Octopus 3rd Gear January 10, 2010 Share January 10, 2010 ================ Is this fully synthetic? Seems a very good price. Must support this vendor. Its semi synthetic. Mix of 20% ~ 25% PAO + remaining group 2 oil. I got best mileage from using Schaeffer #7000 5w30, the viscosity at 40 deg.C (close to local temp on a hot day) is among the lowest, even surpassing those famous fully synthetic oil, thus easier flow at start-up. ↡ Advertisement Link to post Share on other sites More sharing options...
Mivec9 1st Gear January 10, 2010 Share January 10, 2010 Its semi synthetic. Mix of 20% ~ 25% PAO + remaining group 2 oil. I got best mileage from using Schaeffer #7000 5w30, the viscosity at 40 deg.C (close to local temp on a hot day) is among the lowest, even surpassing those famous fully synthetic oil, thus easier flow at start-up. bro can pm me where to buy and the pricing? thanks! how's your ride? i just cheong bk from genting trip.....quite fun trip. Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 10, 2010 Share January 10, 2010 bro can pm me where to buy and the pricing? thanks! how's your ride? i just cheong bk from genting trip.....quite fun trip. Kspchew mentioned he got it at $8.50 per quartz, which is much cheaper than my source at M.X. trading. So I'd like to know where he got it. Ride's ok, just exceed 50k km last month, so far so good. Link to post Share on other sites More sharing options...
Weesern Clutched January 10, 2010 Share January 10, 2010 my service booklet says I need to use ACEA A3/B3... Schaeffer do not have such rating?? Link to post Share on other sites More sharing options...
Kspchew 2nd Gear January 10, 2010 Share January 10, 2010 For $11, I can get 5W-40 fully synthetic EO from Schaeffer. Link to post Share on other sites More sharing options...
Kspchew 2nd Gear January 10, 2010 Share January 10, 2010 (edited) Its semi synthetic. Mix of 20% ~ 25% PAO + remaining group 2 oil. I got best mileage from using Schaeffer #7000 5w30, the viscosity at 40 deg.C (close to local temp on a hot day) is among the lowest, even surpassing those famous fully synthetic oil, thus easier flow at start-up. Spot on, its one of the reasons why I am using this EO. you can get it at www.lubeszone.com, now they are having offer on 7k series and 9k series. P/s:Mod, if providing such an info is not allowed, please remove. tks Edited January 10, 2010 by Kspchew Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 10, 2010 Share January 10, 2010 my service booklet says I need to use ACEA A3/B3... Schaeffer do not have such rating?? I think Schaeffer mostly A1 and A5, except maybe #9000 5w40? I think A3 and A5 are very similiar, except that A3 need a HTHS of >3.5, alot of 30 weight engine oil don't meet that, except maybe Redline? Redline 30 weight got a HTHS of 3.8. Is yours a continental or turbo-charges engine? Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 10, 2010 Share January 10, 2010 Spot on, its one of the reasons why I am using this EO. you can get it at www.lubeszone.com, now they are having offer on 7k series and 9k series. P/s:Mod, if providing such an info is not allowed, please remove. tks Thank you for sharing this info. Link to post Share on other sites More sharing options...
Yuan 6th Gear January 10, 2010 Share January 10, 2010 Kspchew mentioned he got it at $8.50 per quartz, which is much cheaper than my source at M.X. trading. So I'd like to know where he got it. Ride's ok, just exceed 50k km last month, so far so good. Thanks for sharing. I will try to source it at MX Trading. Link to post Share on other sites More sharing options...
Weesern Clutched January 11, 2010 Share January 11, 2010 I think Schaeffer mostly A1 and A5, except maybe #9000 5w40? I think A3 and A5 are very similiar, except that A3 need a HTHS of >3.5, alot of 30 weight engine oil don't meet that, except maybe Redline? Redline 30 weight got a HTHS of 3.8. Is yours a continental or turbo-charges engine? driving a opel... looking for w30 oil for next change Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 11, 2010 Share January 11, 2010 Can consider Castrol Edge 0w30, that one ACEA A3. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged January 11, 2010 Share January 11, 2010 Can consider Castrol Edge 0w30, that one ACEA A3. castrol edge got w30 oil??? if thats the case, I might switch back to Castrol once i finish my stock.... Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 11, 2010 Share January 11, 2010 castrol edge got w30 oil??? if thats the case, I might switch back to Castrol once i finish my stock.... I believe previously it was labelled Castrol SLX. However, I do not know where to get locally... This Castrol Edge 0w30 is very thick, the viscosity at 100 deg.C is 12.2, almost like a 40 weight oil, hence the high HTHS. It however, is not an energy saving oil, so expect your fuel consumption to go up if previously you're using 30 weight energy saving oils. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged January 11, 2010 Share January 11, 2010 I believe previously it was labelled Castrol SLX. However, I do not know where to get locally... This Castrol Edge 0w30 is very thick, the viscosity at 100 deg.C is 12.2, almost like a 40 weight oil, hence the high HTHS. It however, is not an energy saving oil, so expect your fuel consumption to go up if previously you're using 30 weight energy saving oils. wat??? then forget it. FC is my 1st priority. the rest is not important. Link to post Share on other sites More sharing options...
Yuan 6th Gear January 12, 2010 Share January 12, 2010 (edited) Can consider Castrol Edge 0w30, that one ACEA A3. I tried this oil prior to my last servicing. It is quite good and lasted me 10k. I did not see any change or difference in my fuel consumption. Edited January 12, 2010 by Yuan Link to post Share on other sites More sharing options...
Weesern Clutched January 12, 2010 Share January 12, 2010 how much is it?? need cheap w30 oil.... on very tight budget Link to post Share on other sites More sharing options...
Mivec9 1st Gear January 12, 2010 Share January 12, 2010 how much is it?? need cheap w30 oil.... on very tight budget if u r on tight budget, go MY carrefour, I do see they carry w30 oil from reputable companies at much cheaper price than here. Link to post Share on other sites More sharing options...
Yuan 6th Gear January 12, 2010 Share January 12, 2010 if u r on tight budget, go MY carrefour, I do see they carry w30 oil from reputable companies at much cheaper price than here. You mean c-lube? ↡ Advertisement Link to post Share on other sites More sharing options...
Synthetic leather car seats
Synthetic Fuels is the future!
Engine break down with bardahl oil
How Bardahl Asia Pacific work behind Asia distributors
MAX FACTOR GARAGE - The Brake Specialist for almost 40 Years
Lexus Engine Oil - Fully Synthetic 5W40
Chemlube Organic Ester Based Synthetic Oil
