nazerath Turbocharged August 11, 2018 Share August 11, 2018 Mostly snapped up by WS:( Buy 19.90 then charge customers 168...good profit:o Carousell got some for sale ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Othello Supersonic August 11, 2018 Share August 11, 2018 Why they recommend? Mind you, most Jap car post 2010 use 20w engine oil. yeah, my car manual states 16-20 1 Link to post Share on other sites More sharing options...
Johnnylim 5th Gear August 11, 2018 Share August 11, 2018 Mostly snapped up by WS:( Buy 19.90 then charge customers 168...good profit:o Think so, saw one hoot 2 cartons. 1 Link to post Share on other sites More sharing options...
Inlinefour Twincharged August 11, 2018 Share August 11, 2018 Think so, saw one hoot 2 cartons. Profit above People:D 1 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear August 11, 2018 Share August 11, 2018 Yalor, my 2006 Kia Carens 2L Theta Engine NA (World Engine) already recommend 0W/20 lor Same platform as EVO and Chrysler and also use in Stinger 2L Theta2 lor Why they recommend? Mind you, most Jap car post 2010 use 20w engine oil. Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear August 18, 2018 Share August 18, 2018 Interesting, no need to flush modern engine leh ..... I did it once maybe, for my previous ride. 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear August 19, 2018 Share August 19, 2018 Interesting, no need to flush modern engine leh ..... I did it once maybe, for my previous ride. No need if engine oil is changed frequently before it solidify to become sludge. How often will dependent on usage. I used to be able to check because the oil filler cap was not blocked. 1 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear August 19, 2018 Share August 19, 2018 (edited) Yalor, but hor, I am not sure about my Diesel Engine lor. My Carens U2 1.7L DPF EO level actually rises over time. Up to about 1cm above full mark when reach 10kkm cycle. Some say engine failure liao. But I checked internet, DPF Diesel Engine is like that one. As during DPF clean cycle, diesel is spray until DPF wet, then go lean to raise temp and burn the DPF at about 600~800C vapourizing the soot lor. So diesel end up in EO lor. Need to check if C&C on the next servicing as since day 1 the engine is LIKE THAT lor. Now 20kkm done, 10mths. old. No need if engine oil is changed frequently before it solidify to become sludge. How often will dependent on usage. I used to be able to check because the oil filler cap was not blocked. Edited August 19, 2018 by Apple-Tree 1 Link to post Share on other sites More sharing options...
Mkl22 Twincharged August 19, 2018 Share August 19, 2018 Yalor, but hor, I am not sure about my Diesel Engine lor. My Carens U2 1.7L DPF EO level actually rises over time. Up to about 1cm above full mark when reach 10kkm cycle. Some say engine failure liao. But I checked internet, DPF Diesel Engine is like that one. As during DPF clean cycle, diesel is spray until DPF wet, then go lean to raise temp and burn the DPF at about 600~800C vapourizing the soot lor. So diesel end up in EO lor. Need to check if C&C on the next servicing as since day 1 the engine is LIKE THAT lor. Now 20kkm done, 10mths. old. Better change engine oil more often cause of the dilution by diesel. 2 Link to post Share on other sites More sharing options...
Kklee 6th Gear August 19, 2018 Share August 19, 2018 (edited) Yalor, but hor, I am not sure about my Diesel Engine lor. My Carens U2 1.7L DPF EO level actually rises over time. Up to about 1cm above full mark when reach 10kkm cycle. Some say engine failure liao. But I checked internet, DPF Diesel Engine is like that one. As during DPF clean cycle, diesel is spray until DPF wet, then go lean to raise temp and burn the DPF at about 600~800C vapourizing the soot lor. So diesel end up in EO lor. Need to check if C&C on the next servicing as since day 1 the engine is LIKE THAT lor. Now 20kkm done, 10mths. old. Last time, my petrol engine also encounter EO level rise above the full mark. After much analysis, it is the EO used CMI to the point that it begin to sludge. After that, I tried many EO (include Carlube) and in the end, use a more synthetic EO. Finally, I "blend" my own EO by mixing different EO together. I attribute it to my usage pattern and style of driving. Like Mkl22 mentioned, change engine oil more often and use a better quality one. Could also be your usage pattern.. Edited August 19, 2018 by Kklee 1 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear August 20, 2018 Share August 20, 2018 Thanks for your advice. Ya, I will probably be more regimental on the EO change schedule. Link to post Share on other sites More sharing options...
awhtc 6th Gear August 21, 2018 Share August 21, 2018 Carousell got some for sale The Carousell has 5W40 engine oil for warehouse sale tomorrow at $17.90 per 4 L. Link to post Share on other sites More sharing options...
nazerath Turbocharged August 22, 2018 Share August 22, 2018 The Carousell has 5W40 engine oil for warehouse sale tomorrow at $17.90 per 4 L. Any more details on it? Link to post Share on other sites More sharing options...
awhtc 6th Gear August 22, 2018 Share August 22, 2018 Any more details on it?You can search in Carousel "22 August warehouse". Details are inside. Link to post Share on other sites More sharing options...
nazerath Turbocharged August 22, 2018 Share August 22, 2018 You can search in Carousel "22 August warehouse". Details are inside. Nothing showed up in the search but thanks for the info. Link to post Share on other sites More sharing options...
awhtc 6th Gear August 22, 2018 Share August 22, 2018 Nothing showed up in the search but thanks for the info. Try "meta engine oil". You should be able to see "Cheapest". I might buy a cartoon with delivery as I'm too lazy to go down to buy for my current car. 1 Link to post Share on other sites More sharing options...
nazerath Turbocharged August 22, 2018 Share August 22, 2018 Thanks, I was hoping it’s shell. I ever got carlube for 19.90 and that’s 5 litres. Link to post Share on other sites More sharing options...
Metalslug2 3rd Gear August 22, 2018 Share August 22, 2018 (edited) Anyone know where else can I get this? Tampines giant sold out in less than 2 days.. i wanted to buy 2 bottles. change my mind just grabbed a box. super good deal for shell helix i just used it in my honda civic 07. so far so good. quiet and smooth... Edited August 22, 2018 by Metalslug2 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Need advice: cheapest car replacement route?
Petrol Discounts in Singapore
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
Anyone into laopok Mercs?
Migrating down under? Come share your experiences
Cheapest Gym Comparison
Cheap Parking whole day near Suntec
