Stainless steel air filter cleanliness
Circuit
hi to any one using stainless steel filters.. eg hurrican , simota, etc.
my ride is lower. then using a drop-in stainless steel filter.
with CAI to the bottom facing front beside the radiator, slightly forward.
so problem is before the filter i then to get a bit sand in filter box.
after the filter its look clean but use ur hand to wipe. its with v fine sandy feel...
with tissue can see dirt.
when using stock paper theres non....
been told when place CAI low. will get this problem. is it true?
should i relocate higher? but higher no hole to draw cold air...
defead the pupose rite?unless higher then facing down?
The problem is obviously on the type of filter u'r using.
Do u see the big lobangs on your s/s filter? Compare it with your stock filter if u cannot see. [laugh]
No matter where u place your CAI the problem will still be there.
U can DIY and superglue a piece of sponge to your s/s filter as seen on your stock. But why bother? Just use back the stock filter. [laugh]
use cotton type..better than stock (which is made mostly from paper)...
i dont think SS type can filter out the dirt that effectively as cotton.
i think better change back to the original top air snorkel.
cos last time... using tat not so much of dirt after.
nearer to floor got more problem , hai....
test see how lor
