Shicyj Neutral Newbie December 28, 2011 Share December 28, 2011 I tried looking everywhere, almost 5 yrs now. Still can't find it. I suspect it's the fuel pump or something like that (i could be very wrong). My new A5, the wipers will move to a lower position when i turn of the ignition, where you can actually see and hear them move, macham disarm position liddat. That's why i love these cars, they are very technoligically advanced for the humble entry level models. My A5 will automatically put the wipers in INT mode, when the car is stationary, and resume to the driver set speed when moving. wait till an electronic glitch lock you inside your own car like him... http://www.zdnetasia.com/bmw-glitch-locks-...in-39130270.htm ↡ Advertisement Link to post Share on other sites More sharing options...
Berncsp76 6th Gear January 3, 2012 Share January 3, 2012 Battery flat yesterday at Suntec due to the problem surface again, and forgotten to go back to unplug the radiator fuse. Today sent it to my cousin's workshop and took a look. He just changed the relay as he mentioned I did not change it before...viola! problem solved. But now still monitoring see if the radiator fan will shut on or off automatically anot. Link to post Share on other sites More sharing options...
Pss2 2nd Gear September 24, 2016 Share September 24, 2016 (edited) Sorry to bring up this old thread. I have been driving the X Type for a year. Today, when I off the engine, the radiator fan continue to run. I thought it will stop after a minute or 2 but it just continue to run. I have to send to a workshop and the fan refused to turn off till the mechanic had to plug off the fuse. Anyone can advise? I dont think this is normal even for a conti car. This is the first time i experience this after driving for a year. Edited September 24, 2016 by Pss2 Link to post Share on other sites More sharing options...
Kb27 Supersonic September 24, 2016 Share September 24, 2016 Sorry to bring up this old thread. I have been driving the X Type for a year. Today, when I off the engine, the radiator fan continue to run. I thought it will stop after a minute or 2 but it just continue to run. I have to send to a workshop and the fan refused to turn off till the mechanic had to plug off the fuse. Anyone can advise? I dont think this is normal even for a conti car. This is the first time i experience this after driving for a year. Stuck relay. Change it and see what happens. Link to post Share on other sites More sharing options...
Pss2 2nd Gear September 24, 2016 Share September 24, 2016 Stuck relay. Change it and see what happens. Hi Thanks. Car in work shop. They say they will call supplier for the "resistor". I dont know if it is the same as what you mentioned. Link to post Share on other sites More sharing options...
Yoyo163 Neutral Newbie May 11, 2017 Share May 11, 2017 Hi hi Saw this thread I hv a skoda Octavia 2009 combi vrs I hv battery drain issue The fan keeps running on Abd off till it drain my battery Suspect relay problem, electrician check this model no relay for radiator fan Suspect water pump thermostat issue Changed no improvement Anyone encounter this? ↡ Advertisement Link to post Share on other sites More sharing options...
Any Running Man fans?
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
My engine after 150,000 kms
