  • Search this thread
  • Reply to this topic
417 replies to this topic | 0 praises
#381
Posted 11 September 2010 - 01:34 AM
Ken4555
  • Premium member
    Ken4555
    NOS-ed
    Author Image
    10,852
bro...
this penzoil i just tried... tc-w3 but does not feel as smooth as the previous putoline i tried... maybe cause not fully syn but i doubt it... maybe additives different... to be very smooth cant be ashless maybe... watever so i ended up putting more than i usually put... even up to 100ml (or more) for 40 liters on my second tank of this penzoil...
apparently i experienced once (one time only) a juddering start when i crank my car.. starter motor and batt are fine... possibile too much 2-T or TC-w3 2T sunk to the bottom and thicker concentrated amount went in the fuel line?
cause never had this problem with putoline 100% syn racing 2T before...
==FEMALE ORGASM TIKO RANGER== because the gal MUST cum....
#382
Posted 11 September 2010 - 06:41 AM
Trex101
  • Trex101
    6th Gear
    Author Image
    2,746
bro...
Nope, once the 2T is pour into the petrol, it will dissolve into it, it does not separate. TCW3 is widely "experiment" in BITOG precisely because it is ashless and supposedly harmless to the CAT system. No one has experiment with other type of 2T yet.
In another note, i always use 2T TCW3 so never try other type of 2T before but i think even at 100ml/40L dosage should still be ok for the engine. Anyway, Amsoil 2T HPI has just arrived, once your Pennzoil 2T has ran out, you might want to try it.
Edited by Trex101, 11 September 2010 - 06:43 AM.
<b>My Orange Ford Territory Ghia - Philips Xtreme Vision 130+, NGK ZFR6FIX-11 Iridium, Redline 0w30, Redline Racing ATF, Redline Heavy Weight Shockproof </b>
#383
Posted 11 September 2010 - 07:33 AM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    38,046
Yeap, too much 2T.
One time, my engine will missing some beats and I stopped to remove the plugs.
It was wet. I replaced with another set and it was ok, back to normal.
You might need to put less, about 50ml per 40L instead.
#384
Posted 11 September 2010 - 10:12 AM
Ken4555
  • Premium member
    Ken4555
    NOS-ed
    Author Image
    10,852
thanks for the re-assurance bro... have a good weekend!
#385
Posted 11 September 2010 - 10:17 AM
Ken4555
  • Premium member
    Ken4555
    NOS-ed
    Author Image
    10,852
Yeap, too much 2T.
hmmm.... usually my normal is 40ml to 40 liters... so i have my 2T packed in little 40ml bottles... but sometimes i fill up slightly earlier so it will be like 40ml to 30+ liters... i guess over time if i pump earlier many times than will be abit more concentrated after many full tanks...
but anyways i rev the car often and at least once a month i will drive all the way until my fuel needle is going to touch the end of the E mark... which is like maybe 80+km after light on....
makes me feel better that i am clearing all the fuel off but then also feels like more chance to clog the filter... if you know what i mean...
also heard stories of petrol filter slimy and gooey when taken out... hmmmm.....
#386
Posted 11 September 2010 - 11:05 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    38,046
I used 2T oil, Putolene and Pennzoil for quite a while. Then I did take out the fuel filter at about 60k as I wanted to replace it.
I wasn't succesful at that time, probably I missed some o-rings or something.
But I did look at the fuel filter and it was surprisingly very clean. I knock it a few times and no slime came out.
I was diy replacing the long life fuel filter at that time.
On the other hand, I had seen another Opel Corsa fuel filter that ooze out slime...and I know this guy 100% does not use any fuel additive.
So I guess it depends more on the fuel itself than the additive.
#387
Posted 12 September 2010 - 09:53 PM
Ken4555
  • Premium member
    Ken4555
    NOS-ed
    Author Image
    10,852
hey bro... from your post... do you even ever go to a workshop ah? you seem to practically do every thing yourself... though i'm sure for tyres and rotation you need a tyre shop right?.... laugh.gif
then just wondering your car PI or AD? if AD then how you maintain your warranty?....
#388
Posted 12 September 2010 - 10:03 PM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    38,046
For servicing, in the beginning I go to JB after the first 3 free servicing. Now, no more. I do all the service myself, except for wheel balancing which I can't do. laugh.gif
My car is a Hyundai (AD). It's simple car, nothing much can go wrong. So I didn't have to worry about warranty as well. tongue.gif
#389
Posted 12 September 2010 - 10:07 PM
Ken4555
  • Premium member
    Ken4555
    NOS-ed
    Author Image
    10,852
will be asking you for some tips on DIY real soon... hope you can share some infor bro.... thanks!!!
#390
Posted 20 September 2010 - 08:38 AM
Mini-itx
  • Mini-itx
    Banned
For me, I can only do engine oil and transmission oil and coolant, sparkplugs.. The final final drive oil I can't change because I don't have the proepr tools. That one I will have to get WS to do for me.
#391
Posted 07 January 2011 - 10:09 AM
Tom_kkh
  • Tom_kkh
    6th Gear
    Author Image
    3,885
poured some 2T 1ml:10liters.
really smooth drive, which is what i wan. FC unsure.
since i am 3000km to my next servicing, will monitor if it any side effects on spark plug.
mobile 1 liter 2T full syn, ashless, for $12.
should last me 20 tanks.
so wht will a spoil Cat converter will do to the car?
Edited by Tom_kkh, 07 January 2011 - 10:10 AM.
#392
Posted 07 January 2011 - 11:28 AM
Mrel
  • Mrel
    1st Gear
    Author Image
    92
Mind sharing where you got the mobil 2T?
TIA!
#393
Posted 07 January 2011 - 11:43 AM
Tom_kkh
  • Tom_kkh
    6th Gear
    Author Image
    3,885
TIA!
esso petrol kiosk. don buy the wrong 1.
there is another same brand cheaper but not ashless.
#394
Posted 07 January 2011 - 01:34 PM
Mrel
  • Mrel
    1st Gear
    Author Image
    92
Thanks bro!
#395
Posted 07 January 2011 - 08:31 PM
ER-3682
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    12,004
Mobil $12 ones are just semi Syn,$17 then is 100% Syn.
Mazda 6..2.5.
#396
Posted 07 January 2011 - 08:32 PM
ER-3682
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    12,004
I am very sure because i using it on my Yamaha RX-Z,Motocycle.
Mazda 6..2.5.
#397
Posted 08 January 2011 - 12:08 PM
Tom_kkh
  • Tom_kkh
    6th Gear
    Author Image
    3,885
thanks for the information, will double check again.
#398
Posted 08 January 2011 - 12:20 PM
Mona-vie
  • Mona-vie
    4th Gear
    Author Image
    784
I have been using 2T oil for ages as well. 1ml:1L of petrol.
#399
Posted 08 January 2011 - 12:30 PM
Ken4555
  • Premium member
    Ken4555
    NOS-ed
    Author Image
    10,852
so whats your take on different brands of 2T?.......
#400
Posted 08 January 2011 - 03:40 PM
ER-3682
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    12,004
Now also trying Castrol Power Racing,$16,$1 cheaper than Mobil 1 2T,less smoke is noticed,same smoothness.
Mazda 6..2.5.
Dynamics Mechanic Pte Ltd
Quick Reply
Tags: Mixing, into, petrol, tank
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
