Yr1985 1st Gear August 11, 2008 Share August 11, 2008 (edited) As above, preferred experienced ws for these sort of install. Thanks. Edited August 11, 2008 by Yr1985 ↡ Advertisement Link to post Share on other sites More sharing options...
Powerhouse Clutched August 11, 2008 Share August 11, 2008 Those Red thick rubber type? PM me if you interested. Link to post Share on other sites More sharing options...
Imamiah Clutched December 17, 2008 Share December 17, 2008 What is the use of spring stiffeners? I just changed my types from 195/R15/55 to 205/R16/45. when driving 5 pax and going over bumps on expressways, the tyres rub the car fender. will installing spring stiffeners help? Link to post Share on other sites More sharing options...
Flyerking 3rd Gear December 18, 2008 Share December 18, 2008 can try autobac. now promotion $75 including installation. Takes about 1-2 hour only. Advisable for CNG cars and MPVs or cars with regular loads. After installation my car not so bumpy with 500kg load when i cross humps. Link to post Share on other sites More sharing options...
Subzro Neutral Newbie December 18, 2008 Share December 18, 2008 Got mine from Jeep Chee $80 with installation.. Less than 10min job.. Link to post Share on other sites More sharing options...
Leepee 1st Gear December 18, 2008 Share December 18, 2008 Is this Spring stopper placed at the twirl of the suspension spring, thus prevent the spring from compressing fully? Meaning it does not really increase the spring compression rate, just preventing the spring from 'squeezed together' aka bottoming out? Or is this spring stopper placed in the center of the spring, reducing the hard jolt when the suspension fully bottomed? Link to post Share on other sites More sharing options...
Gramlights Neutral Newbie December 18, 2008 Share December 18, 2008 Can try : Jeep Chee MacWell ADM LTM Autobac Fong Kim etc ... Link to post Share on other sites More sharing options...
Subzro Neutral Newbie December 18, 2008 Share December 18, 2008 (edited) I'll let the picture do the talking.. Edited December 18, 2008 by Subzro Link to post Share on other sites More sharing options...
Protege 1st Gear December 18, 2008 Share December 18, 2008 What is the use of spring stiffeners? I just changed my types from 195/R15/55 to 205/R16/45. when driving 5 pax and going over bumps on expressways, the tyres rub the car fender. will installing spring stiffeners help? It will help to reduce rubbing of fender or bottoming out of shocks. I did that last time. I have a set currently sitting in my storeroom if you are interested. Use for less than a month. Willing to let go around $30. Installation should cost about $10 at most workshops. Link to post Share on other sites More sharing options...
Spinworkx Clutched December 18, 2008 Share December 18, 2008 Yep, i did mine at Autobacs....$65 plus $10 for installation. I had the problem of my rear being lower than the front because i have 4 amps, sub and loads of other stuff in the boot that is way too heavy so visually, it's quite obvious that the rear is lower than the front...didn't want to change to coilovers either...so ended up adding this spring stifferner and well, my review is, it actually does work... Ride is more stable now....rear still slightly lower than front but not really noticeable anymore... Fetching people that one confirm will be lower la...never had the fender problem cause offset for the tyres are correct. The only issue is, i dunno how lng they will last but at $75....can last 1yr aready cannot complain lah :) Dun expect sports performance after adding...it's manin purpose is to help those on stock suspension with the problem of being rear heavy because of ICE or CNG or anything heavy behind that will cause the suspension to go low.. Link to post Share on other sites More sharing options...
Subzro Neutral Newbie December 18, 2008 Share December 18, 2008 Agreed on this.. Link to post Share on other sites More sharing options...
Gramlights Neutral Newbie December 18, 2008 Share December 18, 2008 I've used to have a stiffener on my previous ride and lasted me about 2 years before it goes soft on me .. quite lasting uh Link to post Share on other sites More sharing options...
Rtth84 1st Gear December 18, 2008 Share December 18, 2008 my front wheels also rubbing fenders, dun know if its the prings getting softer. will installing this help? Link to post Share on other sites More sharing options...
Protege 1st Gear December 18, 2008 Share December 18, 2008 If the front wheel is not rubbing fender due to wrong offset of rims but due to softer spring, this will help. Link to post Share on other sites More sharing options...
Iygnaug 1st Gear December 18, 2008 Share December 18, 2008 From what i read from the tips and resources, the stiffer the spring is, the better the handling, the less the comfort. please correct me on this if i am wrong. So, if a stiffener is meant to compress the springs more, make it stiffer, then wouldn't that be making the ride more bumpy? I know it can heighten the spring as it will be harder to compress it with load. It will be more stable as the springs become less bouncy for higher speed. But for driving in urban area with humps, won't it be more bumpy? By the way, spring stiffeners are being marketed as handling improving devices. My issue here is: Will the installation of stiffeners increase comfort? Link to post Share on other sites More sharing options...
Ichiyen Clutched December 18, 2008 Share December 18, 2008 [reply]Yep, i did mine at Autobacs....$65 plus $10 for installation. [reply] can i ask if the price of $75 is for 2 springs or 4 springs? any difference if all 4 have or only rear springs have? Link to post Share on other sites More sharing options...
Ktgan Neutral Newbie December 18, 2008 Share December 18, 2008 i did my one at racetech, $80 includes installation, tooke about 10 to 20 minutes. Install it becos when i fetch people who are very heavy, then my ride (rear) will be very low. Becos of this, last time my rear bumper strike kerb with full load of passenger. Link to post Share on other sites More sharing options...
Gramlights Neutral Newbie December 18, 2008 Share December 18, 2008 you can try fender roll. Or if it's still rubbing .. maybe you might wanna check on the offset of the wheels ↡ Advertisement Link to post Share on other sites More sharing options...
Where can I get rubber sheet
Where is the best buffet spread?
Where to change $1 coins FOC
Where to buy cigars in Singapore?
How much to install Retractable Awning for home?
