Somebody 1st Gear November 19, 2009 Share November 19, 2009 Hey guys, do you have any suggestions on improving the handling of a city vtec 2007? am looking at the cheapest and most effective way to improve the handling of the car. find it a little too wobbly at times. it would be great if you could give your suggestions and estimated costs of implementing it. thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Bcyn Neutral Newbie November 19, 2009 Share November 19, 2009 lowering springs - $400 front strut bar - $250 front anti roll - $400 rear strut bar - $200 rear anti roll - $400 coilovers - $1000 larger rims + tires - unlimited. the above are jus rough gauge of prices. all still depends one brand and quality and also where u buy them from. Link to post Share on other sites More sharing options...
Yuan 6th Gear November 20, 2009 Share November 20, 2009 Hey guys, do you have any suggestions on improving the handling of a city vtec 2007? am looking at the cheapest and most effective way to improve the handling of the car. find it a little too wobbly at times. it would be great if you could give your suggestions and estimated costs of implementing it. thanks! In my opinion, there is no cheap and most effective way. You can first consider strut bars, either brand new or 2nd hand. There are a few brands like Summit, Alutec or Ultra Racing. If you are still not satisfied, then can consider whether you want to change your stock suspension to a set of coilovers. In daily driving of Singapore roads, adding strut bars to all the probable points of your car would be sufficient. Can try that first. Once your suspension goes up the lorry, you might want to consider a good set of coils to beef up the handling. Tyres play an important part as they are the only contacts to the road. You might want to look up more into wider and bigger tyres as well. Link to post Share on other sites More sharing options...
Somebody 1st Gear November 21, 2009 Author Share November 21, 2009 any other sequence f improvements? =) Link to post Share on other sites More sharing options...
Tanly Neutral Newbie November 21, 2009 Share November 21, 2009 Coilovers and anti roll bars will do the trick. Cos you cannot really feel any diff with strut bars tie bars under brace bars unless you go track. Check if your City rear is using independent suspension or torsion beam cos from wat I know some cars like Vios or many hatchbacks uses rear torsion beam instead of independent rear shocks.If your rear use torsion beam you can forget abt rear anti roll bar liao. Forget abt lowering springs they are purely for looks,handling wise is shitty and it spoils ur absorbers real fast Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 21, 2009 Share November 21, 2009 First thing first, upgrade from your stock tires to larger diameter tires (low aspect ratio) with tough sidewalls to minimise bulging during corners. Install coilovers to reduce squats and body rolls during move offs. I highly recommend installing strut bars in your engine bay. I dont recommend installing anti roll bars (sway bars) first till you install better tires and coilovers. Anti roll bars is to minimise body roll during hard cornering. Anti flex bar is to prevent flexing in your chassis and body panels. This is important because now that your tires are harder and more rigid, the stress from flexing will be transferred to your body panels and chassis. The strut bar(s) is to absorb and resist the flexing. Anyway, the city is inherently bad in handling due to the decision to position the fuel tanks beneath the seats resulting in a taller tip toe stance. Link to post Share on other sites More sharing options...
Junyi Neutral Newbie December 2, 2009 Share December 2, 2009 just get a gd set of coils will do.. unless still nt up to ur expectation then add bars bah Link to post Share on other sites More sharing options...
Somebody 1st Gear December 5, 2009 Author Share December 5, 2009 gd set of coils? how would that compare to a new set of shocks and springs? less than 1000? Link to post Share on other sites More sharing options...
Cwinedine 1st Gear December 7, 2009 Share December 7, 2009 new STOCK shocks & springs will result back in STOCK ride & feel..it won't give u a better handling =p Link to post Share on other sites More sharing options...
Somebody 1st Gear December 11, 2009 Author Share December 11, 2009 i didn't say install stock shocks and springs =) haha.... Link to post Share on other sites More sharing options...
Itsec 2nd Gear December 12, 2009 Share December 12, 2009 City, being a high CG car, it is a challenge to do stability mods... its depends what u want and your budgets... handling mods are not cheap my recommendation is to get a set of coilover or sports suspension.. 4get about the strut bars.. if u wan to cut down the cost, go to fjc and buy used coilovers from them.. the common ones are bc, tein, tomei, and the rares are mugen/J's racing suspension... remember to do some researches about the coilovers regards to linkage bar, serviceability, and cost of shocks replacement... dont 4get ur braking mods such as better brake pad, 285mm rotor, ssbh, brake stopper, etc... u tends to go faster than in stock condition after install coilovers... i will say brake/stability mods shall do together... Link to post Share on other sites More sharing options...
Somebody 1st Gear December 12, 2009 Author Share December 12, 2009 thanks! =) Link to post Share on other sites More sharing options...
Somebody 1st Gear March 19, 2011 Author Share March 19, 2011 some guy mentioned to go to fjc to buy second hand coilovers, anyone here can pont me to info about "FJC"? can't seem to find it. thanks! Link to post Share on other sites More sharing options...
Karebu 1st Gear March 19, 2011 Share March 19, 2011 fjc is fit jazz club. http://sg-fit-jazz.com/forum-phpbb3/phpBB3/ ↡ Advertisement Link to post Share on other sites More sharing options...
JB Forest City
JB Forest City
Jacky Wu Son Threatened To Bomb Taipei City Hall
Recommended Season Parking for Mapletree Business City
Honda City 4th Gen
Honda City 4th Gen
Come Share Your View on "Car-Lite City"
KSL City shopping mall in JB
SPC Minds Wash towards Vivo City/Harbourfront(Pasir Panjang)
