Junjie 1st Gear May 26, 2008 Share May 26, 2008 i've been using one for the past 5 years or so. Bought at homefix DIY for about 30+. Definitely worth the money. Petrol kiosk got many inconsiderate people who parked their cars at the lot designated for tire pump....so i prefer to do it at my MSCP. Bro, any brand name for the one u r using? Power tap from the 12V socket? ↡ Advertisement Link to post Share on other sites More sharing options...
Carlovz Clutched May 26, 2008 Share May 26, 2008 Cant remember the brand, will check it out later. I brought around 20 plus if remember correctly. But when topping up, it is very fast. Not sure your fren is topping up a totally flat tire or jus topping a few diff psi For a few diff in PSI took mi about less than a min. I tend to over inflate and got to let go a bit air. That's where the confusion comes in. The compressor show me 33PSI but my hand held pressure guage shows 34PSI. So normally I will take the hand held one. Link to post Share on other sites More sharing options...
Ahwhye 5th Gear May 26, 2008 Share May 26, 2008 I just dumped mine last week and got myself a cheapo manual foot pump, and it worked fine for top-up of air for car and bicycles. Link to post Share on other sites More sharing options...
Dumb 4th Gear May 26, 2008 Share May 26, 2008 (edited) Manual pump is very good. Not prone to failure and doesn't drain the battery. Can use to inflate sex doll. If use electric compressor to pump up sex doll, might explode in your face. ---------------------------------------- More likely the doll will only explode if he looses his cool, discard the electric compress in favour of DIY and keep pumping or squeezing it too tight. Edited May 26, 2008 by Dumb Link to post Share on other sites More sharing options...
BoneStock 5th Gear May 27, 2008 Share May 27, 2008 bro, which brand/model u using now? i brought one from autobacs too....but found that the reading from the compressor and the tire pressure guage kinda of show diff readings. So normally i will jus base on the tire guage. else the two show diff readings....confused think it is called power 1 or something like that. usually there are 2 different units available...psi or kg/cm3 Link to post Share on other sites More sharing options...
BoneStock 5th Gear May 27, 2008 Share May 27, 2008 yah...tap from cigarette lighter socket. attached some pics for your easy viewing [inline 26052008.jpg][inline 26052008(001).jpg] Link to post Share on other sites More sharing options...
Junjie 1st Gear May 27, 2008 Share May 27, 2008 Thks Bro Link to post Share on other sites More sharing options...
Tay107 Neutral Newbie June 8, 2008 Share June 8, 2008 is foot pump solid??? long long time got 1 think made in tw or cn. the frame loose. Link to post Share on other sites More sharing options...
Wendyngbc Neutral Newbie January 5, 2012 Share January 5, 2012 Hi, Do you think if you can advise the model or type of the portable air compressor you had bought? I have check the link homely you advise, but not able to find it? Please advise. Thanks. Link to post Share on other sites More sharing options...
Incom 1st Gear January 5, 2012 Share January 5, 2012 Hi, Do you think if you can advise the model or type of the portable air compressor you had bought? I have check the link homely you advise, but not able to find it? Please advise. Thanks. Last saw it available at Homely a few years back. You can give them a call to check before going down. Alternatively is to go down to Autobacs. Cheers Link to post Share on other sites More sharing options...
Ash75 Neutral Newbie January 5, 2012 Share January 5, 2012 Hi anyone can advice if these electrical Tyre pump(meant for maintenance purpose) is d functions same for nowadays new car which don't comes with spare tyre anymore? Cause mine 2nd hand ride got no spare tyre nor electrical pump Thkz for any input/advice. ↡ Advertisement Link to post Share on other sites More sharing options...
This is Why You Should NOT Fit OE Tires To Your Car!
What tires for SUV?
What tires for SUV?
cut on the sidewall of my tire
Tread Depth
Tread Depth
Dunlop SP Sport LEMANS LM705
Used Truck / tractor tires.
How close to wear indicators before changing tires?
Anybody bought those portable car washer
