Leech Clutched April 7, 2009 Share April 7, 2009 Hi guys, may I know if it is worth signing up to Tan Chong's Service Package? Or should I be looking at outside workshops for my servicing? Tan Chong charges $1091 (complete with GST) for 4 consecutive services (for me: 40k, 50k, 60k & 70k). Is this cheap enuff? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Quantum 5th Gear April 7, 2009 Share April 7, 2009 Hi guys, may I know if it is worth signing up to Tan Chong's Service Package? Or should I be looking at outside workshops for my servicing? Tan Chong charges $1091 (complete with GST) for 4 consecutive services (for me: 40k, 50k, 60k & 70k). Is this cheap enuff? Thanks! not cheap, only 40k cost 300+, other 100 to 200 only, exclude the most expensive 80k switch to outside workshop lah Link to post Share on other sites More sharing options...
Leech Clutched April 7, 2009 Author Share April 7, 2009 Thanks. Do u have a good one which u will recommend? I guess I should switch after my warranty ends right? Link to post Share on other sites More sharing options...
Leepee 1st Gear April 7, 2009 Share April 7, 2009 Does Nissan extend the warranty period if one take up the maintenance package? Or is it just purely for changing of engine oil/filter/check water level/check brake pad kind of package? Meaning if needs to change bushings / O2sensor, wheel bearing, etc still have to fork out $$$ for the parts! If just purely the soutine kind of 40km/ 60km kind of Servicing, then it does not seem to be 'worth' it. Link to post Share on other sites More sharing options...
BoneStock 5th Gear April 7, 2009 Share April 7, 2009 not cheap, only 40k cost 300+, other 100 to 200 only, exclude the most expensive 80k switch to outside workshop lah For Tan Chong, both 40k and 80k are priced the same. Link to post Share on other sites More sharing options...
Blackyv Turbocharged April 7, 2009 Share April 7, 2009 btw, if 100K and need to change timing belt, what is the damage??? Link to post Share on other sites More sharing options...
BoneStock 5th Gear April 7, 2009 Share April 7, 2009 Hi guys, may I know if it is worth signing up to Tan Chong's Service Package? Or should I be looking at outside workshops for my servicing? Tan Chong charges $1091 (complete with GST) for 4 consecutive services (for me: 40k, 50k, 60k & 70k). Is this cheap enuff? Thanks! Package A for minor service is $180 Pachage B semi-major is $349 Package C major is $422 Assuming your car is 1600cc and below. 40k uses pack C 50k and 70k use pack A 60k uses pack B so total is $1131. Total savings is $40. I personally think it is not worth. Also if you sign up you will need to use the in-house engine oil. I'd rather pay by per service and have more flexibility. fyi....I also drive a Nissan but I send to outside workshop...usually spend ~$50 only, bring own oil. Link to post Share on other sites More sharing options...
Alechi 2nd Gear April 7, 2009 Share April 7, 2009 bad ... Link to post Share on other sites More sharing options...
BoneStock 5th Gear April 7, 2009 Share April 7, 2009 btw, if 100K and need to change timing belt, what is the damage??? Nissan uses timing chain. Link to post Share on other sites More sharing options...
Quantum 5th Gear April 7, 2009 Share April 7, 2009 Package A for minor service is $180 Pachage B semi-major is $349 Package C major is $422 Assuming your car is 1600cc and below. 40k uses pack C 50k and 70k use pack A 60k uses pack B so total is $1131. Total savings is $40. I personally think it is not worth. Also if you sign up you will need to use the in-house engine oil. I'd rather pay by per service and have more flexibility. fyi....I also drive a Nissan but I send to outside workshop...usually spend ~$50 only, bring own oil. wah, price increased so much I used to drivr nissan that time not so ex lah , and enjoy 1st 2.5 years free servicing Link to post Share on other sites More sharing options...
Application9999 Clutched April 7, 2009 Share April 7, 2009 Nissan uses timing chain. timing chain no need to change right? also...40k do what huh? Link to post Share on other sites More sharing options...
BoneStock 5th Gear April 7, 2009 Share April 7, 2009 wah, price increased so much I used to drivr nissan that time not so ex lah , and enjoy 1st 2.5 years free servicing ya man...price increase liao. My ride also came with the 5 or 7 servicings free. Me still hanging on to my old ride...coming to 5 years Link to post Share on other sites More sharing options...
BoneStock 5th Gear April 7, 2009 Share April 7, 2009 (edited) timing chain no need to change right? also...40k do what huh? ya, timing chain no need to change one, unless it starts to emit noise because of wear and tear. I drove one of my previous ride till 10 years and covered about 250,000km, timing chain also never change. from Nissan's website. Alot of things are check or top up only. Replacements for these are not included in the standard service pricing Lubrication & Oil Change Service 1. Change engine oil, oil filter & drain plug washer + Check & Top up to level 1. Brake / Clutch / Power Steering fluid 2. Auto or manual transmission / Differential & axle oil / H-CVT / LSD 3. Engine coolant / Washer tank water / Battery distilled water Clean & Lubricate 1. Door hinges, locks, catches / Battery terminals 2. Clean Air cleaner element Inspection - Exterior, Underhood, Suspension, Clutch & Brake , Tires Rotation 1. Check all tyres including spare tyre & pressure settings 2. Rotate / balance front tyres 3. External lighting system / Room lamp / Horn { Bulbs extra charge} ** 4. Wiper function, adjust spray nozzle angle 5. Power steering gear & linkages, hoses & pipes 6. All drive beltings / adjust tension {Renewal - Additional charges} *** 7. Drive shaft dust covers / Propeller shaft / Axle & Suspension parts 8. Check wheel bearing grease & repack if necessary 9. Clutch freeplay / Cable adjustment / Brake pedal stroke & operation 10. Check brake pad / shoes thickness {Renewal - Additional charges} ** 11. Check brake master pump / Other brake components 12. Radiator hoses condition / Fuel hoses & pipes 13. All engine mountings / Transmission mountings / Exhaust system 14. Pressure test cooling system / Check coolant mixture ratio @ 40,000km 15. Test battery condition & charging rates Engine & Electrical 1. Electronic engine tuning with engine analyser & system interrogation 2. Check fuel injection A/F valve { Additional labour charge if service is require} * 3. Adjust idling, CO level & ignition timing 4. Inspect spark plugs {Renewal - Additional material charges for Package A & B} 5. Inspect O2 sensor {Exhasut gas sensor} / Ignition wires 6. Inspect auto speed control device {ASCD} vacuum hose Serviceability Check & Brake System, Wheel Alignment 1. Cooling system check-Fan / Water pump / Temp / Hoses 2. Seat belts / Buckles / Rectrators / Anchors / Adjuster 3. Air induction valve / Filter { Renewal - Additional material charge} ** 4. Check ventiliation filter / A/con cooling efficiency {Renewal - Additional material charge} ** 5. Service all 4 wheel brakes 6. Check all brake disc rotors {Additional charges for re-surface disc} * 7. Check all wheel cylinders & brake calipers / Adjust handbrake 8. Check Uneven tire wear {Additional charge for wheel alignment} * Spare Parts & Material Renewal 1. Fuel Strainer { Except In-tank type} + 2. Front wiper blades + 3. Brake fluid + 4. CVT fluid {Renewal at every 60K interval for Nissan M12/P12/C11 Sport & Premium/Murano 3.5} ** 5. Auto or manual transmission / transaxle Fluid + 6. Coolant + 7. Air cleaner element + 8. Sparks plugs (Except Platinum Plugs) + Engine EGR System Inspection 1. Inspect EVAP vapor line {With Carbon Canister} 2. Inspect positive crankcase ventilation system 3. Inspect PCV filter {Renewal - Additional material charge} ** 4. Inspect all vacuum hoses for leakage & connection Edited April 7, 2009 by BoneStock Link to post Share on other sites More sharing options...
Picanto 3rd Gear April 8, 2009 Share April 8, 2009 ya, timing chain no need to change one, unless it starts to emit noise because of wear and tear. I drove one of my previous ride till 10 years and covered about 250,000km, timing chain also never change. from Nissan's website. Alot of things are check or top up only. Replacements for these are not included in the standard service pricing Lubrication & Oil Change Service 1. Change engine oil, oil filter & drain plug washer + Check & Top up to level 1. Brake / Clutch / Power Steering fluid 2. Auto or manual transmission / Differential & axle oil / H-CVT / LSD 3. Engine coolant / Washer tank water / Battery distilled water Clean & Lubricate 1. Door hinges, locks, catches / Battery terminals 2. Clean Air cleaner element Inspection - Exterior, Underhood, Suspension, Clutch & Brake , Tires Rotation 1. Check all tyres including spare tyre & pressure settings 2. Rotate / balance front tyres 3. External lighting system / Room lamp / Horn { Bulbs extra charge} ** 4. Wiper function, adjust spray nozzle angle 5. Power steering gear & linkages, hoses & pipes 6. All drive beltings / adjust tension {Renewal - Additional charges} *** 7. Drive shaft dust covers / Propeller shaft / Axle & Suspension parts 8. Check wheel bearing grease & repack if necessary 9. Clutch freeplay / Cable adjustment / Brake pedal stroke & operation 10. Check brake pad / shoes thickness {Renewal - Additional charges} ** 11. Check brake master pump / Other brake components 12. Radiator hoses condition / Fuel hoses & pipes 13. All engine mountings / Transmission mountings / Exhaust system 14. Pressure test cooling system / Check coolant mixture ratio @ 40,000km 15. Test battery condition & charging rates Engine & Electrical 1. Electronic engine tuning with engine analyser & system interrogation 2. Check fuel injection A/F valve { Additional labour charge if service is require} * 3. Adjust idling, CO level & ignition timing 4. Inspect spark plugs {Renewal - Additional material charges for Package A & B} 5. Inspect O2 sensor {Exhasut gas sensor} / Ignition wires 6. Inspect auto speed control device {ASCD} vacuum hose Serviceability Check & Brake System, Wheel Alignment 1. Cooling system check-Fan / Water pump / Temp / Hoses 2. Seat belts / Buckles / Rectrators / Anchors / Adjuster 3. Air induction valve / Filter { Renewal - Additional material charge} ** 4. Check ventiliation filter / A/con cooling efficiency {Renewal - Additional material charge} ** 5. Service all 4 wheel brakes 6. Check all brake disc rotors {Additional charges for re-surface disc} * 7. Check all wheel cylinders & brake calipers / Adjust handbrake 8. Check Uneven tire wear {Additional charge for wheel alignment} * Spare Parts & Material Renewal 1. Fuel Strainer { Except In-tank type} + 2. Front wiper blades + 3. Brake fluid + 4. CVT fluid {Renewal at every 60K interval for Nissan M12/P12/C11 Sport & Premium/Murano 3.5} ** 5. Auto or manual transmission / transaxle Fluid + 6. Coolant + 7. Air cleaner element + 8. Sparks plugs (Except Platinum Plugs) + Engine EGR System Inspection 1. Inspect EVAP vapor line {With Carbon Canister} 2. Inspect positive crankcase ventilation system 3. Inspect PCV filter {Renewal - Additional material charge} ** 4. Inspect all vacuum hoses for leakage & connection you think they really check all these stuff? Link to post Share on other sites More sharing options...
Gantan88 Clutched April 8, 2009 Share April 8, 2009 not cheap, only 40k cost 300+, other 100 to 200 only, exclude the most expensive 80k switch to outside workshop lah I think it gives you a piece of mind when u sign up the package. When there is a need to change brake pad and other stuffs, it is covered under the package (nissan called it NPMP). And when u service yr car with Tan Chong, anything happen you can go back and bang table. Maybe when car gets older then start to send it to outside for servicing lor... ↡ Advertisement Link to post Share on other sites More sharing options...
National Service in Singapore
Bad service from Top93, ubi
How to feedback on hospital service?
House painting
House painting
Maintenance Tips For Beginners/First Time Car Owners
Disney+ streaming service to fight Netflix
