Ceratoisthebest Neutral Newbie July 21, 2009 Share July 21, 2009 hi everyone, any experts here can help me with this issue??? My window visor has flown off and there is alot of dirty residue of glue from the foam tape and bits and bits of foam sticking to the residue of glue too.....any experts here can help me svole this problem in removing the residue and the small bits of foam sticking to my car's door?....visor was stick on the black plastic area of my car's window.....a sad owner here ↡ Advertisement Link to post Share on other sites More sharing options...
Shull Turbocharged July 21, 2009 Share July 21, 2009 use car wax/scratch remover..the alcohol content inside should be enough to remove it.. Link to post Share on other sites More sharing options...
Babysaint Neutral Newbie July 21, 2009 Share July 21, 2009 use duct tape, stick to d area n peel it off repeat d process. should b able to remove it. or spray abit of wd-40 on a cloth n wipe ( i tried that on a van but do it at ur own risk, dunno if will affext ur pain anot ) Link to post Share on other sites More sharing options...
Route88 2nd Gear July 21, 2009 Share July 21, 2009 Ahgongwolve got ban then u come back ? Link to post Share on other sites More sharing options...
Watwheels Supersonic July 21, 2009 Share July 21, 2009 Use a piece of wet cloth and cover over the affected area. Let it soak for an hour. After that it will be easy to remove. Link to post Share on other sites More sharing options...
Ceratoisthebest Neutral Newbie July 21, 2009 Author Share July 21, 2009 (edited) wd-40...hmm...sounds good....i never knew car cut wax can do the job...thaxs!....errmmm...have u guys heard of using zippo or tinner???...does that works too Edited July 21, 2009 by Ceratoisthebest Link to post Share on other sites More sharing options...
Ceratoisthebest Neutral Newbie July 21, 2009 Author Share July 21, 2009 (edited) Ahgongwolve got ban then u come back ? Edited July 21, 2009 by Ceratoisthebest Link to post Share on other sites More sharing options...
Ceratoisthebest Neutral Newbie July 21, 2009 Author Share July 21, 2009 Use a piece of wet cloth and cover over the affected area. Let it soak for an hour. After that it will be easy to remove. hmmm....but like quite hard lei...the surface is veritcal.....very hard to let it soak properly etc. like puting on weight to press down the wet cloth to the affected area Link to post Share on other sites More sharing options...
Watwheels Supersonic July 21, 2009 Share July 21, 2009 (edited) Pls dun be stingy. Use a bigger piece of cloth. Preferably a towel. Edited July 21, 2009 by Watwheels Link to post Share on other sites More sharing options...
Alpha78 6th Gear July 21, 2009 Share July 21, 2009 Use lighter fluid. Works most of the time. Link to post Share on other sites More sharing options...
Ceratoisthebest Neutral Newbie July 21, 2009 Author Share July 21, 2009 (edited) Pls dun be stingy. Use a bigger piece of cloth. Preferably a towel. but the glue is super hardcore man.....sian......okie...i will giv it a try then....thaxs Edited July 21, 2009 by Ceratoisthebest Link to post Share on other sites More sharing options...
Ceratoisthebest Neutral Newbie July 21, 2009 Author Share July 21, 2009 Use lighter fluid. Works most of the time. abit stupid question.....which is zippo right? Link to post Share on other sites More sharing options...
Ninafrost 1st Gear July 21, 2009 Share July 21, 2009 yes, its called ronsonol.(yellow bottle one) I used that when removing the same stuffs on my car. But i think u need a whole bottle and lots of patience scrapping it off because u have to soak the sponge residual to the core to soften it. Nina Link to post Share on other sites More sharing options...
Ceratoisthebest Neutral Newbie July 21, 2009 Author Share July 21, 2009 yes, its called ronsonol.(yellow bottle one) I used that when removing the same stuffs on my car. But i think u need a whole bottle and lots of patience scrapping it off because u have to soak the sponge residual to the core to soften it. Nina what u mean by soak the sponge residual to the core???? Link to post Share on other sites More sharing options...
Ninafrost 1st Gear July 21, 2009 Share July 21, 2009 By sponge residual i am referring to the black "foamy" residual u described left on ur car door. Your visor is glued to the car door by this industrial double sided tape which has glue on both sides of the sponge strip. The glue that attaches ur visor to the door is very likely to have hardened over a period of time. Therefore, you have to put ALOT of zippo on it/soak it so as to soften/dissolve the glue in order to peel it off. Its like using rosonol to remove sticker price tage. U got to let the ronsonol soak the sticker paper for a minute or so before attempting to peel it off. If in doubt try the ronsonol on the corner of a more inconspicous spot first. Cheers Nina Link to post Share on other sites More sharing options...
Ceratoisthebest Neutral Newbie July 21, 2009 Author Share July 21, 2009 By sponge residual i am referring to the black "foamy" residual u described left on ur car door. Your visor is glued to the car door by this industrial double sided tape which has glue on both sides of the sponge strip. The glue that attaches ur visor to the door is very likely to have hardened over a period of time. Therefore, you have to put ALOT of zippo on it/soak it so as to soften/dissolve the glue in order to peel it off. Its like using rosonol to remove sticker price tage. U got to let the ronsonol soak the sticker paper for a minute or so before attempting to peel it off. If in doubt try the ronsonol on the corner of a more inconspicous spot first. Cheers Nina lol....i get what u mean now....very detailed explaination...sorry to trouble u...thaxs alot Link to post Share on other sites More sharing options...
Mit81 Clutched July 21, 2009 Share July 21, 2009 Bro, go n buy 3M adhesive remover. Works like a charm. Link to post Share on other sites More sharing options...
Ceratoisthebest Neutral Newbie July 21, 2009 Author Share July 21, 2009 (edited) Bro, go n buy 3M adhesive remover. Works like a charm. hmm...more effective than zippo or car cut wax n etc etc???....lol....i nv really saw them before...any handyman shop have??? or where? and it cost how much ar??? Edited July 21, 2009 by Ceratoisthebest ↡ Advertisement Link to post Share on other sites More sharing options...
Give aways
Give aways
Help with STA report remarks
Window grill lock
Window grill lock
HELP! Upstairs neighbour causing sleepness nights
