Yuan 6th Gear November 7, 2009 Share November 7, 2009 uneven wear on rear tyres are affected by many factors such as overinflate/underinflate air pressure, rim warp, incorrect balancing, suspension, irregular or no rotate n balance. the practice and proven of performing front 2 wheel balancing has been going on for so many yrs and majority of car owners has no such problem. Of course as i said, to have a peace of mind, pamper the tyres abit and dun mind paying abit more for the effort, one can always opt for all 4 wheels to be balance when comes to rotate and balance maintenance....:) Actually the cost would have pay off in terms of better driveability and safety on the road since the tyres are the car's only contact with the road. ↡ Advertisement Link to post Share on other sites More sharing options...
Picanto 3rd Gear December 24, 2009 Share December 24, 2009 at what speeds would the vibration be felt if the tyres/wheels are not well balanced? Link to post Share on other sites More sharing options...
Ivanoh Neutral Newbie June 26, 2017 Share June 26, 2017 hi bros, if I move my rim and tyres together to another car do I need balancing? Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 26, 2017 Share June 26, 2017 If it feels perfectly okay in the initial car, then no need after transferred. Link to post Share on other sites More sharing options...
Roberttan 5th Gear June 27, 2017 Share June 27, 2017 hi bros, if I move my rim and tyres together to another car do I need balancing? if I were you I will pay for it since I am there workshop, because at the same time to double check the condition of the rim and tires. to me Once you have doubt just go for it (it not going to cost you bomb ? also at the same time you tire mechanic can help make sure your rims fits properly to another car (items like mounting nuts , center hub adaptor etc 2 Link to post Share on other sites More sharing options...
Ivanoh Neutral Newbie June 27, 2017 Share June 27, 2017 if I were you I will pay for it since I am there workshop, because at the same time to double check the condition of the rim and tires. to me Once you have doubt just go for it (it not going to cost you bomb ? also at the same time you tire mechanic can help make sure your rims fits properly to another car (items like mounting nuts , center hub adaptor etc wanted to do it but the workshop which the dealer bring me to charge $100 for wheels swap and balancing... before hand I called and someone from the workshop say $20 only... so buay song do there.. Link to post Share on other sites More sharing options...
Roberttan 5th Gear June 30, 2017 Share June 30, 2017 wanted to do it but the workshop which the dealer bring me to charge $100 for wheels swap and balancing... before hand I called and someone from the workshop say $20 only... so buay song do there.. no need to be buay song, did you ask $20 how they do? and $100 how they do? Link to post Share on other sites More sharing options...
Ivanoh Neutral Newbie July 1, 2017 Share July 1, 2017 nope.. when he say $100, I asked him only swap tyres how much he say $50... so felt he wanna carrot me already.. so don't really consider doing extra stuff over there Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 1, 2017 Share July 1, 2017 nope.. when he say $100, I asked him only swap tyres how much he say $50... so felt he wanna carrot me already.. so don't really consider doing extra stuff over there sorry for my stupid assumption you asked only swap tyres/tires how much ? my understanding is the wheel or rim stay and separate tires from rim and swap the 8 tires ? or tires with rims(without remove from rims ) swap ? above 2 diff scenarios , second simple swap ? first more work ? anyway is good that you clarify it before they proceed. it is a free market , every establishment run diff JUst MHO Link to post Share on other sites More sharing options...
Willywonka1989 1st Gear October 25, 2017 Share October 25, 2017 Hi can anyone recommend a reputable workshop with balancing services? I just swapped over the tyres and rims from the same type of car but intending to do some balancing to have a peace of mind. Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear November 14, 2017 Share November 14, 2017 question for those still using the older Michelin Pilot Super Sports tyre. Does the thread pattern allow PSS to be swapped from the left<>right ? eg rear left >> rear right, anf vice versa. Any issue? Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 15, 2017 Share November 15, 2017 question for those still using the older Michelin Pilot Super Sports tyre. Does the thread pattern allow PSS to be swapped from the left<>right ? eg rear left >> rear right, anf vice versa. Any issue? pilot super sport is an Asymmetric pattern design= can be used for any corner of your car. Only workshop person need to know how to put this tire on the wheel ,(outside and inside) 2 Link to post Share on other sites More sharing options...
inlinesix Supersonic November 15, 2017 Share November 15, 2017 pilot super sport is an Asymmetric pattern design= can be used for any corner of your car. Only workshop person need to know how to put this tire on the wheel ,(outside and inside) Your explanation too complicated. Simplistically, left tyre has to be removed left rim and reinstall in right rim. ↡ Advertisement Link to post Share on other sites More sharing options...
Tourador Tyres
Tourador Tyres
Tyre puncture
Tyre puncture
Yokohama Advan Apex V601
