Nmnhnlm Clutched May 8, 2010 Share May 8, 2010 Who here is still using STP Oil treatment? I am still using it for my old Toyota. Its one of the cheapest and oldest oil treatment out there that actually works. No magic about the product. Mainly some viscosity enhancers and lots of Zinc! Thats about all. Cause my car needs a 50wt oil, thus I decide to use 40wt oil and STP instead. IT actually works better than just plain 50wt oil and its cheaper! lol... However, be warned that STP oil treatment contains lots of zinc which may affect your cat. Mine is old car so I don't really care. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Kurty Supercharged May 22, 2014 Share May 22, 2014 sorry to bring up an old thread, i just wanna know more about this product before i pour it into the engine. basically, i have an old mitsu engine, famous for engine ticker they called it. some told me to add lucas oil treatment while some, miracle oil. while the another is a Renault D4f clio engine, its 8 yrs old.. kinda rough but can live with it since EOL in 2 yrs time. i still got lots of engine oil - carlube 5w40 lying in my storeroom, thanks to my huge purchase last year. intend to change every 6-7k interval since i find it not lasting till 10k mark As for the engine ticker and roughness of D4F, thinking of pouring some STP oil treatment, its only $5.90 as sold by one of the merchants in here. Maybe a bottle shared by 2 engine.. since it was said that it thicken the oil, with zine as a cleaning agent. hopefully, the tickering sound will be off. Then buy the stp fuel system cleaner, $21 and use it for the old mitsu engine.. i just took over for a year, it's 14 years old.. the cleaner should last me for 2 round. after which, blaze all the way to KL, that should clear whatever junk content.. D4F, nothing to blaze, it already retired.. now is only performing 110km at most but i still loving it. i know some may regards as snake oil but since it only $5.90 and an one time application, it don't hurt much to the wallet. 1 Link to post Share on other sites More sharing options...
ntuc2018 3rd Gear October 7, 2018 Share October 7, 2018 Lately use this cos I find my car use engine oil quite fast. Unexpectedly, it managed to improve my fc slightly.. Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear October 7, 2018 Share October 7, 2018 Lately use this cos I find my car use engine oil quite fast. Unexpectedly, it managed to improve my fc slightly..This is not a permanent solution Link to post Share on other sites More sharing options...
ER-3682 Twincharged October 7, 2018 Share October 7, 2018 Never use STP Oil Treatment on quite new Car,it make the Oil Thick,it won't flow so well... Link to post Share on other sites More sharing options...
inlinesix Supersonic October 8, 2018 Share October 8, 2018 Any EO that requires oil treatment needs to be dumped 1 Link to post Share on other sites More sharing options...
allypk2000 March 11, 2019 Share March 11, 2019 Hi, STP Oil Treatment should be used with cars with 40k+, it enhances performance and drive. Noise reduction is evident as well. I recommend it with cars having 40k+, else you dont need this product. 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged March 11, 2019 Share March 11, 2019 Hi, STP Oil Treatment should be used with cars with 40k+, it enhances performance and drive. Noise reduction is evident as well. I recommend it with cars having 40k+, else you dont need this product. Not for modern Cars with Valve Timing,Oil too thick can cause damage to Valvetrain... Link to post Share on other sites More sharing options...
AlbertCheow Neutral Newbie January 23, 2022 Share January 23, 2022 Im driving a qashqai 1.2T now on 6th year. Mileage is high. 170K. I use STP for my car along with 5W 40 due to suspected oil burning.. well yes it contains zinc for better wear protection.. after use the oil consumption slows down quite a bit... my car need a thicker oil to protect the engine, so viscosity wear is my primary reason... may feel a little rough initially but its ok for it to blend and mix well with 40 oil for best protection... a little worried at start but u will see the difference... Link to post Share on other sites More sharing options...
ER-3682 Twincharged January 23, 2022 Share January 23, 2022 3 hours ago, AlbertCheow said: Im driving a qashqai 1.2T now on 6th year. Mileage is high. 170K. I use STP for my car along with 5W 40 due to suspected oil burning.. well yes it contains zinc for better wear protection.. after use the oil consumption slows down quite a bit... my car need a thicker oil to protect the engine, so viscosity wear is my primary reason... may feel a little rough initially but its ok for it to blend and mix well with 40 oil for best protection... a little worried at start but u will see the difference... Go & read Thread in Conti Talk..."Renault sued over 1.2 turbo engine also used in Qashqai''. 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic January 25, 2022 Share January 25, 2022 I use the diesel treatment to pass inspection 2 Link to post Share on other sites More sharing options...
ER-3682 Twincharged January 25, 2022 Share January 25, 2022 3 hours ago, Mustank said: I use the diesel treatment to pass inspection Put into Fuel Tank.?For lesser Black Smoke.?Buy 18 Litres of Kerosene mix with little Diesel before going for Inspection,sure pass. 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic January 25, 2022 Share January 25, 2022 3 hours ago, Mustank said: I use the diesel treatment to pass inspection That’s because you use lousy Diesel.🤭 1 Link to post Share on other sites More sharing options...
Beregond Supersonic January 26, 2022 Share January 26, 2022 (edited) 19 hours ago, Mustank said: I use the diesel treatment to pass inspection I use liqui moly diesel smoke stop. right before inspect pour into full tank fuel. then go remote area ram high rpm ( make sure no car behind )😆 Edited January 26, 2022 by Beregond 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic January 26, 2022 Share January 26, 2022 7 minutes ago, Beregond said: I use liqui moly diesel smoke stop. right before inspect pour into full tank fuel. then go remote area ram high rpm ( make sure no care behind )😆 Last time no camera time I disturb people Phoon orh yen now do sure kena orh gong jialat jialat ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Do officials still check the 3/4 tank rule at causeway?
Who still remember Bruce Lee
Covid 19 treatment
Covid 19 treatment
Jack Ma: If you're still poor at 35, you deserve it!
Any pest control company to recommend
Would you visit a Dentist during COVID 19 Pandemic?
