Wolfy3769 2nd Gear May 24, 2010 Share May 24, 2010 Had use some new type of wax (those with resin) and found that the result was not that good.... some area.. after waxing... the surface is shinny and smooth...but some area... after waxing.. the surface was abit "rough"... run ur finger.. u can feel the "roughness"... I had a few question... a) how to ensure all area after waxing are shinny and smooth..... first time using this kind of wax... unable to get consistent result.... last time using those liquid wax.. soft wax... dont even had this kind of problem.... some expert can help to advise?? b) how to remove the old wax... thinking had to remove the old wax before apply a new layer of wax ...especailly those "rough" area.... Thanks in advanced... ↡ Advertisement Link to post Share on other sites More sharing options...
Enzomatrix 2nd Gear May 24, 2010 Share May 24, 2010 Was the surface rough b4 waxing? May I ask what wax are u using? U can try clay and polish to strip and prep the car surface b4 waxing. Link to post Share on other sites More sharing options...
Maddriver 4th Gear May 24, 2010 Share May 24, 2010 (edited) Had use some new type of wax (those with resin) and found that the result was not that good.... some area.. after waxing... the surface is shinny and smooth...but some area... after waxing.. the surface was abit "rough"... run ur finger.. u can feel the "roughness"... I had a few question... a) how to ensure all area after waxing are shinny and smooth..... first time using this kind of wax... unable to get consistent result.... last time using those liquid wax.. soft wax... dont even had this kind of problem.... some expert can help to advise?? b) how to remove the old wax... thinking had to remove the old wax before apply a new layer of wax ...especailly those "rough" area.... Thanks in advanced... Hi..not an expert but just to share.. 1) is it time to clay?? 2) Ensure it is a last step use..A wax rather then a polish agent. 3) maybe can try panel by panel There are many ways of removing old waxes..Do want those metal streaking feel when u run your finger across and a flat water sheet?? Some uses APC(All purpose cleaner)..prepsol..IPA but i find them do give a clean metal streaking feel but may not be able to strip some of those tougher sealant or wax.. I do have a paint bonding agent that loosen up old wax before u apply a fresh layer of wax or sealant..If you are really want to try..I have mentioned before will be Kerosence..I do came across some pro polisher starts using this menthod and those wax manufacturer chemist uses this too.. I will still recommend a APC or PBA just to loosen up this old waxes.. Edited May 24, 2010 by Maddriver Link to post Share on other sites More sharing options...
Maddriver 4th Gear May 24, 2010 Share May 24, 2010 Hi..not an expert but just to share.. 1) is it time to clay?? 2) Ensure it is a last step use..A wax rather then a polish agent. 3) maybe can try panel by panel There are many ways of removing old waxes..Do want those metal streaking feel when u run your finger across and a flat water sheet?? Some uses APC(All purpose cleaner)..prepsol..IPA but i find them do give a clean metal streaking feel but may not be able to strip some of those tougher sealant or wax.. I do have a paint bonding agent that loosen up old wax before u apply a fresh layer of wax or sealant..If you are really want to try..I have mentioned before will be Kerosence..I do came across some pro polisher starts using this menthod and those wax manufacturer chemist uses this too.. I will still recommend a APC or PBA just to loosen up this old waxes.. Link to post Share on other sites More sharing options...
Superjellyfish Neutral Newbie May 24, 2010 Share May 24, 2010 Hi, first things first - apologies for hijacking this thread as I cannot start a new topic... I'm somewhat of a weekend warrior when it comes to car detailing and have always liked to maintain my own car. Can someone steer me in the right direction - I am looking for a detailer that can professionally do paint work correction, i.e. removing swirls and minor oxidation from paint work and that's it? I prefer to do my own paint work maintenance so not sure if there is any such service available in Singapore. Any help is much appreciated. Thanks and sorry again for steering off topic here. Link to post Share on other sites More sharing options...
Enzomatrix 2nd Gear May 24, 2010 Share May 24, 2010 yo boss, is there going to be a dent removal session soon? Link to post Share on other sites More sharing options...
Maddriver 4th Gear May 24, 2010 Share May 24, 2010 yo boss, is there going to be a dent removal session soon? halo boss..its been awhile..hmmm..sure sure..will do it Link to post Share on other sites More sharing options...
Blueray Hypersonic December 25, 2019 Share December 25, 2019 @Carbon82 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Removing Scratches on Headlight - Head light Polishing
Removing smell lying beneath leather car seat
Removing stains in interior car fabric roof/upholstery
Removing Vinyl Wrap after 3 years
No more oil spill when removing filter
Removing scratches
Removing scratches
Removing the glare from aftermarket HID?
