Roberttan 5th Gear June 7, 2018 Share June 7, 2018 Main reason why tyre companies discourage repair is because once the run flat tyre get punctured the sidewalls take the weight of the car and pending how long you drive without pressure may compromise the sidewall hence safety may get compromised if repaired. However if you detect the puncture and pump air quickly enough you can retain your sidewall integrity, either way internal patching it recommended for rft not only because its a better seal but it also allows the tyre shop to inspect the sidewall for any rupture (see below) i think we had 1 very good picture shown clearly how was the internal damaged or injured looks like, from the pictures if 1 punctured tire was repaired from outside (those sticky worm or insert repaired) will risk of this if continue use . that's way if you have to do the external repair please ask the shop people to remove the repaired tire for internal inspection. ↡ Advertisement Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 11, 2018 Share June 11, 2018 I went to see the under side of my original rims, no have EH or EH+. Link to post Share on other sites More sharing options...
Beregond Supersonic June 11, 2018 Share June 11, 2018 I went to see the under side of my original rims, no have EH or EH+. Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 11, 2018 Share June 11, 2018 because that is a audi. your audi orginal come with RFT tyres?? Nope. Doesnt come with RFT tyres as standard. Link to post Share on other sites More sharing options...
Roberttan 5th Gear June 11, 2018 Share June 11, 2018 I went to see the under side of my original rims, no have EH or EH+. 3 Link to post Share on other sites More sharing options...
Extremme 4th Gear August 21, 2018 Share August 21, 2018 Was quoted $360 for a michelin run flat tyre. Think my stock rim size is 17". Is it expensive? Link to post Share on other sites More sharing options...
redstuff 4th Gear August 21, 2018 Share August 21, 2018 Was quoted $360 for a michelin run flat tyre. Think my stock rim size is 17". Is it expensive? I have no experience with Michelin RFTs, but I was quote around 260-290 for Bridgestone and Pirelli 17" RFTs. Managed to find a source last month that charged me $230 for Pirelli Cinturato P7 RFT 225/50/R17. PM me if you want to have the contact. Link to post Share on other sites More sharing options...
Extremme 4th Gear August 21, 2018 Share August 21, 2018 (edited) I have no experience with Michelin RFTs, but I was quote around 260-290 for Bridgestone and Pirelli 17" RFTs. Managed to find a source last month that charged me $230 for Pirelli Cinturato P7 RFT 225/50/R17. PM me if you want to have the contact.Pls pm me!! Thks Edited August 21, 2018 by Extremme Link to post Share on other sites More sharing options...
Beregond Supersonic August 21, 2018 Share August 21, 2018 Was quoted $360 for a michelin run flat tyre. Think my stock rim size is 17". Is it expensive? higher then pirelli and goodyear. (225.55.17 ) pirelli p7 cint RFT can get easily-300 buks i think but michelin RFT very rare i think, didnt even see before, slightly higher is normal? 1 Link to post Share on other sites More sharing options...
Extremme 4th Gear August 21, 2018 Share August 21, 2018 higher then pirelli and goodyear. (225.55.17 ) pirelli p7 cint RFT can get easily-300 buks i think but michelin RFT very rare i think, didnt even see before, slightly higher is normal? My current stock is also michelin RFT. Not into tyres hence asking Link to post Share on other sites More sharing options...
redstuff 4th Gear August 21, 2018 Share August 21, 2018 Pls pm me!! Thks Done. Link to post Share on other sites More sharing options...
Roberttan 5th Gear August 21, 2018 Share August 21, 2018 Was quoted $360 for a michelin run flat tyre. Think my stock rim size is 17". Is it expensive? may be you can share the tire size ? Expensive = what ? = subjective tiresa are sold with installation bla bla bla . No shop is equal , compare apple to apple Link to post Share on other sites More sharing options...
Extremme 4th Gear August 21, 2018 Share August 21, 2018 may be you can share the tire size ? Expensive = what ? = subjective tiresa are sold with installation bla bla bla . No shop is equal , compare apple to apple It's quoted by the authorised dealer so I will assume its jacked up as always as opposed to go out to those outside tyre shops. 205/55/17 Link to post Share on other sites More sharing options...
inlinesix Supersonic August 21, 2018 Share August 21, 2018 205/45 17 Michelin PS4 $240 Link to post Share on other sites More sharing options...
Inlinefour Twincharged August 21, 2018 Share August 21, 2018 higher then pirelli and goodyear. (225.55.17 ) pirelli p7 cint RFT can get easily-300 buks i think but michelin RFT very rare i think, didnt even see before, slightly higher is normal? Michelin Zero Pressure RunFlat price higher than other brand Thats why not much people mentioning or using PML using Bmw Star tyres of Pirelli, Goodyear commonly but expensive too But does come with 1 for 1 warranty coverage 1 Link to post Share on other sites More sharing options...
hadllton August 23, 2018 Share August 23, 2018 i have 2 years experience with this tires, and i like it Link to post Share on other sites More sharing options...
ER-3682 Twincharged December 22, 2018 Share December 22, 2018 How much heavier are Run -Flat Tyre compare with Normal Tyre.?Is it more than 1 kg per Tyre.? Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 29, 2018 Share December 29, 2018 It's quoted by the authorised dealer so I will assume its jacked up as always as opposed to go out to those outside tyre shops. 205/55/17 car Dealer are not tire specialist , they are Providing you service to save your time (time = Money) if you really wants the Specialist you need to go and look around market who are knowledgible and expert in tires and are able to provide you after sales serive like regular pressue pump / rotation / re balance and most importantly Tire repaire by recommended way . ↡ Advertisement Link to post Share on other sites More sharing options...
Hdb flat renovation
Hdb flat renovation
