Newkid 2nd Gear July 31, 2007 Share July 31, 2007 hi folks, need help on where i can customise housing for my 4 inch mid rage speakers to be mounted on the dashboard. thanks in advance ↡ Advertisement Link to post Share on other sites More sharing options...
Kwchan 1st Gear July 31, 2007 Share July 31, 2007 DIY Link to post Share on other sites More sharing options...
Newkid 2nd Gear July 31, 2007 Author Share July 31, 2007 idea bro!! yours is simple and tidy, greeeeat!! what speakers you using? Link to post Share on other sites More sharing options...
Spinworkx Clutched July 31, 2007 Share July 31, 2007 I see a Vifa there :) And a Focal? Link to post Share on other sites More sharing options...
Kwchan 1st Gear July 31, 2007 Share July 31, 2007 Vifa XT25 & Vifa MG10, also Vifa MG18 on the door some pple even use them for home hifi system Link to post Share on other sites More sharing options...
Kwchan 1st Gear July 31, 2007 Share July 31, 2007 the miso soup bowl can be found in Daiso at $2 each just nice to fit my 2 pairs of 4" u may want to add some sound proofing material inside or go to ikea to get the thicker, wooden bowl for $10+ each Link to post Share on other sites More sharing options...
Hyun Neutral Newbie July 31, 2007 Share July 31, 2007 that foto is sonus faber ah? Link to post Share on other sites More sharing options...
Twnll 1st Gear July 31, 2007 Share July 31, 2007 Spkrs and amp looks DIY? Link to post Share on other sites More sharing options...
Sarong1 1st Gear August 1, 2007 Share August 1, 2007 This looks like one example of bringing home audio into car, or vice versa... Link to post Share on other sites More sharing options...
Hyun Neutral Newbie August 1, 2007 Share August 1, 2007 apart from the frequent usage of sound processing in the car, are there really many differences in terms of implementation of hardware? i.e. the cd player, the wires, the speakers, the enclosures, all follow the same principles. Link to post Share on other sites More sharing options...
Sarong1 1st Gear August 1, 2007 Share August 1, 2007 (edited) Yes and no. Lets talk about the DIFFERENCES first. In home, the type of connect right from the power source all the way to the drivers require delicate attention. For eg using IEC plugs, using power filters/conditioners, "floating/dampening the equipments" from vibration through using isolation pads/cones/pods etc to using short length of I/C as far as possible. These are just the icebergs of the differences. Now, let's talk about the similiarities. You will realise that the components and parts used in car audio's amplifiers and crossovers are generally on par, if not, sometimes better than home audio and we are talking about value-to-value comparison. The manner in which the signal flows through from the source right to the reproduction stage is generally the same as well. So which has more? I beg to think that home audio is really much better because size does matter. I am talking about the acoustic volume, the regulated power supply and the many wonders you can play with the placement of the hardwares. This, in car, is often limited because of space. The speakers are not given enough space to "breathe" and you will probably realise that the size of whatever thing you play in car is often miniaturised. Edited August 1, 2007 by Sarong1 Link to post Share on other sites More sharing options...
Hyun Neutral Newbie August 1, 2007 Share August 1, 2007 certainly it's really much better, there isn't any doubt. and where the example of plugs, conditions etc are concerned, there isn't any "difference" - both sides wanna use plugs, power line conditioning. i guess the vibration-dampening is less applicable in cars due to its mobile nature, but who knows, maybe also got good effect. so it's not really different mah. and as for size, everything is done on larger scale. all the same things - just larger. Link to post Share on other sites More sharing options...
Sarong1 1st Gear August 1, 2007 Share August 1, 2007 Why not put it this way although I am quite reluctant to compare both since there is really no basis. I will surmise it this way. "The same type of equipments when applied in different acoustics, should have varying results." Full Stop. Link to post Share on other sites More sharing options...
Hyun Neutral Newbie August 1, 2007 Share August 1, 2007 which is the point in my response - are they really different? the "modifications" made to drivers for "car use", apart from simply playing with impedances and weather-proofing, are they trying to do some form of compensation? i have not yet come across any concrete "mods" manufacturers do to drivers to make them outstanding compared to home drivers. "The same type of equipments when applied in different acoustics, should have varying results." this is something often disregarded. although home audio can be played in an enclosed room, the magnitude of cabin gain in a car is so tremendous that it changes the way low-frequency drivers should be implemented. a common result of this misunderstanding is that subwoofers are often set WAY too loud. also, we often have a misunderstanding of how much subsonic frequency we require in a car to achieve a flat response. often, we demand to FEEL distinctly the 20hz vibration, and that is way too "loud". Link to post Share on other sites More sharing options...
Sarong1 1st Gear August 1, 2007 Share August 1, 2007 this is something often disregarded. although home audio can be played in an enclosed room, the magnitude of cabin gain in a car is so tremendous that it changes the way low-frequency drivers should be implemented. a common result of this misunderstanding is that subwoofers are often set WAY too loud. also, we often have a misunderstanding of how much subsonic frequency we require in a car to achieve a flat response. often, we demand to FEEL distinctly the 20hz vibration, and that is way too "loud". Hyun, this I agree with you totally. In fact, if you are to play some music in the car and stand outside the car to listen, you will probably have a good sensing just what freq are propagated outside the car and what really remains as rebounce in the car.When we say a generally flat response, we do not only refer to the spectrum balance, but also the sound pressure balance. Remember that each set of speakers in the car are supposed to complement each other to reproduce a full-range spectrum faithfully. There should not be a case where the subwoofer, for eg, outperforms the rest of the components, because that will mean, imbalance and unnatural. We can discuss more. Link to post Share on other sites More sharing options...
Kermit 1st Gear August 1, 2007 Share August 1, 2007 I know I'm actually getting myself frustrated by participating in this discussion...but...what the heck.... You know why dogs like to lick their own balls? Because they CAN. So, you know why people like to feel the 20hz vibration in the car? Because they CAN. QED. At home, it demands much more to be able to do that. In a live envirnoment, well, perhaps with the exception of disco/clubs, these low freq are hardly reproduced. But in clubs, people MUST have that....look at how many hugh subwoofers they use and what power is driving them.... Whether or not you think it's natural or not...really depends on what music you're playing. And of cos, individual preferences. If my monkey business tracks don't have that umphhh in the sub ranges...I know it's wrong....but when I switch back to something else...i may be getting too much of sub...so how? Link to post Share on other sites More sharing options...
Hyun Neutral Newbie August 1, 2007 Share August 1, 2007 > Re: Customise housing for 4 inch focal 100kp comp speakers hehe looks like we're both way off topic. perhaps another difference is that in home application, using narrower-dispersion drivers isn't a big sin. in car audio, we'll need to know what we're doing when mounting narrower-dispersion drivers, or just stick to the traditional wide dispersion ones. Link to post Share on other sites More sharing options...
Kermit 1st Gear August 1, 2007 Share August 1, 2007 depends on what drivers, playing what range...and where they're mounted. agree...dispersion is one impt consideration. ↡ Advertisement Link to post Share on other sites More sharing options...
Component speakers, no amp?
First Testing
First Testing
Which bank offers better housing loan package now?
Gladen n Ground Zero speakers, are they related?
Right side speakers no sound
Brax Matrix Speakers by Audiotec Fischer
