glass look clear and wet. And repels some water during rain...Overall results quite satisfied.... =================== OK thanks. I'm looking for a glass polish like a cutting compound which will remove fine scratches. Link to post Share on other sites More sharing options...
Scrambyjess Neutral Newbie August 16, 2006 Share August 16, 2006 you can find AG Fast Glass and Glass Polish at the Homefix DIY store at IMM. Juz went there today. Fast Glass selling at $13.90. Link to post Share on other sites More sharing options...
Bentwy Neutral Newbie August 16, 2006 Share August 16, 2006 autobacs. last week I went they were having a 20% off on all autogylm products... Link to post Share on other sites More sharing options...
Dgwee Neutral Newbie August 16, 2006 Share August 16, 2006 At Autobacs: AG Fast Glass $11.10 AG Glass Polish $10.20 Both after 20% discount Link to post Share on other sites More sharing options...
Beanoyip Turbocharged August 16, 2006 Share August 16, 2006 Fast glass and glass polish... whats the difference? Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 17, 2006 Share August 17, 2006 Thanks I'm actually looking for the AG Windscreen Wash which is in a bottle form and needs to mix with water before usage ↡ Advertisement Link to post Share on other sites More sharing options...
New Age Polish --> Volkswagen Portfolio
Indoor skydiving: Kyra Poh wins two golds at Wind Games
New Age Polish --> Mazda Portfolio
New Age Polish --> Lexus Portfolio
New Age Polish --> Hyundai Portfolio
New Age Polish --> Nissan Portfolio
Health screening packages
