Babyt 4th Gear October 10, 2009 Share October 10, 2009 Just received a set of SPC coupons left on my windscreen at MSCP. the discount values from $2( for every $30 pumped), $3(dun remb) and $4( for every $70). I think using the coupon together with POSB Everyday...could SPC be the cheapest petrol in town? lets not talk about using special credit cards which offer more discounts than general cc. ↡ Advertisement Link to post Share on other sites More sharing options...
Akula Turbocharged October 11, 2009 Share October 11, 2009 $2 off for every $40 dollars, $3 off for every $55 dollars, $4 off for every $70 dollars. POSB Everyday card rebate is currently at 3%. Link to post Share on other sites More sharing options...
Chinesenew Neutral Newbie October 11, 2009 Share October 11, 2009 So its cheaper to use Citibank which gives 5% on all petrol station? Link to post Share on other sites More sharing options...
Babyt 4th Gear October 11, 2009 Author Share October 11, 2009 what about SPC onsite discount + posb + coupon? Link to post Share on other sites More sharing options...
Kb27 Supersonic October 11, 2009 Share October 11, 2009 SPC onsite + SPC card is 10% discount, if you pump <$50 the previous month. The $2 off $40 is applied after this. So if you pump $40, after 10% discount is $36. Then minus $2 more. You pay $34. If you charge to everyday card, then you get another 3% rebate from card company. Link to post Share on other sites More sharing options...
Blackyv Turbocharged October 11, 2009 Share October 11, 2009 $2 off for every $40 dollars, $3 off for every $55 dollars, $4 off for every $70 dollars. POSB Everyday card rebate is currently at 3%. infact,it has more than that... the discount range from $2 to $8(above $150 of petrol.., dont ask me who will pump petrol up to $150, ask those driving jaguar.. ) Link to post Share on other sites More sharing options...
Akula Turbocharged October 11, 2009 Share October 11, 2009 IF you pump $140, will be able to utilize 2 X $4 coupon. That's around 81.5 litres of 95 Ron. Both my cars dun have such big tanks, though did hit more than this amt when petrol was $2.20+...... Link to post Share on other sites More sharing options...
Pentrain Clutched October 11, 2009 Share October 11, 2009 esso has the same coupon.. Link to post Share on other sites More sharing options...
Acevin Clutched October 11, 2009 Share October 11, 2009 Sorry to off-track. I never try SPC before (hence no SPC card), can check if after pump, can apply for SPC card and get immediately to enjoy the 5% on the spot for the pump? Thks. Esso & Shell both can get card on the spot to enjoy discount immediately, but not sure for SPC. Tks. Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear October 11, 2009 Share October 11, 2009 SPC can apply on spot and get discount on spot.. but it will be the base tier of 5%.. Link to post Share on other sites More sharing options...
Boyboy 1st Gear October 11, 2009 Share October 11, 2009 last time i calculated with vouchers, it's over 25% off the listed price at pump with everyday card and SPC card. my SPC discount was at the middle tier. in fact i got 29% once, but i did use some daily $ from my regular spending to offset the petrol also, hence the 29%. if dun cheat, it was abt 25%. SPC fuel not bad imho. their diesel like more power than caltex.. even with dunno what caltex diesel with techron . but i pumping caltex regularly cos the discount is 18% which no other mainstream pump can match. Link to post Share on other sites More sharing options...
Acevin Clutched October 11, 2009 Share October 11, 2009 SPC can apply on spot and get discount on spot.. but it will be the base tier of 5%.. Tks. so the 1st time upon getting the SPC card is 5% instead of the 10%, and subsequently is 10% huh? Thks. Link to post Share on other sites More sharing options...
Sdexxxxd 2nd Gear October 11, 2009 Share October 11, 2009 i recently swop from Shell to SPC. Although SPC is cheaper (plus I downgrade to 92), it seem like the consumption is a little worse. I used to get 10-11 km/l, now can only manage at max 10 km/l perhaps it need time to adjust well? we'll see Link to post Share on other sites More sharing options...
Blackyv Turbocharged October 11, 2009 Share October 11, 2009 i recently swop from Shell to SPC. Although SPC is cheaper (plus I downgrade to 92), it seem like the consumption is a little worse. I used to get 10-11 km/l, now can only manage at max 10 km/l perhaps it need time to adjust well? we'll see if u pump 95 previously and change to 92, in any brand also will cause a drop..... Link to post Share on other sites More sharing options...
Pentrain Clutched October 11, 2009 Share October 11, 2009 hi Acevin, the 10% discount from SPC is base on how much u pump in the previous month..u can check from the application from.. Link to post Share on other sites More sharing options...
Pentrain Clutched October 11, 2009 Share October 11, 2009 hi sdexxxxd, i recently downgrade from esso 5000 to esso 2000. first tank..mileage seems quite bad, have yet to refuel hence FC not calculated.. heard that the car's ecu need some adjustment so the first few tanks will suffer..haha will try 2 more tanks if mileage still bad..den i'm back on esso 5000 Link to post Share on other sites More sharing options...
Volvobrick Supersonic January 20, 2018 Share January 20, 2018 For those using SPC, SPC near Coronation is closing down and giving out $3 coupons (min $50 spend) to be used at other SPCs (Feb and Mar) after this one closes permanently on 31 Jan. 6 Link to post Share on other sites More sharing options...
Ysc3 Twincharged January 20, 2018 Share January 20, 2018 nowadays, SPC give out "rewards" directly into the card account ... so every time go pump must ask the cashier to check ... if don't check, they won't auto to use the e-coupons. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Esso discount voucher
New car discount/price/promo
Pandamart S$0.99 delivery & up to 50% discounts off products on March 22 to 24
New SPC&U card 17% discount in Oct
Taxi Promo Codes
Taxi Promo Codes
9/9 Shopping Deal Consolidation Thread
Discounts for traffic fines can be considered: Shanmugam in response to Pritam’s instalment payment suggestion
