Yuan 6th Gear April 13, 2010 Author Share April 13, 2010 Low oil level, low pressure, screen blockage, diluted oil, low vicosity oil,damge pump gasket, etc What would have caused any of these? ↡ Advertisement Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear April 13, 2010 Share April 13, 2010 alamak. i think you so worried, just go perform an oil change now lor. spend some $$$ to alleviate your fears and give you peace of mind rather than worrying if your car is going to explode. if you do a proper oil change with the right amounts and this still happens, then you worry again lol Link to post Share on other sites More sharing options...
Yuan 6th Gear April 13, 2010 Author Share April 13, 2010 alamak. i think you so worried, just go perform an oil change now lor. spend some $$$ to alleviate your fears and give you peace of mind rather than worrying if your car is going to explode. if you do a proper oil change with the right amounts and this still happens, then you worry again lol No la....Just curious about his comments. Not worry. Anyway, I did my oil change a short while ago. Mechanic diagnosed as more oil was used during the last change. 3 litres is enough. He checked the coolant and the exhaust and they are alright. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 13, 2010 Share April 13, 2010 Maybe people don't even know when washers are damaged or look out for tell tale signs/symptoms. =============== Dunno leh. Many places recommend to change the washer every time the drain plug is removed but nobody seems to b doing it here & so far no complaints about oil leaking out? Maybe its not so critical & wil only b changed as & when it starts to leak. Ive done numerous oil changes but so far, I also never had the problem of oil leaking due to a damaged washer. Link to post Share on other sites More sharing options...
Octopus 3rd Gear April 13, 2010 Share April 13, 2010 =============== Dunno leh. Many places recommend to change the washer every time the drain plug is removed but nobody seems to b doing it here & so far no complaints about oil leaking out? Maybe its not so critical & wil only b changed as & when it starts to leak. Ive done numerous oil changes but so far, I also never had the problem of oil leaking due to a damaged washer. Crush washer purpose is not to seal like a gasket. It basically allow some axial tension on the thread, to prevent the plug from coming loose due to vibration. Link to post Share on other sites More sharing options...
Chiangauto Clutched April 13, 2010 Share April 13, 2010 -In certain cases, the oil level may have risen since the last time you checked. This could be due to condensed water (from combustion), condensed fuel or a coolant leak - all are causes for concern. -Fuel-diluted motor oil (from blow-by or leakage) can substantially reduce oil viscosity and thin additive concentration. The odor of diesel fuel can often be detected right from the dipstick. -Free and emulsified water is harmful to the oil and the engine. For short-trip drivers, water condensation may be more acute if your engine has the flexible fuel vehicle (FFV) option and you are burning an alcohol-gasoline fuel blend. It is important to remember that combustion produces water in your engine - more water than the fuel consumed. Most of the water goes out the tailpipe, but if the engine is cool, much of it may condense in the crankcase. -A simple way to detect water in used motor oil is to put a drop of oil from the dipstick on a hot exhaust manifold. If it crackles (sounds like bacon frying) this is an indication of water contamination. Beware that there is some risk that the drop of oil may catch fire. -Brand new automobiles imported from Japan may have a high oil level due to short-run engine starts (as many as 50) required when the vehicle is transported from the assembly plant, across the ocean, and finally to the dealer Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 14, 2010 Share April 14, 2010 No need to change just heat up the washer red hot with a butuan torch - this method will de-stress the material. Link to post Share on other sites More sharing options...
Yuan 6th Gear April 14, 2010 Author Share April 14, 2010 -In certain cases, the oil level may have risen since the last time you checked. This could be due to condensed water (from combustion), condensed fuel or a coolant leak - all are causes for concern. -Fuel-diluted motor oil (from blow-by or leakage) can substantially reduce oil viscosity and thin additive concentration. The odor of diesel fuel can often be detected right from the dipstick. -Free and emulsified water is harmful to the oil and the engine. For short-trip drivers, water condensation may be more acute if your engine has the flexible fuel vehicle (FFV) option and you are burning an alcohol-gasoline fuel blend. It is important to remember that combustion produces water in your engine - more water than the fuel consumed. Most of the water goes out the tailpipe, but if the engine is cool, much of it may condense in the crankcase. -A simple way to detect water in used motor oil is to put a drop of oil from the dipstick on a hot exhaust manifold. If it crackles (sounds like bacon frying) this is an indication of water contamination. Beware that there is some risk that the drop of oil may catch fire. -Brand new automobiles imported from Japan may have a high oil level due to short-run engine starts (as many as 50) required when the vehicle is transported from the assembly plant, across the ocean, and finally to the dealer Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 14, 2010 Share April 14, 2010 Crush washer purpose is not to seal like a gasket. It basically allow some axial tension on the thread, to prevent the plug from coming loose due to vibration. ============== But the plug washer is not crush washer. Its just a normal type. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 14, 2010 Share April 14, 2010 No need to change just heat up the washer red hot with a butuan torch - this method will de-stress the material. =============== OK thanks but I never see any mech do this even. They just put the plug back & tighten. But so far I or anybody I know has had oil leaking from the plug due to washer failure. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic April 14, 2010 Share April 14, 2010 Not all brands need to change the washer. Nissan doesn't need to but Toyota have to change the washer every oil change. Link to post Share on other sites More sharing options...
Octopus 3rd Gear April 14, 2010 Share April 14, 2010 ============== But the plug washer is not crush washer. Its just a normal type. Do they look like this? If so, they are crush washers. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 14, 2010 Share April 14, 2010 (edited) Do they look like this? If so, they are crush washers. =============== No. They r those flat type without any break. I think u sud know lah. The oil plug has a washer which u can see when the mech removes the plug. Sud b made of copper usually. Oh sorry. I took a closer look & yes these r the type of washers used. I tot a crush washer was like what is on the spark plug where its a 1 time use only washer. Edited April 14, 2010 by Pisces69 Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 14, 2010 Share April 14, 2010 Not all brands need to change the washer. Nissan doesn't need to but Toyota have to change the washer every oil change. ============= Every type of car i drove, not once did I see the mech change the washer? Thats why I was wondering if its really that necessary. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic April 14, 2010 Share April 14, 2010 ============= Every type of car i drove, not once did I see the mech change the washer? Thats why I was wondering if its really that necessary. I am not sure too bro. But what my mechanic told me is Toyota drain plug suppose to change the washer every oil change. Guess it's more preventive than anything. He even show me one whole bag of washers for Toyota vehicles. Link to post Share on other sites More sharing options...
Yuan 6th Gear April 15, 2010 Author Share April 15, 2010 I am not sure too bro. But what my mechanic told me is Toyota drain plug suppose to change the washer every oil change. Guess it's more preventive than anything. He even show me one whole bag of washers for Toyota vehicles. Now that I see and you guys mention, I remember during one of the servicings last year, my mechanic changed something like that.....He did not charge me for it as it was part of my major servicing. Link to post Share on other sites More sharing options...
Ixat 1st Gear April 15, 2010 Share April 15, 2010 Bros, I don't need a extractor afterall. Realise my EO level is actually lower despite having more oil filled. (TS hope you don't mind me asking here) X is the oil level and if u don't see a F, than oil level is at F point on dipstick. 0w40 - 4.4L filled E---------X @ cold after 8hrs (Exactly at F point) E---------F--X @ 90deg after 30min (Above F point) 20w50 - 4.75L filled E------X--F @ cold after 8hrs (Below F point, read this is the recommended level) E---------X @ 90deg after 30min (Exactly at F point) This are measured within 50km of servicing and confirm no EO leak or consumption. As you can see more oil is filled but it results in lower levels on the dipstick compared to a thinner oil. Anyone can explain on this? Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 15, 2010 Share April 15, 2010 I am not sure too bro. But what my mechanic told me is Toyota drain plug suppose to change the washer every oil change. Guess it's more preventive than anything. He even show me one whole bag of washers for Toyota vehicles. ============== OK next time I check with my mech the condition of the washer. If its worn, I wil get him to replace it for safety sake. ↡ Advertisement Link to post Share on other sites More sharing options...
Marriage registration fees in Singapore to increase
No increase in gambling addicts since 2 casinos opened.
8 town councils to increase service & conservancy charges
ERP rates increase/decrease thread monitor!
A level results for University Courses
Happy Chinese New Year 2023!
SCHNELL Engine Oil 5W40
