Kelpie 2nd Gear September 26, 2007 Share September 26, 2007 1. I've been seeing small puny car putting big brake kit like 4 pots or 6 pots. 2. Are these small cars really that fast that need such a big brake that you only see them in performance car? Not even some of those >2L luxury cars have it. 3. So is this a matter of overkill or an ego problem? Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Wolverman Neutral Newbie September 26, 2007 Share September 26, 2007 some not so well endowed girls wear oversized bras.. why? Link to post Share on other sites More sharing options...
Viviobluerex Clutched September 26, 2007 Share September 26, 2007 (edited) I drive a small puny car , but stock brakes is not good, so I change 4pot. I fear for my life if my car can't stop in time, is that overkill or ego problem? By the way what car You driving? Edited September 26, 2007 by Viviobluerex Link to post Share on other sites More sharing options...
Viviobluerex Clutched September 26, 2007 Share September 26, 2007 Ah.... that depends. Link to post Share on other sites More sharing options...
macrosszero Turbocharged September 26, 2007 Share September 26, 2007 1. Its cool to be safety conscious. 2. It implies they have modded their engine as well. 3. Overkill. Seriously it is their car, their money, their problem. You can say the same for big spoilers and GT wings, or airscoops and cutouts for non-existent intercoolers and turbochargers. No, I'm not one of them, I run stock brakes. Link to post Share on other sites More sharing options...
Streetbumpkin Neutral Newbie September 26, 2007 Share September 26, 2007 Brakes is the most important component of the car to me.It's not a matter of how fast your car can go but how fast and how short a distance you can stop to avoid an accident in extreme cases. Link to post Share on other sites More sharing options...
Viviobluerex Clutched September 26, 2007 Share September 26, 2007 For my case no choice, every unit of my make/model has "spongy brakes", after trying many type of brake pads, brake hose, pumps, disc rotors...etc. Finally gave up and bought a 4pot set. You will understand if I say "Braking Confidence" wun you? Link to post Share on other sites More sharing options...
Kelpie 2nd Gear September 26, 2007 Author Share September 26, 2007 Mine is a Civic, I'm on ordinary orginal factory 282mm brake kit. I've no problem going and up down gentings and stopping at high speed. I think frequent change of brake pads and the use of high performance tyres are good enough. Regards, Link to post Share on other sites More sharing options...
Viviobluerex Clutched September 26, 2007 Share September 26, 2007 Since we talking about this, can I check with you, do you change new pads before going to genting? Or do you run in for a couple of days before even driving in? BTW, I saw a Kanchil in Genting with a real 6 pot brembo, I was like .. Link to post Share on other sites More sharing options...
Streetbumpkin Neutral Newbie September 26, 2007 Share September 26, 2007 I upgraded my brake lines to stainless steel braided, brake disc to slotted and brake pads, both from project mu..No regrets.Now braking is definately with much more confidence.No doubt good tyres play a role but i found the brakes was the cause. Link to post Share on other sites More sharing options...
Jian Neutral Newbie September 26, 2007 Share September 26, 2007 Is there a prob for puny car with big brake? if there's BBK for my make why not? I upgrade for safety issue, cos my stock brake cannot make it. On full load the car cant stop in time. Link to post Share on other sites More sharing options...
Viviobluerex Clutched September 26, 2007 Share September 26, 2007 Project MU!!!! Wah! Must be damn ex?!?!?!?!!?!?! Link to post Share on other sites More sharing options...
Viviobluerex Clutched September 26, 2007 Share September 26, 2007 Ha ha ha, let me guess, yours is a hatch!!!!! We have the same problem!!!! Link to post Share on other sites More sharing options...
Streetbumpkin Neutral Newbie September 26, 2007 Share September 26, 2007 I never change caliper Link to post Share on other sites More sharing options...
Jian Neutral Newbie September 26, 2007 Share September 26, 2007 bro, ya project mu pad and rotor noise when come to stop or about to stop?? Link to post Share on other sites More sharing options...
Kelpie 2nd Gear September 26, 2007 Author Share September 26, 2007 I don't change brake pads specifically for climbing hills . My brake pads are also stock type, which are also good enough for me. Regards, Link to post Share on other sites More sharing options...
Meecar Clutched September 26, 2007 Share September 26, 2007 I drive a small puny car , but stock brakes is not good, so I change 4pot. I fear for my life if my car can't stop in time, is that overkill or ego problem? By the way what car You driving? if you get elephant size brakes but if you dont replace your tires regularly as recommended, it then make no sense if your tires are close to botak, no dinosaur brakes are going to help you because you will be aqua-planing oversize brakes may be counter-productive as the braking system with the entire wheel system and suspension the corollary would be buying oversize tires i guess the oversize brakes must be approved by the manufacturer, that I believe it is ok Link to post Share on other sites More sharing options...
Jian Neutral Newbie September 26, 2007 Share September 26, 2007 yeah bro, guess u know who am i ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Small little tiny bug on walls & ceiling
Brake squeak every morning
