Vtim 3rd Gear July 20, 2007 Share July 20, 2007 Got this email from a friend: [/size] Although you may not realize it, simple table salt has a great number of uses other than simply seasoning your food. The following list will give you sixty uses of salt, many of which you probably didn't realize :- 1. If you drop a whole egg on the floor, pour salt all over the egg, let it sit for awhile, then use dustpan, the egg will come right up, without all that mess. 2. Soak stained hankies in salt water before washing. 3. Sprinkle salt on your shelves to keep ants away. 4. Soak fish in salt water before decaling; the scales will come off easier. 5. Put a few grains of rice in your saltshaker for easier pouring. 6. Add salt to green salads to prevent wilting. 7. Test the freshness of eggs in a cup of salt water; fresh eggs sink; bad ones float. 8. Add a little salt to your boiling water when cooking eggs; a cracked egg will stay in its shell this way. 9. A tiny pinch of salt with egg whites makes them beat up fluffier. 10. Soak wrinkled apples in a mildly salted water solution to perk them up. 11. Rub salt on your pancake griddle and your flapjacks won't stick. 12. Soak toothbrushes in salt water before you first use them; they will last longer. 13. Use salt to clean your discolored coffee pot. 14. Mix salt with turpentine to whiten you bathtub and toilet bowl. 15. Soak your nuts in salt brine overnight and they will crack out of their shells whole. Just tap the end of the shell with a hammer to break it open easily. 16. Boil clothespins in salt water before using them and they will last longer. 17. Clean brass, copper and pewter with paste made of salt and vinegar, thickened with flour. 18. Add a little salt to the water your cut flowers will stand in for a longer life. 19. Pour a mound of salt on an ink spot on your carpet; let the salt soak up the stain. 20. Clean your iron by rubbing some salt on the damp cloth on the ironing surface. 21. Adding a little salt to the water when cooking foods in a double boiler will make the food cook faster. 22. Use a mixture of salt and lemon juice to clean piano keys. 23. To fill plaster holes in your walls, use equal parts of salt and starch, with just enough water to make stiff putty. 24. Rinse a sore eye with a little salt water. 25. Mildly salted water makes an effective mouthwash. Use it hot for a sore throat gargle. 26. Dry salt sprinkled on your toothbrush makes a good tooth polisher. 27. Use salt for killing weeds in your lawn. 28. Eliminate excess suds with a sprinkle of salt. 29. A dash of salt in warm milk makes a more relaxing beverage. 30. Before using new glasses, soak them in warm salty water for awhile. 31. A dash of salt enhances the taste of tea. 32. Salt improves the taste of cooking apples. 33. Soak your clothesline in salt water to prevent your clothes from freezing to the line; likewise, use salt in your final rinse to prevent the clothes from freezing. 34. Rub any wicker furniture you may have with salt water to prevent yellowing. 35. Freshen sponges by soaking them in salt water. 36. Add raw potatoes to stews and soups that are too salty. 37. Soak enamel pans in salt water overnight and boil salt water in them next day to remove burned-on stains. 38. Clean your greens in salt water for easier removal of dirt. 39. Gelatin sets more quickly when a dash of salt is added. 40. Fruits put in mildly salted water after peeling will not discolor. 41. Fabric colors hold fast in salty water wash. 42. Milk stays fresh longer when a little salt is added. 43. Use equal parts of salt and soda for brushing your teeth. 44. Sprinkle salt in your oven before scrubbing clean. 45. Soaked discolored glass in a salt and vinegar solution to remove stains. 46. Clean greasy pans with a paper towel and salt. 47. Salty water boils faster when cooking eggs. 48. Add a pinch of salt to whipping cream to make it whip more quickly. 49. Sprinkle salt in milk-scorched pans to remove odor. 50. A dash of salt improves the taste of coffee. 51. Boil mismatched hose in salty water and they will come out matched. 52. Salt and soda will sweeten the odor of your refrigerator. 53. Cover wine-stained fabric with salt; rinse in cool water later. 54. Remove offensive odors from stove with salt and cinnamon. 55. A pinch of salt improves the flavor of cocoa. 56. To remove grease stains in clothing, mix one part salt to four parts alcohol. 57. Salt and lemon juice removes mildew. 58. Sprinkle salt between sidewalk bricks where you don't want grass growing. 59. Polish your old kerosene lamp with salt for a brighter look. Remove odors from sink drainpipes with a strong, hot solution of salt water. 60. If a pie bubbles over in your oven, put a handful of salt on top of the spilled juice. The mess won't smell and will bake ↡ Advertisement Link to post Share on other sites More sharing options...
Kungming 1st Gear July 20, 2007 Share July 20, 2007 4. Soak fish in salt water before decaling; the scales will come off easier Saltwater fish oso same? Not much sense leh right? Meaning they swim in salt water scale oso drop off easily? Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 20, 2007 Author Share July 20, 2007 maybe because when the fish is dead it is different lor Link to post Share on other sites More sharing options...
Starian Clutched July 20, 2007 Share July 20, 2007 can I suggest 61? 61: to make your open wound more pain, add salt, as many as possible to gain the effect of "want to die, yet cannot die"... Link to post Share on other sites More sharing options...
Ccssgm 1st Gear July 20, 2007 Share July 20, 2007 62......4 wooden Plank....Sell Salted Fish....... [laugh] Link to post Share on other sites More sharing options...
Starian Clutched July 20, 2007 Share July 20, 2007 hey hey, wrong la, ppl saying the use of salt, not this... Link to post Share on other sites More sharing options...
Ccssgm 1st Gear July 20, 2007 Share July 20, 2007 .....Sorry......Never Read Properly...... Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 20, 2007 Author Share July 20, 2007 Link to post Share on other sites More sharing options...
Ender Hypersonic July 20, 2007 Share July 20, 2007 A pinch of salt into your coke, is good for your throat and cooling. After a durian session, pour salt water onto the durian hust and drink for it. This will mitigate the heatiness of the durian. Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 21, 2007 Author Share July 21, 2007 not too sure about the coke part, I thought it is to reduce the gases in coke but the durian part is Link to post Share on other sites More sharing options...
Rustyz 5th Gear July 21, 2007 Share July 21, 2007 Durian season!!! Yes salt water on the husk taste better Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 21, 2007 Author Share July 21, 2007 yes, I love "Cat Mountain King" Link to post Share on other sites More sharing options...
Slowmo Clutched July 21, 2007 Share July 21, 2007 Just to add one more, salt turns slugs and snails into liquid, useful if you want to get rid of them or if you just want to collect snail shells. Link to post Share on other sites More sharing options...
Ender Hypersonic July 21, 2007 Share July 21, 2007 This is too cruel. I hope no one is doing this. Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 22, 2007 Author Share July 22, 2007 talk about snails, remind me of the one and only time that I tried escargot, never again Link to post Share on other sites More sharing options...
Jayzee Neutral Newbie July 22, 2007 Share July 22, 2007 thanks for sharing, buddy. Link to post Share on other sites More sharing options...
Guyver 1st Gear July 28, 2007 Share July 28, 2007 Are the information provided above .. proven? Or is it some urban legend? Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 29, 2007 Author Share July 29, 2007 I know some are true ↡ Advertisement Link to post Share on other sites More sharing options...
Meaning of happiness!
Home renovation tips
