Knightsljx Neutral Newbie December 11, 2009 Share December 11, 2009 hi bros, does anyone have any good recommendation for removing brake dust that have sort of hardened? like caked onto the rim. especially for matt rims. thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Maddriver 4th Gear December 11, 2009 Share December 11, 2009 bro..original matt or re-spray b4? if re-spray before..avoid wheel cleaners..if original..try wheel cleaners and if brake dust still dun comes out..use degreaser and a brush..this is how i deal with my berlingo caked up brake dust.. Link to post Share on other sites More sharing options...
Speddevil Neutral Newbie December 11, 2009 Share December 11, 2009 halo bro benny Link to post Share on other sites More sharing options...
Collinite_SG Neutral Newbie December 11, 2009 Share December 11, 2009 Try using APC. Link to post Share on other sites More sharing options...
Jasonlim8213 Neutral Newbie December 11, 2009 Share December 11, 2009 Try using APC. APC??? Link to post Share on other sites More sharing options...
Booboon 1st Gear December 11, 2009 Share December 11, 2009 all purpose cleaner. Link to post Share on other sites More sharing options...
Fcuktion Neutral Newbie December 11, 2009 Share December 11, 2009 If its a painted set of wheels, i would say go for wheel brighterner that has some acid in its content. Made life damm easy for me with BMWs, they have damm scary brake dust. if can't really fully remove, some may be tar deposits. Use some Tar Remover. Link to post Share on other sites More sharing options...
Knightsljx Neutral Newbie December 12, 2009 Author Share December 12, 2009 thanks for the advice, degreaser WD40 ok? i tried to scrap them off with a piece of plastic, most of it came out but some still trapped due to matt surface. morale of the story, dun go for matt rims Link to post Share on other sites More sharing options...
Ivan96935sg Neutral Newbie December 12, 2009 Share December 12, 2009 Just use those rims cleaner........guess will work well. Link to post Share on other sites More sharing options...
Fcuktion Neutral Newbie December 12, 2009 Share December 12, 2009 I believe WD40 would do for the tar deposits. Try it out on the inner barrels 1st. good luck! Link to post Share on other sites More sharing options...
Bigass Neutral Newbie December 19, 2009 Share December 19, 2009 ImHO, sonax rim cleaner Link to post Share on other sites More sharing options...
Sk65 1st Gear May 24, 2010 Share May 24, 2010 ImHO, sonax rim cleaner i bought that yest used in the afternoon did 2 rounds of cleaning. back rims looks like new front, was shiny from far (can tell obvious difference) satisfied. stanford tyres selling $15 + (thats where i bought) then went to autobac selling $13.90 (s--t....) satisfied. Link to post Share on other sites More sharing options...
Mini-itx Clutched May 24, 2010 Share May 24, 2010 Just get some wheel cleaners from autobacs. Lots of them there. Link to post Share on other sites More sharing options...
Mach23 2nd Gear May 24, 2010 Share May 24, 2010 thanks for the advice, degreaser WD40 ok? i tried to scrap them off with a piece of plastic, most of it came out but some still trapped due to matt surface. morale of the story, dun go for matt rims Caution not to spray WD40 on brake disc or pads else cld be disasterous at least first couple of brake sequences Link to post Share on other sites More sharing options...
Picanto 3rd Gear May 25, 2010 Share May 25, 2010 Caution not to spray WD40 on brake disc or pads else cld be disasterous at least first couple of brake sequences spray it on a piece of cloth and wipe. Link to post Share on other sites More sharing options...
Melvinyuen 2nd Gear May 25, 2010 Share May 25, 2010 maybe can remove the wheel one by one and scrub? use WD40 and clean the wheels one by one then put it back. Confirm clean and shiny. And will not harm the brakes too. :D Link to post Share on other sites More sharing options...
Puteh83 1st Gear May 25, 2010 Share May 25, 2010 just a thot on these cleaners.. do drop by major supermarkets in batam the next time u r there. it's dirt cheap. Link to post Share on other sites More sharing options...
Ken4555 1st Gear May 25, 2010 Share May 25, 2010 a suggestion... go to that big workshop along bendermeer road... before Eminent Plaza... they got this machine can put ur rim in and come out like new... think they have a promo now like $5 per rim... i think... foe me i never have this problem... when i 1st got my rims... i applied a thick coat of wax/sealant... when ever wash car just hose the rims and its shiny... just like the paintwork.. prevention is better than cure... ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Brake squeak every morning
Dust Mite
Dust Mite
