Hshs 5th Gear July 15, 2010 Share July 15, 2010 Yes, window curtain plus door visors help a lot[cool] ↡ Advertisement Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 30, 2010 Share July 30, 2010 saw it at autob*cs..forgot how much though.. went to both autob*cs, they don carry the ventilation fan. anyone know where to get? Link to post Share on other sites More sharing options...
Tzehou Neutral Newbie July 30, 2010 Share July 30, 2010 Home-Fix DIY shops got sell them too. Go to bigger ones like those in Thomson. They should have tem. Link to post Share on other sites More sharing options...
Vextan 1st Gear July 30, 2010 Share July 30, 2010 to reduce the heat inside your car, the secret is to use something to cover the dashboard, because it is the dashboard that gets heated up the most when under sun for long, dont believe, touch the dashboard and it is hot as a piece of fried chicken. by doing so, you greatly reduce the heat build up. Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 30, 2010 Share July 30, 2010 (edited) Home-Fix DIY shops got sell them too. Go to bigger ones like those in Thomson. They should have tem. Thanks for the info, will drop by to check. Maybe i should check out mustafa too..... Edited July 30, 2010 by Tom_kkh Link to post Share on other sites More sharing options...
Altivo 3rd Gear July 30, 2010 Share July 30, 2010 i have a sunroof so when i return to my car after parking under the sun for a long time, i will open the roof and all the windows... the heat dissipate pretty fast Link to post Share on other sites More sharing options...
Mcf777 Turbocharged July 30, 2010 Share July 30, 2010 Not sure about the interior temperature, but its hot enough to deform my nohonhon (those shaking head solar toy) plastic box. I've ever taken the external temperature of a silver and maroon colour car parked under sun, silver car surface was 50 deg.C and the maroon colour car at 63 deg.C. interior temperature is about 40-43 deg C under the hot sun Link to post Share on other sites More sharing options...
Xefera 6th Gear July 30, 2010 Share July 30, 2010 Actually I read from an article that the fastest way is to open the windows slightly then drive the car. The wind entering the car will push the hot air out, and switch on the aircon after a few minutes. This will be most efficient and will not cause premature RIP of the compressor Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 30, 2010 Share July 30, 2010 i have a sunroof so when i return to my car after parking under the sun for a long time, i will open the roof and all the windows... the heat dissipate pretty fast i am more concern of the heat speeding up the damaging of interior leathers rather than getting into a hot car under the sun. So i guess the ventilation fan should come in handy. Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 30, 2010 Share July 30, 2010 i am more concern of the heat speeding up the damaging of interior leathers rather than getting into a hot car under the sun. So i guess the ventilation fan should come in handy. For protection of plastic, cover and solar film is more useful than ventilation fan. Fan cools temp a bit, but still expose to UV and IR. Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 30, 2010 Share July 30, 2010 not so much on e heat which is damaging, rather its e super dry humility when e interior is cooked up under hot sun. Our air con which cool n dry e air within also attribute to it. Link to post Share on other sites More sharing options...
Rainman 1st Gear July 30, 2010 Share July 30, 2010 You know that hot gush of air when you open your car door? How do we reduce the temp when the car is parked in the open? Do we leave gaps in the windows? You can do that if you have window visors installed I guess. Is there any solar powered device in the market which can be installed to provide ventilation and does it help? I find it leaving window gaps helps alot... simple, effective and costless. Best is u have windows visor also, helps rain splash or naughty hands... Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 30, 2010 Share July 30, 2010 For protection of plastic, cover and solar film is more useful than ventilation fan. Fan cools temp a bit, but still expose to UV and IR. ya cover best, but i find it too troublesome. Got Rikecool installed but i find it overrated! So trying my best to bring down temperature to "prolong" the interior's life. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 30, 2010 Share July 30, 2010 I find it leaving window gaps helps alot... simple, effective and costless. Best is u have windows visor also, helps rain splash or naughty hands... I agree on this. Cheapest way to get rid of the heat without spending a single cent. And very effective too. Link to post Share on other sites More sharing options...
Circuit Clutched July 30, 2010 Share July 30, 2010 Just get window visor which is should be easily available, then leave 1 cm gap in car. normally i leave open a bit at passenger side and driver side with 1 cm gap confirm better alot. cheap and good , no need worry things spoilt Link to post Share on other sites More sharing options...
Carhire Neutral Newbie July 30, 2010 Share July 30, 2010 Intresting comments ... Link to post Share on other sites More sharing options...
Hosaybo 6th Gear July 30, 2010 Share July 30, 2010 can try the mist type of spray.... magicool. google for it. Link to post Share on other sites More sharing options...
Rongshu Neutral Newbie July 30, 2010 Share July 30, 2010 (edited) I feel after parking for whole day outside, the interior abosorbs a lot of heat. Even after driving for 1 hour with aircon, when I enter the car again at night, I still feel warm or a bit hot. The heat still slowly released from seats, dashboard etc. Not sure if anyone else feels the same way. Just like a house facing west and is baked for whole day. Even a few hours after sunset still can feel the heat. Edited July 30, 2010 by Rongshu ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
