  • Search this thread
  • Reply to this topic
55 replies to this topic | 45 praises
#1
Posted 04 October 2010 - 09:26 AM
Hulk
  • THREAD STARTER
  • Premium member
    Hulk
    4th Gear
    Author Image
    794
Hi bros,
Recently when I depress my brake padal, there is a "tock" sound heard. Serviced brake but sound still come back. I am driving a Toyota, heard that this is a known problem for Toyota that the "tock" sound come from the brake caliper.
Any bro who have this problem before? The sound is so irritating that I feel want to replace the whole brake caliper. How much to get stock caliper? Which stockist to get?
#2
Posted 04 October 2010 - 09:53 AM
Aaron_soh80
  • Aaron_soh80
    Banned
Hi bros,
I aso face dis problem..when braking got sound..i thought is brake pad but change le still the same..
esp when braking on a down slope ..more louder.. me driving city ya..
#3
Posted 04 October 2010 - 12:58 PM
Mini-itx
  • Mini-itx
    Banned
Noise from brakes, sometimes its quite normal sometimes it may be warped rotor. Sometimes its due to the way the pistons compresses the pads onto the rotors.
#4
Posted 04 October 2010 - 05:09 PM
Hulk
  • THREAD STARTER
  • Premium member
    Hulk
    4th Gear
    Author Image
    794
#5
Posted 04 October 2010 - 05:30 PM
Tiphoneas
  • Tiphoneas
    Clutched
    Author Image
    29
i 2nd that. do a check at workshop and highlight this to them. some workshop can't diagnose the problem, and once you tell them where and what, they can check and mystery solved!
#6
Posted 05 October 2010 - 12:01 AM
R_aquarii
  • Premium member
    R_aquarii
    3rd Gear
    Author Image
    254
my toyota vios also got this noise..
if the problem is with the piston is there any solution?
#7
Posted 05 October 2010 - 10:50 PM
Hulk
  • THREAD STARTER
  • Premium member
    Hulk
    4th Gear
    Author Image
    794
I'm waiting to see a mechanic who work in agent, recommended by my colleague to see my brake "tock" sound problem now. If can replace piston I will do it, if can't I will replace the whole brake caliper system, don't mind spend little bit more as long can get rid of the irritating sound.
#8
Posted 22 November 2012 - 09:55 PM
Yr1985
  • Yr1985
    5th Gear
    Author Image
    1,320
long time ago thread, but my Vios have his problem now. Anyone can help? Hulk?
Edited by Yr1985, 22 November 2012 - 09:56 PM.
www.sgfubar.com
Chance and luck mostly favour the undeserved people.
I'm not one of them, fortunately.
#9
Posted 22 November 2012 - 10:26 PM
Rustyz
  • Premium member
    Rustyz
    6th Gear
    Author Image
    4,492
Can try record the sound and upload. Word may not be the best describe it
maybe diff sound diff solution.
Can try use water spray the brake pad sometime is just dirty. Do it when the brake are cool.
Edited by Rustyz, 22 November 2012 - 10:29 PM.
If anyone can have it, I don't want it.
#10
Posted 23 November 2012 - 11:50 AM
Pisces69
  • Premium member
    Pisces69
    2Fast2Furious
    Author Image
    55,394
Tok sound likely some bolt is loose. Hv it throughly checked.
If e nut or blot comes out u cud hv no brakes.
Raise car up n stand below n rock car to see where sound us from.
#11
Posted 23 November 2012 - 12:22 PM
Newdrive
  • Newdrive
    4th Gear
    Author Image
    638
Hi bros,
not sure if the sound u getting same as mine.
i am driving toyota vios though.
WS tell me cause one of my rear brake caliper... there is 2 pin, one is missing and they cannot replace cos the hole is misaligned... hence need to replace the whole caliper!
if u want, we can meet up... and listen to each other car's sound.
it happens to me whenever i brake or reverse.
Edited by Newdrive, 23 November 2012 - 12:22 PM.
QUOTE (AboutLove)
About Love Production - Pre Wedding, Events & Travel Photography
#12
Posted 23 November 2012 - 01:54 PM
Pohhenry
  • Premium member
    Pohhenry
    Author Image
    7,966
Might be small little sand on the brake pad then press onto rotor disc also got sound... drivingcar.gif
#13
Posted 23 November 2012 - 02:24 PM
Yr1985
  • Yr1985
    5th Gear
    Author Image
    1,320
Aku drive Vios too!! Now I am at BM, tech uncle said could be ABS actualator. They are now checking for me. Will update here later
www.sgfubar.com
#14
Posted 25 November 2012 - 09:11 PM
Jphua
  • Premium member
    Jphua
    1st Gear
    Author Image
    80
tis could be a point.
mine caliper's threaded hole is gone hence the bolt to to tighten the caliper is loose. so when brake is pressed, tock sound come out as the bolt is lossen.
pls hoist up the car & check.
refer to the pic attached. see the rusty bolt in the center of the pic. you'll see there is a gap between the bolt & the bracket.
tis is my case. best advise to bro who heard sounds from braking, pls do send for a check. brake system don play play.
#15
Posted 25 November 2012 - 11:30 PM
Newdrive
  • Newdrive
    4th Gear
    Author Image
    638
looks like similar to me but mine is the hole that the 2 pins is holding on to. one of the hole already buang... so now left 1 pin to hold. i am still looking at scrap yards to look for a better condition to replace one of my rear brake caliper.
Edited by Newdrive, 25 November 2012 - 11:31 PM.
QUOTE (AboutLove)
#16
Posted 25 November 2012 - 11:49 PM
Hondafit2008
  • Hondafit2008
    2nd Gear
    Author Image
    175
tock sound is brake system got something loose, piston pot or pad catch or rotor. while braking got metal sound (eeeee) is cos pads change liao but rotor no skim so uneven rubbing. got is from other forum hope helps
#17
Posted 26 November 2012 - 04:32 PM
Jphua
  • Premium member
    Jphua
    1st Gear
    Author Image
    80
may i know wad caliper u r using rite now, stock or bbk?
#18
Posted 27 November 2012 - 11:31 PM
Stevenliewhk
  • Stevenliewhk
    Author Image
    13
this is not normal , this is rotor got problem , u can try to do disc skimming only $60-$80
#19
Posted 28 November 2012 - 12:26 AM
Jphua
  • Premium member
    Jphua
    1st Gear
    Author Image
    80
if rotor is uneven, normally it will produce a screeching sounds rather than a tock tock sounds. tat's wad i think so...
best is TS go check his brake be it caliper, rotor, any bolts connection better.
#20
Posted 28 November 2012 - 07:14 AM
Stevenliewhk
  • Stevenliewhk
    Author Image
    13
hahaha......u can dont believe me nvm , im mechanic i do alot car brake like this , if you need to try just do it or need help also can text me
90108212 .....this a small problem dont worried ..
Dynamics Mechanic Pte Ltd
Quick Reply
Tags: Brake, sound
