Passion 5th Gear June 26, 2010 Share June 26, 2010 I have just install my car with HID and the beam is like scattered all over.Immediately I fix back my halogen bulb.Now,I've a question.How come only my car install with HID,the beam will be all over the place,whereas other people car which is the same model as mine,wouldn't have that kind of beam scattered all over.Can some HID expert enlighten me on this issue?Is it my bulb issue?I really had enough of the beam shooting everywhere.I've re-align my headlight,now the throw of the light is even shorter than what the halogen does,and the scatter beam still shoot onto those road sign.Though it's not direct beam,but somehow I feel,something can be done to solve this.Forummer,pls help! ↡ Advertisement Link to post Share on other sites More sharing options...
Dscheng 3rd Gear June 26, 2010 Share June 26, 2010 Wht car u driving? Link to post Share on other sites More sharing options...
Passion 5th Gear June 26, 2010 Author Share June 26, 2010 Corolla Altis 1.6.I've seen other Altis 1.6 installing HID.But none got my issue as in the green signboard on the road was lighted up by my headlight.When I switch off,the signboard become dark. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 26, 2010 Share June 26, 2010 your headlamp reflectors and tip reflector not designed for hid unlike conti cars pls revert to halogen and dun be an ass and blind people with your misaligned beam Link to post Share on other sites More sharing options...
Passion 5th Gear June 26, 2010 Author Share June 26, 2010 Hello...I know.That's why I swapped back immediately.Until I find a permanent solution,else I'm not reverting back. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 26, 2010 Share June 26, 2010 no solution unfortunately Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 26, 2010 Share June 26, 2010 (edited) Did u get the HID from the same place as those other Altis drivers u saw? Maybe got quality issue on the bulbs. As I know, u need to change the whole lamp assy to fix HID cos the light wil shine all over as the reflectors r different & some lamps dont suit HID bulbs. Check with the place u bought the HID bulbs from. Some cheap China made bulbs r not that good. Better to stick with the original halogen bulbs but upgrade to those brighter type bulbs like Philips Vision Plus or Crystal Vision. These r maybe 70-90% brighter than stock halogen bulbs. I am now using Philips Premium which is abt 30% brighter & bulb cost about $10 each for H7. Vision Plus last time I used was 50% brighter but cost abt $35/pair for H4. Those were like many years ago so price might b different now. I tried Osram Night Breaker H7 b4 but they dont seem to last. Only a few months & they blew. Same with several other pple using them. I wont recommend them as its quite ex to keep replacing those $70/pair bulbs every few months. I recommend u go with Philips bulbs as they seem to have a better quality bulb. Edited June 26, 2010 by Pisces69 Link to post Share on other sites More sharing options...
Macrosszero Turbocharged June 26, 2010 Share June 26, 2010 HID was recently covered in this thread: http://www.mycarforum.com/index.php?showto...652716&hl=* If your Altis is the current shape Altis, only the 1.8 model comes with HID headlights. If you get a chance please take a look at the difference between the headlights of the 1.8 and the 1.6 models - the 1.8 should be using a light bucket that shields the HID bulb from directly shining forward, while the 1.6 should be using an exposed halogen bulb. The shielding greatly reduces glare while keeping the light throw useful. Link to post Share on other sites More sharing options...
ER-3682 Twincharged June 26, 2010 Share June 26, 2010 Most legal HID comes with a 'lens'also known as eyeball inside the housing,thats why the lights focus on 1 spot. Link to post Share on other sites More sharing options...
Icyfreakass 1st Gear June 26, 2010 Share June 26, 2010 Hi, bro. U can try installing a projector. Pm or sms me if u need one. We have stock but its not in our thread. Check our webbie. Www.limbat.com.sg Link to post Share on other sites More sharing options...
Zze121 3rd Gear June 26, 2010 Share June 26, 2010 Go to Sgaltis, look for projector head light. but not LTA friendly. Link to post Share on other sites More sharing options...
Happily1986 5th Gear June 26, 2010 Share June 26, 2010 aiya install HIR bulb lor. Link to post Share on other sites More sharing options...
Icyfreakass 1st Gear June 26, 2010 Share June 26, 2010 aiya install HIR bulb lor. Good alternative if ts dosent mind not having white lights! Link to post Share on other sites More sharing options...
Aimnfire 4th Gear June 26, 2010 Share June 26, 2010 your headlamp reflectors and tip reflector not designed for hid unlike conti cars pls revert to halogen and dun be an ass and blind people with your misaligned beam actually can providing the lighting point is the same what i meant is take the original bulb and hid bulb side by side look at the original bulb filament, thats where the lighting point is than take the hid and see where is their lighting point my guess its lower than your filament for hir that i purchase recenly although it gives better lighting, then 1 bulb blow i change normal bulb on the blow side then i realise that the hir is actually giving high beam although my switch is low beam i took out the bulbs and compare with the original yup hir bulb filament was sitting much lower almost at the high beam filament (my bulb type is H4) no wonder some cars give way to me then when i over take them they high beam me all the way Link to post Share on other sites More sharing options...
Xavina Neutral Newbie June 26, 2010 Share June 26, 2010 your headlamp reflectors and tip reflector not designed for hid unlike conti cars pls revert to halogen and dun be an ass and blind people with your misaligned beam +1. Sorry for off topic but i have to say, Please for those who are using these xenon lights or any other white lights, please lower your lights, drivers infront WILL be dazzled and its bloody hell dangerous and distracting. Link to post Share on other sites More sharing options...
Passion 5th Gear June 27, 2010 Author Share June 27, 2010 Hi,I'm trying to stay stock except for the bulb.I've seen other altis got it done up,so I believe I can do the same.Just who got the lobang to get it done?I realise 9006 bulb compare to D2S bulb,9006 bulb has slightly longer length and the arc is slightly more into the capsule of the bulb.Now,I'm suspecting it's the bulb problem more than anything else. Link to post Share on other sites More sharing options...
Bummer 1st Gear June 27, 2010 Share June 27, 2010 You can also choose to buy the entire Altis 1.8 model HID headlamp housings including beam auto levelling from some spare part shop and retrofit. Any other option will not include auto levelling which means if your boot and rear are full of passengers and cargo and sinks down, your HID will not automatically lower the beam thus resulting in the beam shining up into other cars and blinding them. Do not do this. Get Philips X-treme POwer +80 if you want longer throw. Link to post Share on other sites More sharing options...
Passion 5th Gear June 27, 2010 Author Share June 27, 2010 You can also choose to buy the entire Altis 1.8 model HID headlamp housings including beam auto levelling from some spare part shop and retrofit. Any other option will not include auto levelling which means if your boot and rear are full of passengers and cargo and sinks down, your HID will not automatically lower the beam thus resulting in the beam shining up into other cars and blinding them. Do not do this. Get Philips X-treme POwer +80 if you want longer throw. May I know where can I get this?Anyone can intro a shop to get this? ↡ Advertisement Link to post Share on other sites More sharing options...
Math Question
Math Question
Toyota Camry
Toyota Camry
Question on Transfer of Car Ownership
Question for Car Servicing
COE renewal question
Question of polyclinics
Noob questions on property
