Tweakmax2 Neutral Newbie June 21, 2010 Share June 21, 2010 Which is better? more lowered, more comfortable?Which is more ex? ↡ Advertisement Link to post Share on other sites More sharing options...
Forummer Neutral Newbie June 21, 2010 Share June 21, 2010 Lowering springs can never be as comfortable as original springs because it is shorter n the spring rates r higher than stock. They'll wear out the stock shock absorbers prematurely too. Of cuz if u dun mind changing your shocks every 1-2 yrs, then go ahead. A set of shocks cost ard 400 - 600. Looks of cuz is nicer but ride quality will be affected. More bounce for sure. The rear shocks have too much travel. Weigh the pros n cons wisely and u won't make the wrong choices n wasting money. If u decide to go to coilovers, then it's another ball game. Link to post Share on other sites More sharing options...
Tohto Hypersonic June 21, 2010 Share June 21, 2010 Not really true. I am using Tanebe NF210. My ride actually improve after lower and with better handling compare to stock spring. Link to post Share on other sites More sharing options...
Yuan 6th Gear June 22, 2010 Share June 22, 2010 Which is better? more lowered, more comfortable? Which is more ex? Between the 2 choices you stated, I would go for Tanabe. Link to post Share on other sites More sharing options...
Ky13 Clutched June 22, 2010 Share June 22, 2010 Go for Tanabe. According to the spec, the spring is only 5% stiffer than stock spring. Moreover, the springs will only lower your ride by about 3mm or so. This shouldn't affect the ride comfort or the lifespan of your shocks much. My ex ride was on Tanabe NF210 for 4 years+ before one of the rear shocks (stock) started to leak. Link to post Share on other sites More sharing options...
Yuan 6th Gear June 22, 2010 Share June 22, 2010 Go for Tanabe. According to the spec, the spring is only 5% stiffer than stock spring. Moreover, the springs will only lower your ride by about 3mm or so. This shouldn't affect the ride comfort or the lifespan of your shocks much. My ex ride was on Tanabe NF210 for 4 years+ before one of the rear shocks (stock) started to leak. Not me asking..... It is TS. Link to post Share on other sites More sharing options...
Tweakmax2 Neutral Newbie June 22, 2010 Author Share June 22, 2010 Go for Tanabe. According to the spec, the spring is only 5% stiffer than stock spring. Moreover, the springs will only lower your ride by about 3mm or so. This shouldn't affect the ride comfort or the lifespan of your shocks much. My ex ride was on Tanabe NF210 for 4 years+ before one of the rear shocks (stock) started to leak. Lowered by 3mm? so little ? then i change for wat Link to post Share on other sites More sharing options...
Ky13 Clutched June 22, 2010 Share June 22, 2010 oops.. typo.. It's 3cm (30mm) - about 2 fingers lower Link to post Share on other sites More sharing options...
Ky13 Clutched June 22, 2010 Share June 22, 2010 Not me asking..... It is TS. my bad... anyhow clicked 'reply' Link to post Share on other sites More sharing options...
Tweakmax2 Neutral Newbie June 27, 2010 Author Share June 27, 2010 so tanabe is beter than tein ? Link to post Share on other sites More sharing options...
Ky13 Clutched June 27, 2010 Share June 27, 2010 (edited) so tanabe is beter than tein ? I've only tried Eibach, H & R, Espelir, and Tanabe (both NF and DF); never had a chance to try Tein yet. I like tanabe NF210 most as it gives me the most comfort to my butt. Edited June 27, 2010 by Ky13 Link to post Share on other sites More sharing options...
Hermes_1 Neutral Newbie July 16, 2010 Share July 16, 2010 How much is tanabe?? I was quoted 480 for tein lowersprings! Link to post Share on other sites More sharing options...
Hermes_1 Neutral Newbie July 16, 2010 Share July 16, 2010 How is h&r springs compared with the 2 above?? Link to post Share on other sites More sharing options...
Darkblue 1st Gear August 1, 2010 Share August 1, 2010 Tanabe NF-series +1 Link to post Share on other sites More sharing options...
Kanta Neutral Newbie August 2, 2010 Share August 2, 2010 They are steel springs coated with colour... Why bother about brand? which brand produces spring which known to break? Check spring rate of each compared to stock and get wat you need. Link to post Share on other sites More sharing options...
Omrukyio Neutral Newbie October 21, 2010 Share October 21, 2010 hi guys~ was thinking of changing my stock wrx spring.. any suggestions? Link to post Share on other sites More sharing options...
Mini-itx2010 Neutral Newbie October 21, 2010 Share October 21, 2010 You can't really compare by brand alone. You need to know the specs of the springs esp spring rate, how stiff are the springs. Stiffer springs will improve your handling but will cause car to become bumpy and may be uncomfortable to some. If the shocks are unable to handle the spring movement, then its going to fail prematurely. You need to match your springs to your dampers to have a good balance between comfort and handling. Btw, lowering heigth of the car may not be a good thing. It does look nice on the outside but it affect your handling. Link to post Share on other sites More sharing options...
Mini-itx2010 Neutral Newbie October 21, 2010 Share October 21, 2010 Btw, there is also ant-roll bar which will affect your handling. Is your anti-roll bar able to react properly to the new springs? ↡ Advertisement Link to post Share on other sites More sharing options...
Tein Monoflex
Tein Monoflex
Tanabe Suspension Kits
Tein Coilover
Tein Coilover
Tanabe Sustec Pro GF Coilovers
Tein coilover overhaul quality.
Tanabe NF210
Tanabe NF210
Tein S-tech lower spring
