Iforu Neutral Newbie October 16, 2009 Share October 16, 2009 any1 know where to buy? i ask many shops liao, all dont have. thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Babyt 4th Gear October 16, 2009 Share October 16, 2009 u mean sea salt? Link to post Share on other sites More sharing options...
Peqasus 1st Gear October 16, 2009 Share October 16, 2009 spa sea salt's workable too. either u using as fengshui cure issit? or kill ghost?? Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged October 16, 2009 Share October 16, 2009 any1 know where to buy? i ask many shops liao, all dont have. thanks go east coast get some sea water and put it at somewhere with sunlight.. leave it till dry and u will get raw salt... Link to post Share on other sites More sharing options...
Route88 2nd Gear October 16, 2009 Share October 16, 2009 Dead sea salt, the best salt in the world Link to post Share on other sites More sharing options...
Nikamura Neutral Newbie October 16, 2009 Share October 16, 2009 simple leh. go east any sea side.. take the water and heat it till salt is left . Link to post Share on other sites More sharing options...
Boyboy 1st Gear October 16, 2009 Share October 16, 2009 pls dun use sea salt from singapore waters. it's very polluted. Link to post Share on other sites More sharing options...
Iforu Neutral Newbie October 16, 2009 Author Share October 16, 2009 u mean sea salt? sea salt = raw salt?? Link to post Share on other sites More sharing options...
Iforu Neutral Newbie October 16, 2009 Author Share October 16, 2009 spa sea salt's workable too. either u using as fengshui cure issit? or kill ghost?? yes for fengshui use!! so where can buy raw salt? thanks!! Link to post Share on other sites More sharing options...
Babyt 4th Gear October 16, 2009 Share October 16, 2009 go those beauty spas/ toilette stores haha maybe too exp for u to use as fengshui tool haha Link to post Share on other sites More sharing options...
Hermitage 1st Gear October 16, 2009 Share October 16, 2009 Dunno what ya mean bro. What's raw salt? How large are the grains you refer to as raw salt? Sea salt is the type that has those large, irregularly shaped and flattened grains. Fine salt is the type we get out of a salt shaker; really tiny crystals, regular in size and resembling the fine, powdery sand we find on our beaches. Or is it really Crystal Meth you're after Link to post Share on other sites More sharing options...
Ultramega 1st Gear October 16, 2009 Share October 16, 2009 yes for fengshui use!! so where can buy raw salt? thanks!! If it's for fengshui why don't you try fengshui shops? Or those crystal shops since their products are somewhat related to fengshui and salt is essentially crystal too? Link to post Share on other sites More sharing options...
Iforu Neutral Newbie October 18, 2009 Author Share October 18, 2009 go east coast get some sea water and put it at somewhere with sunlight.. leave it till dry and u will get raw salt... really like this = raw salt????!?!?? Link to post Share on other sites More sharing options...
Nikamura Neutral Newbie October 18, 2009 Share October 18, 2009 Zzzzzz time to open mouth riao since no one mentioned it.. TS.. do try to check out those aquariums shop . they do sell sea salt used for saltwater tanks for ur home fish tanks. but i m not sure is it the one u are looking for or not. Link to post Share on other sites More sharing options...
Amortifiedpenguin Clutched October 18, 2009 Share October 18, 2009 really like this = raw salt????!?!?? Table salt (sea or fine) contains sodium chloride as well as sodium iodide as WHO regulates that to prevent some deficiency, iodine needs to be added into salt. if you wana get really pure salt, ie. sodium chloride (NaCl). Mix EXACTLY 1 portion of aqueous sodium hydroxide (NaOH) with 1 portion of aqueous hydrochloric acid (HCl) of EQUAL concentration. Test the pH using a digital pH meter. If done properly and accurately the pH should read 7.0. IF it is less than 7, add more NaOH, if its more than 7, add more HCl till it is EXACTLY pH 7.0. Thereafter, evaporate the mixture (naturally or under low heat) to obtain fine sodium chloride crystals. IF you require one sizable crystal, try crystallization by seeding. Link to post Share on other sites More sharing options...
Picnic06-Biante15 Supersonic October 18, 2009 Share October 18, 2009 any1 know where to buy? i ask many shops liao, all dont have. thanks You could get those salt from aquarium wholesalers at Seletar Farmway 1. Link to post Share on other sites More sharing options...
Hotamp 3rd Gear October 19, 2009 Share October 19, 2009 You could get those salt from aquarium wholesalers at Seletar Farmway 1. I got a packet once from one shop that sells organic health food beside the west coast community centre. Link to post Share on other sites More sharing options...
D_bergkam 1st Gear October 19, 2009 Share October 19, 2009 That's really scientific. Let me give my input on salt seeding then. 1. Stir salt into boiling hot water until no more salt will dissolve (crystals start to appear at the bottom of the container). Be sure the water is as close to boiling as possible. Hot tap water is not sufficient for making the solution. 2. If you want crystals quickly, you can soak a piece of cardboard in this supersaturated salt solution. Once it is soggy, place it on a plate or pan and set it in a warm and sunny location to dry out. Numerous small salt crystals will form. 3. If you are trying to form a larger, perfect cubic crystal, you will want to make a seed crystal. 4. To grow a big crystal from a seed crystal, carefully pour the supersaturated salt solution into a clean container (so no undissolved salt gets in), allow the solution to cool, then hang the seed crystal in the solution from a pencil or knife placed across the top of the container. You could cover the container with a coffee filter if you like. 5. Set the container in a location where it can remain undisturbed. You are more likely to get a perfect crystal instead of a mass of crystals if you allow the crystal to grow slowly (cooler temperature, shaded location) in a place free of vibrations. Table salt (sea or fine) contains sodium chloride as well as sodium iodide as WHO regulates that to prevent some deficiency, iodine needs to be added into salt. if you wana get really pure salt, ie. sodium chloride (NaCl). Mix EXACTLY 1 portion of aqueous sodium hydroxide (NaOH) with 1 portion of aqueous hydrochloric acid (HCl) of EQUAL concentration. Test the pH using a digital pH meter. If done properly and accurately the pH should read 7.0. IF it is less than 7, add more NaOH, if its more than 7, add more HCl till it is EXACTLY pH 7.0. Thereafter, evaporate the mixture (naturally or under low heat) to obtain fine sodium chloride crystals. IF you require one sizable crystal, try crystallization by seeding. ↡ Advertisement Link to post Share on other sites More sharing options...
Pink salt contains more lead and other metals (than white salt)?!
Salt and pepper spice.
Salt Lamp
Salt Lamp
Epsom Salt as detox way
Bugatti Veyron driven into salt lake
Salt water as alternate fuel in the future?
Sugar and Salt, which is more evil?
