Jupitery Neutral Newbie May 30, 2008 Share May 30, 2008 My car steering wheel will vibrate strongly when i apply brake at high speed (eg. 90km/h or higher). I have just recently(about 1 mth ago) send my 2 year old car for servicing, change new tires, change front brake pads and did a wheel alignment. Prior to this, i have no such problem. Any kind soul can tell me what is the likely cause of the problem? ↡ Advertisement Link to post Share on other sites More sharing options...
Sky61 1st Gear May 30, 2008 Share May 30, 2008 wat brakepads u changed? rotors most likely warp. change rotors or skim them,and do a high speed on-wheel balancing at stamford. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 30, 2008 Share May 30, 2008 Should be brake rotor/disc uneven. Link to post Share on other sites More sharing options...
Kinco135 1st Gear May 30, 2008 Share May 30, 2008 brakes vibrate at high speed should be quite common but not at 90km/h. Drove a nissan sunny 2004 model. i only feel the vibrate if i brake from 120km/h and above and is quite an sudden brake than i can feel it. Link to post Share on other sites More sharing options...
Try_conti 2nd Gear May 30, 2008 Share May 30, 2008 don't think TS is referring to ABS .... Link to post Share on other sites More sharing options...
Sky8807 1st Gear May 30, 2008 Share May 30, 2008 Suggest check brake pads condition - properly seated and secured. recent wheel align might be contributing if the adjustment is too much toe-in. Where did you do your Wheel align? Link to post Share on other sites More sharing options...
Gary84 1st Gear May 31, 2008 Share May 31, 2008 from my past experience...your rotors probably has warped alrdy....What's your mileage? Link to post Share on other sites More sharing options...
Takumi21 2nd Gear May 31, 2008 Share May 31, 2008 Or what type of car you driving? Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 31, 2008 Share May 31, 2008 Try cleaning up the brake pad, to get more contact surfaces.If this did not solve the problem, go for a side slip test. If the wheels does slip , try to get a better reading as close as -+0m/km. Other possiblities is loose wheel bearings and balljoints Link to post Share on other sites More sharing options...
Jupitery Neutral Newbie May 31, 2008 Author Share May 31, 2008 Car : Toyota Wish Mileage : 69000km 1mth ago, just change new tires, bad pad, wheel alignment(given to me free) at stamford tyres. New brake pad is toyota brand one. I just send to Stamdford tyres and the mechanic told me to go skim the disc/rotor too. But they say they don't have the machine and ask me to go other workshop. Mechanic ask me go Sin Ming area workhop and find myself wor. Any kind souls can recommend me the workshop? I hope to go skim now on a Sat afternoon, still open? roughly what price is the skimming? Link to post Share on other sites More sharing options...
Apollo 1st Gear May 31, 2008 Share May 31, 2008 sat after 1 pm most workshop closed liaoz if u just wanna know the $$, goto the infamous shop in Paya Ubi Ave 1 block 50 smthg... they can do, but price is like ok lah.. if u goto that area, many "performance" or 'performance' shops there.... Link to post Share on other sites More sharing options...
Eatniddle Neutral Newbie May 31, 2008 Share May 31, 2008 you can try workshop around tampines. (behind safra) To skim the rotor can only last you for awhile. i suggust you replace a new set. if you still want to keep your ride for awhile i recommend you to change new. I used to ride a wish. at 39k milliage i already kenna this problem. My friend less 10k and got warranty replacement. heard that this a common fault on wish. for skimming i heard is less then 100. replace new check the price last time was abt 250-300.cheers. Link to post Share on other sites More sharing options...
Qr25vet Clutched May 31, 2008 Share May 31, 2008 i usggest to skim your rotors and @ the same time change to a set of new brake pads...that will solve your problem most of the time... Link to post Share on other sites More sharing options...
Samwng 1st Gear May 31, 2008 Share May 31, 2008 My Ex-car condition is same as you. Just send the car to do Four wheel alignment. Link to post Share on other sites More sharing options...
Gary84 1st Gear May 31, 2008 Share May 31, 2008 u asked wrong person bro....TS is Jupitery... Link to post Share on other sites More sharing options...
Gary84 1st Gear May 31, 2008 Share May 31, 2008 Hope u have alrdy skip your rotor by now...Skimming a pair of rotors should cost btwn 50 - 100 for a normal saloon car... Link to post Share on other sites More sharing options...
Apollo 1st Gear May 31, 2008 Share May 31, 2008 fwah.. so exp..... some1 mention $50. how abt $40? Link to post Share on other sites More sharing options...
Jupitery Neutral Newbie June 1, 2008 Author Share June 1, 2008 Dear pal, txs for all your advise, i have got the rotor/disc skim yesterday at Kian Teong. Cost me $70 and whole process took less than 1 hr. Steering wheel no more vibrate liao. According to the person at Kian Teong, 2 possibility that could cause the Disc 'wrap' 1) As i have recently change brake pads, the new pads may not 'sit in well' onto disc as the disc may have acustom to the old pads. Thus, it's advisable to skim disc whenever you change pads. 2) Never never wash the wheel when the disc is in hot condition. When water quickly cold down the disc, the contraction on the disc may cause wrap. Thus, allow the car to cool down before washing wheel. If you alway send car to wash at petrol kiosk, advisable to allow car to cool down before sending it for a wash. ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
ItzJuzCarbon can customise any of your steering wheels, car parts, interior trims, side panels and accessories with Carbon Fiber!
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
ACS boy dies during high adventure course
How problematic is VW's 7 speed DSG?
Are You A Big Spender For A High End Bed Mattress?
