Jastch Neutral Newbie September 28, 2012 Share September 28, 2012 I got a shock when I googled 'No DTC found' - both top replies gave the answer of using incompatible scanner with a proprietary fault code. Hence it is very likely that your workshop was not able to diagnose and they simply recommend you repairs based on visual inspection. Here I have to agree that you bring your car for a 2nd opinion but it's very possible that you might end up with a overhaul recommendation. Hi may I know where to buy the gel? ↡ Advertisement Link to post Share on other sites More sharing options...
W124 Clutched September 30, 2012 Share September 30, 2012 You can find it on ebay Link to post Share on other sites More sharing options...
Ilovemyride Neutral Newbie October 1, 2012 Share October 1, 2012 if you experience juddering between changes in the gear. Meaning not smooth and jerky in gear change. Link to post Share on other sites More sharing options...
Winnie_Yeo Neutral Newbie October 2, 2012 Share October 2, 2012 (edited) HI, ER-3682 : My car is a new car that brought five years ago Kb27 : Mine is an auto transmisson Btw, I had done my repairs last sat. Its seem that the workshop change the throttle body. Thank you! Edited October 2, 2012 by Winnie_Yeo Link to post Share on other sites More sharing options...
Winnie_Yeo Neutral Newbie October 2, 2012 Share October 2, 2012 Hi: Have u checked or try changing spark plugs? As this also may cause intermittent problem too. Yup! we change the spark plug at autobac. Link to post Share on other sites More sharing options...
Mazdacar 1st Gear October 21, 2012 Share October 21, 2012 (edited) Hi. Had to hijack this tread. I just collected my car mazda 3 2008 from second hand dealer after inspection from Vicom. The report shows the gearbox was in good condition. However I realize there was a humming sound from the gearbox at all gears. It sound like the reversing gear. The dealer told me its normal for all mazda 3 to have this sound. And offer me to switch gearbox with another Mazda 3 which clock a higher mileage (88000km) from his workshop. Is this advisable or should I ask for an overhaul instead? I dont know if i got a faulty gearbox. Headache man! Please help. Thanks! Edited October 21, 2012 by Mazdacar Link to post Share on other sites More sharing options...
Dazzleboy Clutched October 21, 2012 Share October 21, 2012 Could be wheel bearing or engine mount Link to post Share on other sites More sharing options...
Mazdacar 1st Gear October 21, 2012 Share October 21, 2012 My engine mount was change by the previous owner at Mazda dealer 10k ago it was reflected in the servicing receipt. Wheel bearing might not be the cause. Because the sound only exist when I step on the pedal. My gearbox is quite smooth. Could it be some early symptom of gearbox going to up lorry? Link to post Share on other sites More sharing options...
ER-3682 Twincharged October 21, 2012 Share October 21, 2012 Never HEARD of any car autobox with sound,don't go back to the dealer,go to a well known workshop to ask the cause. Link to post Share on other sites More sharing options...
Mazdacar 1st Gear October 21, 2012 Share October 21, 2012 Never HEARD of any car autobox with sound,don't go back to the dealer,go to a well known workshop to ask the cause. Thanks for the reply. Do you have any reputable gearbox specialize workshop to recommend? The dealer told me I am given one month warranty. That's why I went back to their workshop to rectify the problem. Is it advisable to swap the gearbox with the other mazda 3? Link to post Share on other sites More sharing options...
Keavze 1st Gear October 21, 2012 Share October 21, 2012 when was the ATF oil last changed? Maybe it's time to change the ATF oil. Link to post Share on other sites More sharing options...
Keithchue 5th Gear October 21, 2012 Share October 21, 2012 hi, is yours only happen when in low revs and not high revs. i have also this problem, only in low revs and not when i'm in high revs. gearbox is shifting up and down fine. just a bit hyer active. Link to post Share on other sites More sharing options...
Mazdacar 1st Gear October 21, 2012 Share October 21, 2012 when was the ATF oil last changed? Maybe it's time to change the ATF oil. The workshop just got it change ytd. But it's still the same. Link to post Share on other sites More sharing options...
Mazdacar 1st Gear October 21, 2012 Share October 21, 2012 hi, is yours only happen when in low revs and not high revs. i have also this problem, only in low revs and not when i'm in high revs. gearbox is shifting up and down fine. just a bit hyer active. Yup. I usually drive around 2k plus rpm. But when I release my gas pedal or step lightly, the humming sound will come back. And when I drive upslope, the sound kick in too. Is it the exact same symptom you are facing? Are you driving mazda 3 too? Was hoping mazda 3 owner can have some feedback. Link to post Share on other sites More sharing options...
ER-3682 Twincharged October 21, 2012 Share October 21, 2012 Thanks for the reply. Do you have any reputable gearbox specialize workshop to recommend? The dealer told me I am given one month warranty. That's why I went back to their workshop to rectify the problem. Is it advisable to swap the gearbox with the other mazda 3? These car dealers's workshop usually helps the dealers more than their customers,DO NOT let them swap the gearbox...go to the Mazda agent at Ubi Close to let them check. Link to post Share on other sites More sharing options...
Voodooman Supersonic October 21, 2012 Share October 21, 2012 Yup. I usually drive around 2k plus rpm. But when I release my gas pedal or step lightly, the humming sound will come back. And when I drive upslope, the sound kick in too. Is it the exact same symptom you are facing? Are you driving mazda 3 too? Was hoping mazda 3 owner can have some feedback. Go back to AD for a pressure test to confirm it is a gearbox problem and ask dealer to do a gearbox overhaul if that is the issue No point swapping to another old unproven gearbox as these days the actual mileage done can be deceiving due to rampant tampering of odometers. Did you experience gear slippage or just the humming sound, if it is the latter, could be other issues? Link to post Share on other sites More sharing options...
Keithchue 5th Gear October 21, 2012 Share October 21, 2012 hi, mine also have sound during 1.7-2k rpm, im on a civic, above 2krpm is fine. also, it iwll also happen when changing gears when the revs are too low to maintain the change, i.e turning right from traffic light, it will have a awful groaning sound. mine, is apparent when i step on the pedal, none when the pedal is depress. Link to post Share on other sites More sharing options...
Mazdacar 1st Gear October 21, 2012 Share October 21, 2012 Thanks guys! I thk I will book an appointment with the AD tmr. Anyone know the cost for pressure check and is it sufficient to ensure the reliability of the gearbox? Super headache to have this kind of problem. ↡ Advertisement Link to post Share on other sites More sharing options...
Bad Auto Dealer - Salesman!
Questions about Gearbox overhaul
Reputable like Lye Design in Amk Auto-point
Honda civic FD4 gearbox issue
Thai used-car market heats up as foreign startups jump in
