Dionyeo Neutral Newbie March 6, 2008 Share March 6, 2008 There's still a number of items lying around in my room since i took it off, maybe u bros can just call me directly and discuss. Need to clear my room asap for personal reasons. 1. Stock air box - bottom cover got one hole 2. Hamburger air filter - biggest size 10 inch if i dun remember wrongly, top cover slightly cracked, stainless steel filter. 3. Galvanised 4-2-1 extractor - only 3-4 months old 4. EP71 turbo FRONT 242mm twin ventilated rotors, brake calipers and brake pads (1 complete set direct plug and play noneeed modification)- i would say the performence is in between Stock EP80 brakes(single solid disc rotor) and EP82GT brakes(bigger twin ventilated disc rotors and caliper), high speed braking definately better than stock EP 80, especially if u have upgradeed master brake cylnder. pads are 6 months old as of removal. 5. Exedy 3 puck heavy duty clutch with clutch cover - can last another 9months-1.5yrs clutch plate 8 inches, clutch cover 10 inches (Outside Diameter) 6. 2pieces of OEM 262mm twin-ventilated 4 x 100PCD rotors(brake disc) Size: Overall Diameter: 262mm, rotor thickness: 18mm, overall height: 48mm thanks for viewing, please help to clear! ↡ Advertisement Link to post Share on other sites More sharing options...
Ep82 Neutral Newbie May 22, 2008 Share May 22, 2008 Hi Ep82, I'm interested on some of your parts.Could you please give me a call @ 97505530? Rgds, David Link to post Share on other sites More sharing options...
Steam Neutral Newbie May 22, 2008 Share May 22, 2008 WELCOME, DAVID!!! ↡ Advertisement Link to post Share on other sites More sharing options...
The Perfect Storm of the Stock Market III
Teana repair/parts
Teana repair/parts
Consolidation of useless modification (Performance parts)
The Best Cooling Measures: Ice Cream! 😂
Tesla hits record high in first trading session of 2021
Test forum upg
Test forum upg
Stockist for Genuine Toyota Spare Parts?
