Nlatio Turbocharged April 16, 2010 Share April 16, 2010 For those looking for kakis to play badminton can find them here. Badminton Central - Singapore Subforum Enjoy your games! haaa finding kakis to play is one thing.... trying to book a court is another..... guess because it is indoor sports, can play anytime..... more demand for it..... tennis on the other hand.... very hard to play under the hot sun... go swimming better.... ↡ Advertisement Link to post Share on other sites More sharing options...
Toledo 1st Gear April 16, 2010 Share April 16, 2010 i am using pro-ace too. used to play with yonex but pro-ace is cheaper. u can also set the string tension higher for pro-ace compared to yonex. pro-ace is popular in malaysia so shd be cheaper there. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear April 16, 2010 Author Share April 16, 2010 Brand Update other than Yonex: 1. Apacs 2. Carlton 3. Dunlop 4. Fleet 5. Gosen 6. Head 7. Prince 8. Proace 9. Wilson Regards, Link to post Share on other sites More sharing options...
Chongyong Neutral Newbie April 16, 2010 Share April 16, 2010 try fleet...value for money.. unless you are really pro which need >27 lbf on the string else fleet will do the job. My fleet can stand on 25 lbf and only cause me RM 100 with grip and string... Link to post Share on other sites More sharing options...
Teoky Clutched April 16, 2010 Share April 16, 2010 Brand Update other than Yonex: 1. Apacs 2. Carlton 3. Dunlop 4. Fleet 5. Gosen 6. Head 7. Prince 8. Proace 9. Wilson Regards, There are many other brands, Li Ning and Victor are pretty popular in Singapore. You can also find Zelm (good stuff), Kason, Panda Power (good stuff), Fischer, Winnex, Finnex, Karakal, Pro-Kennex, Flypower, Flymax etc in Singapore. Brands not available easily here are Mizuno (really good), Kumpoo (sponsor of Thai team) and Gosen. This is by no means exhaustive list, there's alot of other brands. My advice is that if you are on a budget, don't go for the low end Yonex, they really don't play very well compare to other brands in the same price range. Link to post Share on other sites More sharing options...
Booboon 1st Gear April 16, 2010 Share April 16, 2010 Wilson, head carton all cmi. very soft frame. u clash yr racket will break. Link to post Share on other sites More sharing options...
Booboon 1st Gear April 16, 2010 Share April 16, 2010 Victor is good. teoky uses superwaves and bs series. but its ex in sgp. chris really mark up the price alot. Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged April 16, 2010 Share April 16, 2010 kawasaki was my fav Link to post Share on other sites More sharing options...
Teoky Clutched April 17, 2010 Share April 17, 2010 (edited) Victor is good. teoky uses superwaves and bs series. but its ex in sgp. chris really mark up the price alot. Waaah, how come you know I use SW and BS ? So scary !!! Are you a BCF member ? My SW33P was purchased before Victor sponsored the Korean so the price is around S$130+. As it is not a popular model, I think you can still get it cheaper than the newer series which to me is abit overpriced. For my BS10, I got it from Bangkok and it cost me S$130+ only. I believe Singapore is more than S$170+. Edited April 17, 2010 by Teoky Link to post Share on other sites More sharing options...
Kelpie 2nd Gear April 17, 2010 Author Share April 17, 2010 There are many other brands, Li Ning and Victor are pretty popular in Singapore. You can also find Zelm (good stuff), Kason, Panda Power (good stuff), Fischer, Winnex, Finnex, Karakal, Pro-Kennex, Flypower, Flymax etc in Singapore. Brands not available easily here are Mizuno (really good), Kumpoo (sponsor of Thai team) and Gosen. This is by no means exhaustive list, there's alot of other brands. My advice is that if you are on a budget, don't go for the low end Yonex, they really don't play very well compare to other brands in the same price range. Ok, shall not look at brand now. What I've gathered from a friend is this: 1. Stiffer racket vs Flexible one. My moment is swift but I old man so lack of power. I should go for stiffer racket (more power) or flexible one (better control)? 2. High Tension vs Low Tension. I no power so I need to go with a low tension one. 23~24lb ok or not? 3. Sweet Spot Round shape, oval shape, "squarish" one, which is better for me? Many Thanks to Gurus out there. Regards, Link to post Share on other sites More sharing options...
Kklee 6th Gear April 17, 2010 Share April 17, 2010 IMHO, playing style will determine the kind of racket required. When you hold the racket and swing, you will basically feel that it is a) heavier at the head end - better for smashing perhaps b) balance - general play c) heavier at the handle portion - accuracy and net play perhaps For sweet spot, my take is that if the style is more on the power end, the sweet spot should be larger and rounder. A long time ago, my experience is such that my racket wasn't suitable for my style, I kept hitting outside the sweet spot causing vibration and misplaced shots. Link to post Share on other sites More sharing options...
Booboon 1st Gear April 17, 2010 Share April 17, 2010 Let me try to help. 1. get a medium flex racket. too stiff u will get shoulder pain after playing. 2. string get yonex bg66, 22 to 23lbs 3. isometric head is better, bigger playing area less chance to mishit. get from jb honly, half price when u get apacs and proace. sgp is too expensive liao. Link to post Share on other sites More sharing options...
Toledo 1st Gear April 17, 2010 Share April 17, 2010 do note that if u intend to get yonnex, there are FAKE ones, esp the more expensive rackets. u can check badminton central on how to spot the fakes. pro-ace is more durable. my last $300+ yonnex broke after 1 mth of purchase when i clashed it with my partner. heart pain. switched to pro-ace after that. Link to post Share on other sites More sharing options...
Booboon 1st Gear April 17, 2010 Share April 17, 2010 Yonex is known for soft frame, so tat u break n buy new ones. haha. apacs hav very strong frame, 28lbs no problem. Link to post Share on other sites More sharing options...
Lethalstrike Turbocharged April 17, 2010 Share April 17, 2010 wow... now so many brands to consider other than Yonex: a) Apacs b) Carlton c) Dunlop d) Fleet d) Head e) Prince f) Proace g) Wilson Regards, Ashaway is pretty good too Link to post Share on other sites More sharing options...
Kohler Neutral Newbie April 17, 2010 Share April 17, 2010 Nowaday all the $30-50 range racket are already very good and light. Don't need to get those expensive racket Link to post Share on other sites More sharing options...
Kelpie 2nd Gear April 18, 2010 Author Share April 18, 2010 Nowaday all the $30-50 range racket are already very good and light. Don't need to get those expensive racket I went to Queensway shopping centre today to have a feel of the local prices of Badminton Rackets. Wow...so many brands these days, and quite a number of China made rackets around. I still find Yonex and Carlton design more appealing after so many years. May be I'm old school lah . Wilson also not too bad. It seems also that a decent one will probably cost around S$80, at least. This mean I have to pay around RM187 for one. I have made up my mind to get one in JB. Jusco Membership day is coming, which mean I will get my racket even cheaper . Regards, Link to post Share on other sites More sharing options...
Booboon 1st Gear April 18, 2010 Share April 18, 2010 U hav to get frm racket shop. go to honly buy, taman sentosa. opp the ya wang shop. rm180 can get u 2 rackets. apacs, proace. dont buy yonex in jb cos more ex. ↡ Advertisement Link to post Share on other sites More sharing options...
Audio Shop Recommendation
Any recommendation for ear digging?
Congratulations to LKY for winning Singapore's FIRST GOLD in the BWF World Championships
MCF Badminton (pattern) workout
Recommendation for locksmith
Recommendation for Spectacles
