Ahyoo2002 2nd Gear May 13, 2008 Share May 13, 2008 Come across this interesting 5/7/8 Seater from bro Carbon82 at SHC: http://www.shc-forum.com/viewtopic.php?t=1...der=asc&start=0 Look like it will be a competitor to Toyota Sienta. Launch Date: 29 May 2008 (in Japan) Available with 3 seating configuration: 5 pax (2 row) / 7 pax (3 row with captain seat on 2nd row) / 8 pax (3 row with bench seat on 2nd & 3rd row) Price: 5 seat version to be price around that of entry level Airwave, while 7 / seat version around that of entry level Stream External Dimension: 4,215mm (L) x 1,695mm (W) x 1,715mm (H) Wheelbase: 2,700mm Engine Type: 1.5L SOHC i-VTEC (L15A) Engine Capacity: 1,496cc Max. Horsepower: 118ps / 6,600rpm Max. Torque: 142Nm (14.4Kgm) / 4,800rpm Transmission: Auto - CVT Fuel Consumption (Japan 10-15 Mode): 16.4Km/L (Base model) ↡ Advertisement Link to post Share on other sites More sharing options...
Kxbc Turbocharged May 13, 2008 Share May 13, 2008 Engine capacity only 1.5l. How to haul 7 pax? Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear May 13, 2008 Author Share May 13, 2008 Full Specification External Length: 4,215mm External Width: 1,695mm External Height: 1,715mm Internal Length: 2,625mm Internal Width: 1,440mm Internal Height: 1,265mm Wheelbase: 2,740mm Track (Front): 1,480mm Track (Rear): 1,465mm Min. Ground Clearance: 150mm Min. Turning Radius: 5.2m Wheel Size: 185/70R14, 185/65R15 Weight: 1,250 [FLEX, FF] - 1,380Kg [Gi Aero 8Pax, 4WD] Engine Type: 1.5L SOHC i-VTEC (L15A) Engine Capacity: 1,496cc Bore x Stroke: 73.0mm x 89.4mm Compression Ratio: 10.5:1 Max. Horsepower: 118ps (86KW) / 6,600rpm Max. Torque: 144Nm (14.7Kgm) / 4,800rpm Transmission: Auto - CVT [FF] / 5AT [4WD] Fuel Consumption (Japan 10-15 Mode): 16.4Km/L [FF] / 14.0 [4WD] Front Brake: Ventilated Disc Rear Brake: Drum Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear May 13, 2008 Author Share May 13, 2008 Er, similar to Toyota Sienta, Daihatsu Terios 7 seater and Toyota Avanza (1.3 and 1.5L, Malaysia), all are 7 seater but 1.5L only. Link to post Share on other sites More sharing options...
Killingtimes Neutral Newbie May 13, 2008 Share May 13, 2008 well...the price of toyota rush or Terios seems attractive as compare to Honda Freed. Link to post Share on other sites More sharing options...
Hectos Neutral Newbie May 13, 2008 Share May 13, 2008 different cat. dude. Link to post Share on other sites More sharing options...
Raven Neutral Newbie May 13, 2008 Share May 13, 2008 4WD somemore....?? Link to post Share on other sites More sharing options...
Perrier 1st Gear May 13, 2008 Share May 13, 2008 Seemed like a downsized stepwagon with a smaller engine. Link to post Share on other sites More sharing options...
Shern25 2nd Gear May 13, 2008 Share May 13, 2008 can one, only at the expense on power. I think 1.5l 7seater MPV will be getting popular especially when Cat A COE is so much lower than Cat B now, and the escalating oil price. Link to post Share on other sites More sharing options...
Killingtimes Neutral Newbie May 13, 2008 Share May 13, 2008 wat u mean diff cat? Both are 1.5..... Link to post Share on other sites More sharing options...
Watwheels Supersonic May 13, 2008 Share May 13, 2008 Looks like the big bro of Jazz/Fit. Link to post Share on other sites More sharing options...
Application9999 Clutched May 13, 2008 Share May 13, 2008 looks good and look big...but....can it move with a 1.5L engine? Link to post Share on other sites More sharing options...
Killingtimes Neutral Newbie May 13, 2008 Share May 13, 2008 of course it will move Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 13, 2008 Share May 13, 2008 looks good and look big...but....can it move with a 1.5L engine? sure can move one, it's a matter of how fast only Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear May 13, 2008 Author Share May 13, 2008 well...the price of toyota rush or Terios seems attractive as compare to Honda Freed. The new 7 Seater Toyota Terios is from Indonesia and the FC can not compare to this one. I think this Freed is direct answer from Honda to Toyota Sienta. Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear May 13, 2008 Author Share May 13, 2008 4WD somemore....?? In Japan, they always has many variants for the same model Link to post Share on other sites More sharing options...
Application9999 Clutched May 13, 2008 Share May 13, 2008 true true...every car can hit 100km/hr...is just how it reach 100km/hr...hahaha Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear May 13, 2008 Author Share May 13, 2008 Looks like the big bro of Jazz/Fit. Based on FIT/Airwave ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
