Bossman Neutral Newbie May 14, 2007 Share May 14, 2007 Hi guys, Recently i felt that my car vibrates quite a bit before the engine has warmed up.It drives of about 5 km before the vibration goes away.Did not upgrade or mode anything prior. have been using using 030w schaeffer engine oil thks ↡ Advertisement Link to post Share on other sites More sharing options...
Route88 2nd Gear May 14, 2007 Share May 14, 2007 Your engine mountings? Dirty Throttle body? Link to post Share on other sites More sharing options...
Geogeo Neutral Newbie May 15, 2007 Share May 15, 2007 what's mileage of your car? Link to post Share on other sites More sharing options...
Ivan96935sg Neutral Newbie May 15, 2007 Share May 15, 2007 faulty ignition coils? Fouling of spark plugs? Link to post Share on other sites More sharing options...
Hubwee Supercharged May 15, 2007 Share May 15, 2007 Engine Mountings ??? Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 15, 2007 Share May 15, 2007 Check the RPM of the engine when u cold-start. If it's too low, have it adjusted. Is it time to have your regular servicing? Maybe get the mech to check your TB after u change the plugs, oil & air filter. If the car runs fine after warmed up, it cud b your auto-choke is not working properly. Link to post Share on other sites More sharing options...
Franwilliam 1st Gear July 23, 2016 Share July 23, 2016 My Honda Civic FD4 is having the same problem. I have changed the fuel pump..but the problem still the same. Btw I install air intake system, throttle controller too. I just changed my plug few months ago. Anyone can help me?Now I'm thinking could it be the injectors? Link to post Share on other sites More sharing options...
Hobbit6003 3rd Gear July 23, 2016 Share July 23, 2016 The last time it happened to me, it was the engine mounting of my ride, by then a 7 yr old Civic Link to post Share on other sites More sharing options...
therock Supersonic July 23, 2016 Share July 23, 2016 Probably worn engine mounts.. Happened to my civic. Just ask Kah to check it ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Car air-con
Car air-con
The 2017 Alfa Romeo Giulia
Everything about ice creams
When anything happens…CHANGE CAR!
To be Happy, start thinking about Death!
