Matthewscl Neutral Newbie May 21, 2007 Share May 21, 2007 Wah..got the approval from CO to go see the event...1st time see...very shiok man!..some photos to share.. ↡ Advertisement Link to post Share on other sites More sharing options...
Matthewscl Neutral Newbie May 21, 2007 Author Share May 21, 2007 (edited) Heart Pain, the Carbon fibre lip cracked into pieces! Edited May 21, 2007 by Matthewscl Link to post Share on other sites More sharing options...
Ronnchee Clutched May 21, 2007 Share May 21, 2007 where was the even held ?? nice pictures taken. Link to post Share on other sites More sharing options...
Matthewscl Neutral Newbie May 21, 2007 Author Share May 21, 2007 national stadium carpark F...u can search google..i think its under MPT motors or something like that.. next one should be on sept Link to post Share on other sites More sharing options...
Ronnchee Clutched May 21, 2007 Share May 21, 2007 yes, the next date is 16 Sept, but yet to confirm. will keep it in my diary. Thanks Link to post Share on other sites More sharing options...
Crozz Neutral Newbie May 21, 2007 Share May 21, 2007 Awesum rides. Wunder if they got install crash-bars or roll-cage inside anot. its illegal in Sg but for saftey reasons do they have it? Another grey-line to thread on yah? Link to post Share on other sites More sharing options...
Cannon Neutral Newbie May 22, 2007 Share May 22, 2007 Hey nice pictures taken! I like the shot where the background is blurred. It creates a sense of speed. Got a question hopefully bros here can help me answer. Whenever those evos rammed their engines just before they sprint off, there is a series of popping sound from the engine. WRXs or the civics don't do that. What makes those sound and what they are for. Thanks! Link to post Share on other sites More sharing options...
Icetrap 2nd Gear May 22, 2007 Share May 22, 2007 (edited) Are you talking about the backfire or antilag control / Launch control? I believe that you should be talking about the Anti-Lag System (ALS) is a system used on mainly turbocharged racing to eliminate turbo lag. In laymans term, this will spool the turbo during idle so that you can be boosting from Idle http://video.google.ca/videoplay?docid=-50...nti+lag+evo+vii http://video.google.ca/videoplay?docid=723...nti+lag+evo+vii http://video.google.ca/videoplay?docid=418...nti+lag+evo+vii Edited May 22, 2007 by Icetrap Link to post Share on other sites More sharing options...
Cannon Neutral Newbie May 22, 2007 Share May 22, 2007 ICETRAP, thanks for the link. Yes after watching those videos, I think it is the anti lag sound. Is those popping sound only exclusive to evos? Why there is the need for these kind of system? Haha..I dont mind some one explain to me in more technical terms Is it more superior? (Hope i dont start a flame war) Link to post Share on other sites More sharing options...
Icetrap 2nd Gear May 22, 2007 Share May 22, 2007 Any turbo cars can have antilag system. In fact one of the first car to used it was the Celica GT-4 during WRC rally. From Wikipedia, the free encyclopedia[/u] Anti-Lag System, ALS, is a system used on mainly turbocharged racing and rally engines to eliminate turbo lag. It was used in the early days of turbo charging in F1 until fuel restrictions made its use unsuitable. Later it became a common feature in rally cars due to the mandated restrictors on the turbocharger inlet. Because of the pressure drop across the restriction, the pressure ratio for a given boost level is much higher and the turbocharger must spin a lot faster to produce the same boost as before. This increases turbo lag significantly compared to unrestricted turbochargers. An ALS system requires an air bypass, and generally this is done in one of two ways. The first method is to use a throttle air bypass; this may be an external bypass valve or a solenoid valve which open up the throttle 12-20 degrees. This allows air to bypass the closed throttle and to reach the engine. The second method is to use a bypass valve which feed charge air directly to the exhaust manifold. The throttle bypass/throttle solenoid system is combined with ignition retardation and slight fuel enrichment (mainly to provide cooling), typically ignition occur at 35-45 Link to post Share on other sites More sharing options...
Sickscientist Clutched May 22, 2007 Share May 22, 2007 (edited) Nice pics.... Too bad I missed it on Sunday..... So which team won..?? Wondering if my friend, Man from man exhaust participated.... Edited May 22, 2007 by Sickscientist Link to post Share on other sites More sharing options...
Matthewscl Neutral Newbie May 22, 2007 Author Share May 22, 2007 dont know leh..i didnt stay all the way, the sun was scrotching hot and i already gana sunburned by standing there for about 3hours..hahahah Link to post Share on other sites More sharing options...
Matthewscl Neutral Newbie May 22, 2007 Author Share May 22, 2007 Awesum rides. Wunder if they got install crash-bars or roll-cage inside anot. its illegal in Sg but for saftey reasons do they have it? Another grey-line to thread on yah? yeh..they do have...they took out all the passenger seats also... Link to post Share on other sites More sharing options...
Cannon Neutral Newbie May 23, 2007 Share May 23, 2007 hi thanks for the info. If forummers here don't mind me dwelling on this topic I now more or less understand and appreciates the anti -lag system in some cars. To my limited understanding, a car with ALS enjoys advantage in that he has turbo boost even in low engine speed or rather more even power across the engine revolution bandwidth. However, in the situation of motorsport such as sprint, at the instant just before the car is launched, cars are normally operating at or near max boost. Is there still a need for a anti-lag effect? Is a evo with ALS still enjoys this advantage in a sprint event? Link to post Share on other sites More sharing options...
DarkLord 1st Gear May 24, 2007 Share May 24, 2007 Yahz, he was there. Saw him swapping out his exhaust on Tues. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 24, 2007 Share May 24, 2007 Nice pics Didn't know that got this event else will nag my CO to go together & watch Link to post Share on other sites More sharing options...
cefiro_dude Neutral Newbie June 12, 2007 Share June 12, 2007 Exactly, bro. Didn't know they still had this event in sg either. Cool Link to post Share on other sites More sharing options...
Cannon Neutral Newbie June 14, 2007 Share June 14, 2007 Nobody can give me an answer?? Or perhaps I have already answer my own question ↡ Advertisement Link to post Share on other sites More sharing options...
Photos of the week
Photos of the week
Servotronic... The super crowded workshop...
Posting photos
Posting photos
Car photography locations
Super Virgin Coconut Oil
What are some rare photos of world history?
Nostalgic Singapore Car Photos from the 90s
