Ken_leong 2nd Gear February 5, 2008 Share February 5, 2008 Hi. Need advice from you bros and sis here. Which would you choose? ↡ Advertisement Link to post Share on other sites More sharing options...
Boyboy 1st Gear February 5, 2008 Share February 5, 2008 hurricane is better in quality and price better as in higher.. i use simota btw . use it only if u don't mind ur engine sucking in more dirt. i don't give a damn about mine Link to post Share on other sites More sharing options...
Joshterran 1st Gear February 5, 2008 Share February 5, 2008 Hi, Do you clean and oil your Simota filter? I wash with water, air dry before I apply oil. ================================================ Link to post Share on other sites More sharing options...
Donut Supercharged February 5, 2008 Share February 5, 2008 use K&N filter........... its better Link to post Share on other sites More sharing options...
Boyboy 1st Gear February 5, 2008 Share February 5, 2008 stainless steel filter leh. i don't think it is supposed to be oiled. i wash with water enuff liao Link to post Share on other sites More sharing options...
Josephteo 1st Gear February 5, 2008 Share February 5, 2008 Yea..dun think stainless steel filters need to be oiled... the advantage is that you have less fuss when you need to clean up the filter...i.e. just wash with water..or blow away the dirt can liaoz... but with a cotton based air filter (e.g. K&N air filter), you need to follow the directions very clearly and wash the filter using their non-detergent based cleaner then oil using their red-color looking oil... (it's sold in a package called K&N recharger kit) but the good thing about cotton-based air filters is that it allows more air into the engine than conventional disposable paper air filter...but it blocks more dirt into the engine as compared to the stainless steel filters.... So guess u gotta judge for yourself... I'm current using the K&N filter... Link to post Share on other sites More sharing options...
Boyboy 1st Gear February 5, 2008 Share February 5, 2008 i not confident of maintaining a K&N by myself, and don't want to rely on mech to settle also. so just use SS filter lor. anyway dun think i'll be driving my car for more than 100k. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear February 5, 2008 Share February 5, 2008 If pocket is deeper then go for Hurricane else Simota Both are stainless steel hence maintenance is jus wash with soap/plain water then dry it More dirt & dust would allowed to enter your engine hence can opt to change your engine oil at 1K or 1.5K earlier then the 10K interval My ride already on it for 74K and still going strong Link to post Share on other sites More sharing options...
Eyke Supercharged February 5, 2008 Share February 5, 2008 iirc, the air your engine takes in does not go to where your engine oil circulates, so changing engine oil more frequently doesn't help. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear February 5, 2008 Share February 5, 2008 Is it??? Paiseh paiseh ... Heard the MAF sensor will get dirty much easier as compared to using stock air filter Link to post Share on other sites More sharing options...
Johnson 1st Gear February 5, 2008 Share February 5, 2008 Hi. Need advice from you bros and sis here. Which would you choose? understand that the filtration holes for hurricane SS filters is ard 55 microns, i.e. 0.055mm per hole. Dunno how big is the Simota one. Link to post Share on other sites More sharing options...
Josephteo 1st Gear February 5, 2008 Share February 5, 2008 (edited) yes bro... The first time I was not confident about maintaining my K&N and I asked the mechanic to help me clean and oil and install... I saw how he install the filter..so i got a feel... then i took out the k&n filter and I found that OIL was dripping out of the filter...coz he OVER-OILED it... After that incident...I had to re-wash, re-oil and fix back the filter myself... from then on... I dun really trust mechanics with the k&n air filter cleaning... haha..it's always better to DIY for K&N filter..or any other oil-based filter for that matter. Edited February 5, 2008 by Josephteo Link to post Share on other sites More sharing options...
Josephteo 1st Gear February 5, 2008 Share February 5, 2008 bro Mzrmazda3, You are using hurricane filter is it? Do you feel that you have more power after installing the filter as compared to the stock disposable air filter? For me, after installing the K&N...seems my car got more power..especially when moving off...easier and smoother...as compared to using the stock disposable air filter... haha...dunno is psychological or not? but i did switch back to old air filter...drive a bit..then switch back... and it really feels more power... not sure..haha Link to post Share on other sites More sharing options...
Nash10 Neutral Newbie February 5, 2008 Share February 5, 2008 I have tried K&N filter,hurricane stainless steel filter. Now i am using simota carbon charger..thats the best i felt.. Link to post Share on other sites More sharing options...
Yuan 6th Gear February 7, 2008 Share February 7, 2008 I thought cotton filters are better than stainless steel ones? Link to post Share on other sites More sharing options...
Sickscientist Clutched February 7, 2008 Share February 7, 2008 Better in filtration... Link to post Share on other sites More sharing options...
Bryanlow Neutral Newbie February 7, 2008 Share February 7, 2008 YA bro same feel too. Link to post Share on other sites More sharing options...
Picanto 3rd Gear February 9, 2008 Share February 9, 2008 stock is the best. protects your MAF sensor from dust and dirt. ↡ Advertisement Link to post Share on other sites More sharing options...
Air Purifier Discussion - tips and info
DIY engine oil change
Steel cabinet
Steel cabinet
Recommendation for water filter
K&N or Hurricane or works stainless steel air filter.
Dyson Zone, the real deal or has April fool's day come early?
Replacing fuel filter
