W13ng Neutral Newbie March 16, 2007 Share March 16, 2007 Hi ...... Anyone using 12V mini air compressor to inflate tyre, instead of going to petrol station to inflate. Is it advisable? ↡ Advertisement Link to post Share on other sites More sharing options...
Boyboy 1st Gear March 16, 2007 Share March 16, 2007 in an emergency, still ok. for regular inflating, petrol station la... must plug into cigarette lighter.. and it's much slower too Link to post Share on other sites More sharing options...
Ccssgm 1st Gear March 16, 2007 Share March 16, 2007 Abit of Air Leak...........Use Mini Compressor Is alright...... Link to post Share on other sites More sharing options...
Apollo 1st Gear March 17, 2007 Share March 17, 2007 it is advisable............ to go petrol station to pump. the mini compressor CMI one. becos the pump hor small small, the pleasure also not enuff. must jack up tyre so the wait of car hor dun act on the tyre u know. then this one u pump, 5 minute must stop becos they say beri the hot. pump 5 min wait 10 min. finish pumping sun rise liaoz. Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 18, 2007 Share March 18, 2007 Avoid those low pressure high volume pump as they are designed mainly for inflating large size advertising toys, bed, beachballs etc. Go for those that can put put at least 250psi air pressure and can pump a flate tyre up within 3.5minutes ( depending on car size, and other condtions) Link to post Share on other sites More sharing options...
W13ng Neutral Newbie March 19, 2007 Author Share March 19, 2007 Just wondering any diff. in the air of the petrol station & of the mini air compressor Link to post Share on other sites More sharing options...
Apollo 1st Gear March 19, 2007 Share March 19, 2007 got.. a ordinary compressor system will hv a air filter which seperate the moisture in the air (poorly) before kept inside reciever tank. if left unused, the hot pumped air will cool down then the moisture will collugate into water, then is a pee hole to discharge water. a good good compressor system adds a air dryer system after compressor, so the air is cooled down immediately, then also filter away moisture before sent to receiver tank. so the air inside receiver tank is 100% moisture free... well mebbe 98%. but dun think petrol kiosk got this air dryer. min compressor arh... smlj also dun hv lah. all moisture in air is pumped into tyre lor. Link to post Share on other sites More sharing options...
Nullbig Clutched March 19, 2007 Share March 19, 2007 (edited) Are you refering to this type of dryer for compressed air?? This one I used for my project for Compressed air of 0.8 MPa...Can pump typre for Caterpillar Trucks.... Edited March 19, 2007 by Nullbig Link to post Share on other sites More sharing options...
Crasher Neutral Newbie March 19, 2007 Share March 19, 2007 How about plugging in a nozzle and using it to spray off excess water after we wash our cars? Does anyone buy it just for this purpose? Link to post Share on other sites More sharing options...
Apollo 1st Gear March 19, 2007 Share March 19, 2007 warouz... 6 early 7 early scare me with a big big picture. dun lidat leh.. i only toylet janitor. btw, i dun like catepillar truck.. cos catepillar are slow. i prefer far-lorry. Link to post Share on other sites More sharing options...
Nullbig Clutched March 19, 2007 Share March 19, 2007 ....Toylet janitor now drive big big car one.....dun pray pray.....Orbit workers all take MRT and buzz..... Link to post Share on other sites More sharing options...
Apollo 1st Gear March 19, 2007 Share March 19, 2007 i orbit lor... i take BMW.... bus, mrt and walk. Link to post Share on other sites More sharing options...
Nullbig Clutched March 19, 2007 Share March 19, 2007 And I believe you....... Link to post Share on other sites More sharing options...
Favcar Neutral Newbie March 19, 2007 Share March 19, 2007 It sure does. Where to buy good cheap tires is your question. http://www.favcars.com/auto-part/article.p...p-tires&i=3&e=2 Link to post Share on other sites More sharing options...
Apollo 1st Gear March 19, 2007 Share March 19, 2007 can, but small small compressor at most last u 3 minutes of spraying. then u hv to wait for it to fill up another few minutes. a faster way is just to drive along the ECP. so u got cross wind coupled the coanda effect over the car surface, etc the entire water will b sheared off the car surface in under 10 minutes but then again, i second guess only. Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 19, 2007 Share March 19, 2007 Free-of-charge compressed air cannot be 100% free from water and oil. Removing water and oil from compressed air can be a costly affair.The water content will not casue any harm to yr tyres. For some contruction heavy equipment such as front loader the tyre need very low pressure and need to be fill up 50% with water to increase the weight of the loader. With low pressure and water, it's very comfortable to operated such vehilces even in very rough terrains. Link to post Share on other sites More sharing options...
Lyz77 1st Gear April 6, 2011 Share April 6, 2011 Sorry that I need to high jack yr thread as I can't post new topic since I am new here. May I know other then getting the rims from Eurokars, where else can I source for Mini cooper rims? Thanks. Link to post Share on other sites More sharing options...
Roberttan 5th Gear April 7, 2011 Share April 7, 2011 those mini air compressor is for emengency used only. you cant compare it with those commercial and industrial type compressor(which have more gadget to make the air quality better into your tyre. When you have no choice along the road you will think of what ever resources you have to make you car back to the journey. taking 5 or 10 mins to pump is much shorter than waiting for help without knowing their arrival ? just for your info we dont have to jackup the car to pump your soft tyre A patient inside the ambulance has higher survival rate than waiting for help ↡ Advertisement Link to post Share on other sites More sharing options...
Renting a Mini bus to go Malaysia
Selling a 2017 Nissan Pulsar to buy a used 2016 Mini
Mini JCW GP Roll Over Shortly After Owner Takes Delivery
[Official] 2024 Mini Cooper
Next-Gen Mini Cooper Gets Special EV Sounds, Infotainment Modes, OTA Updates
The Best Cooling Measures: Ice Cream! 😂
