Kyojin 1st Gear August 28, 2008 Share August 28, 2008 Ok bros, I've done some research into GT brakes and hope to share info with you guys. I found it to be a real nightmare looking for parts. Call me fussy, but I do not believe in being cheap on braking components, so I wanted brand new rotors. Just to let you know that the front rotors for EP82 have only a 1mm run-out before reaching it's minimum of 17mm. I found that my rotors were skimmed (or turned) before and it's now down to 16mm. Intro For those who don't know the GT Brake Kit refers to the brake system off a EP82 GT. It's a four-disc system, with front ventilated and rear solids. It's an easy swap onto EP80s with a more wimpy brake system. Rotors Specs Front Rotors Diameter: 254mm Thickness: 18mm Minimum Thickness: 17mm Centre hub bore: 54mm PCD: 4x100 Front Toyota OEM: 43512-10110 (EP82) / 43512-16080 (Paseo EL44) Brembo 09.6765.10 (on indent basis only) Rear Toyota OEM: 42403-19105 These can be found at a stockist called YUNG SOON AUTO SUPPLY CO (Tel: 62986988). They can special order from Toyota Japan if they don't have it in stock. Pads Now comes the fun bit. It seems that we have a VERY limited choice for performance pads now. Ferodo (FCP308H) is sold out, Mintex (MDB1251) and Bendix (DB308) are also out. Even Thai-made N-brakes are sold out! So what are we left with? Toyota Originals Front 04465-10040 Rear 004466-18010 (no other choices - even the Oz guys have to use these) Other brands for front pads Project Mu (Stamford Tyres) Front: F182 (Bestop up to 350deg or B-Spec up to 500deg) EBC Greenstuff can be special ordered, part number: DP2453 ↡ Advertisement Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 28, 2008 Author Share August 28, 2008 Just to add, if you are indeed looking for your own parts, the best way to tell the stockist is that you need brakes for Paseo from 1992 (EL44). This only applies to front brakes (Paseo had rear drums) Link to post Share on other sites More sharing options...
So_nice 6th Gear August 28, 2008 Share August 28, 2008 so wat other better brake kits can we use for our starlets? Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 28, 2008 Author Share August 28, 2008 affordable? EP82 GT if have no budget limit, there are quite a few big brake kits out there, which i don't agree with. Link to post Share on other sites More sharing options...
So_nice 6th Gear August 28, 2008 Share August 28, 2008 i'm currently on the ep82 gt brake kits. i mean better braking kits from other toyota models? those aftermarket BBK i think is an overkill.. Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 28, 2008 Author Share August 28, 2008 u don't need anything better than EP82 GT kit. even the oz guys running modded 4E's are running EP82 kits. they uprate their front brake pads and they are good to go. Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie August 28, 2008 Share August 28, 2008 goin for pssi pss ahh, if not so big brake waste $$ oni..... Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 28, 2008 Author Share August 28, 2008 think so_nice going for psst psst... coz he ask so much about better brakes Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie August 28, 2008 Share August 28, 2008 upgrade brake master pmup and good brake pad and disc rotor gd enough lohh.... kyojin is right even those foregin country ep82 which modded is still using back ep82 front caliper which is can tell is good enough Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie August 28, 2008 Share August 28, 2008 i ever see foregin country ep82 modded the old mr-2 front 2pot caliper but noit sure it's is possible or not Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 29, 2008 Author Share August 29, 2008 MR2 AW11 has same caliper as EP82 GT - uses the same pads. Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 29, 2008 Author Share August 29, 2008 some goodies for weekend project... 1. Toyota front rotors 2. Project Mu B-Spec brake pads 3. ATE SL (Super DOT 4) brake fluid Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie August 31, 2008 Share August 31, 2008 OEM EP82 rotor? How much you paid for it? Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged August 31, 2008 Share August 31, 2008 There is a brembo rotor distributor at AMK industrial park 2. You may want to check with them. I got my CL1 rotor there. PM me if you need it. Kangtao was previously pass to me by Vtim. Link to post Share on other sites More sharing options...
So_nice 6th Gear August 31, 2008 Share August 31, 2008 brand new rotors? where u got them? Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 2, 2008 Author Share September 2, 2008 erm, as i already said in my first post the Brembo is on indent basis only. Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 2, 2008 Author Share September 2, 2008 Front rotors: $100 each Where to get? Read my first post! Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged September 3, 2008 Share September 3, 2008 I duno is the same shop anot mah...... cuz i duno the name.... ↡ Advertisement Link to post Share on other sites More sharing options...
FORCE Big Brake Kit promotional Price
Brakes specialist?
Brakes specialist?
Question on brakes for Toyota
Disc brakes vs Drum brakes
Squealing/Squeaking brakes
Knocking sound on rear left wheel when braking
'Gong-gong' sound when pressing brakes
Need some help - what brakes are these?
